[ Total Views: 667 | Total Replies: 2 | Thread Id: 97505 ]
Author: Subject:  1300 twin port to 1600 twin port
Memberretroresto
A.K.A Paul
Threads: 147
Theme: UltimaBB Psyche Green
Mood: Depends on how my VW is running
posted on June 20th, 2012 at 04:22 PM
Hi All,
I have a twin port 1300, can i simply swap out the 1300 P&B for 1600 P& B and use the same 1300 TP heads?
Paul
Memberragged
A.k.a.: David
Just ask if you need HELP!
Threads: 46
posted on June 20th, 2012 at 04:35 PM
Piston and cylinders slip straight in but the heads will need machined out to fit the bigger cylinders. (just like you would do to a 1600 head if you were fitting 90.5 - 94 mm cylinders) Also, some of the early 1300's had the smaller 1200 valves but the later 1300's had the 1600 valves. If I remember correctly, they used a dome top piston to increase the Comp ratio when they used 1600 valves/heads.
Cheers Dave
Threads: 559
posted on June 20th, 2012 at 08:14 PM
1300s twins also had smaller inlet manifolds, might pay to get a full 1600 T and cast ends.
The 1300 twin port is a great basis for a motor, they are usually very under stressed.
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
