Aussieveedubbers Tech Talk 34 PICT 3 repair? |
[ Total Views: 432 | Total Replies: 2 | Thread Id: 97933 ] |
homer
Threads: 30
posted on July 21st, 2012 at 12:54 PM |
34 PICT 3 repair?
One of the studs on my 34 PICT 3 is pulling (spinning when tightening nut). Can this be repaired or is the carb stuffed?
Joel
posted on July 21st, 2012 at 02:29 PM |
Is it the one under the bowl at the back or the front one?
you can use a nut and bolt on the front one with a bit of grinding but the rear one under the fuel bowl will need a helicoil.
homer
Threads: 30
posted on July 21st, 2012 at 02:43 PM |
Thanks for the reply Joel. Its the front one so i guess i might try that.
[ Queries: 40 ]
[ PHP: 1.7% - SQL: 98.3% ]
