[ Total Views: 467 | Total Replies: 1 | Thread Id: 97715 ]
Author: Subject:  Oil Pump Question
MemberNewt
Threads: 82
Mood: Born 10 minutes late & never caught up.
posted on July 6th, 2012 at 09:38 PM
Oil Pump Question
Hi Guys,
Is there a preference between an aluminum oil pump and a cast base oil pump?
I read somewhere that steel ones expand differently and can leak. Any thoughts?
Newt
It is as it is - If you didnt enjoy today, you've missed the opportunity.
Membervwo60
Threads: 71
Mood: good
posted on July 7th, 2012 at 07:50 AM
I have two cast iron melling pumps in service at the moment, they do have a different expansion rate to aluminium, people refer to the pumps leaking internally and of having oil pressure problems, make sure they fit the oil pump bore correctly when you are building the engine, some aluminium pumps have the same issues with two much clearance in the bore and these leak as well. both my cast iron pumps have no oil pressure problems or leak externally.
