| [ Total Views: 1421 | Total Replies: 6 | Thread Id: 97685 ] |
scot70wagon
Threads: 84
Mood: happy
| posted on July 4th, 2012 at 06:09 PM |
generator to alternator query
how do you modify the wiring on a 68 12v bug to change from generator to go to alternator. i know you need to bypass regulator as alternator is self
regulated. but not sure exactly how to go about it. cheers
ALL GOOD THINGS HAPPEN IN NEWCASTLE. JUST ASK A NOVACASTRIAN :    !!
vwo60
Threads: 71
Mood: good
| posted on July 4th, 2012 at 06:19 PM |
You connect the wire from your ignition light to the D+ terminal and a large wire from the B terminal on the alternator to the positive post on the
starter motor. this cable will have to handle the output of the alternator.
scot70wagon
Threads: 84
Mood: happy
| posted on July 4th, 2012 at 09:08 PM |
the alternator has a d+ and a b+. the d+ is a bolt style connection and the b+ a push plug connection. do you disconnect the wires from the generator
regulator under the back seat, ie bypass it or leave it connected. cheers
hulbyw
Threads: 133
Mood: I'm OK, RU?
| posted on July 4th, 2012 at 09:14 PM |
Try this http://forums.aussieveedubbers.com/viewtopic.php?tid=50478&page=1#pid470541
Damn good reference.
Cheers.......Wayne
pod
A.k.a.: paul mrvw061
Mood: could be better
| posted on July 4th, 2012 at 10:05 PM |
D+ the idiot light, b+ is the thick cable that goes to both sides of the regulator under the back seat,you need to join the one that goes into the
regulator with the one that goes from regulator to the battery ,effectively taking out the genny regulator, heres a couple of diagrams
| Error |
| Error |
hulbyw
Threads: 133
Mood: I'm OK, RU?
| posted on July 5th, 2012 at 06:12 PM |
I too am interested in this conversion, however different folks are saying different ways of connecting the alternator, with respect to the D+ and B+
terminals. Looking at the above options and even doing a Google, I am still confused. Can anyone explain please
Cheers...Wayne
matberry
| posted on July 5th, 2012 at 06:52 PM |
D+ (dynamo positive) becomes B+ (battery positive) by joining the the big cables together either at the alt B+ post or in the wiring (usually undfer
the seat). The exact wiring mods vary depending on year of car
