| [ Total Views: 863 | Total Replies: 5 | Thread Id: 9794 ] |
grouch
Threads: 15
Mood: 'gruven
| posted on August 27th, 2003 at 05:07 PM |
Kombi Speedo Adjustment
Does anyone know if there is a way to adjust the speedo reading ie. my speedo reads approximately 10kph slower than it should at 60kph.
kombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
| posted on August 27th, 2003 at 05:59 PM |
speedo calibration is done by an instrument maker - costs heaps, better to start at the other end & work back, 1 what size tyres do you have, 2 is
the gearbox diff correct for the vehicle & it's speedo ? large diameter tyres will make speedo read slow
Please, I need drivers side window regulator (winder mechanism) for my '54
vw54
| posted on August 27th, 2003 at 06:01 PM |
Best off removing it from the car and getting a Instrument fitter to Overhaul it and or calibrate it for you on the test bed.
We havea couple of places here in Sydney that can do it but i suspect that you have similar shops in Brisbane
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on August 27th, 2003 at 11:08 PM |
sorry made severe mistake - drive for kombi speedos is front wheel ei small diameter tyre will make speedo say you are going faster than you are ,
large diameter tyre will make speedo say you are going slower than what you are the speedos are & geared & calibrated anticipating a certain
size tyre & rolling diameter the odometer is driven by a fixed gear & its accuracy therefore does not vary with wear or age
The needle indicating speed , however is driven indirectly by what i suppose you could call a combination of magnets a spring & centrifugical
force & that setup can be subject to inaccuracy when the instrument is so old so - if you sit on exactly 60kmh for exactly 1 minute the odometer
should register exactly 1 kilometre & if it does you are wasting a hell of a lot of money to get it cleaned and calibrated, you either have the
wrong speedo or wrong diameter tyre
1303Steve
| posted on August 27th, 2003 at 11:33 PM |
I have an aftermarket speedo in my car, I had a ratio box made for it by Speedscreen in Newtown. Have you checked the odometer on one of the freeway
sign posts?
VDO now make all their speedos electronic, and they are easily user adjusted.
1302Steve
Purple Martin
A.k.a.: Martin
Threads: 141
Mood: warm & fuzzy
| posted on August 28th, 2003 at 08:29 AM |
posted by kombikim
if you sit on exactly 60kmh for exactly 1 minute the odometer should register exactly 1 kilometre & if it does......
......you know that your tyres are exactly the right size because the odometer is driven by a fixed gear. If the odometer is right but the speedo is
wrong, the problem must be in the magnets/spring.
1959 red & white Beetle
1975 Kombi camper
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on August 28th, 2003 at 08:56 AM |
yep that is it
Steve's electric speedo sounds great,
hate to think how much it would cost
a digital speed alert kit from Jaycar might also be a viable option
grouch
Threads: 15
Mood: 'gruven
| posted on August 28th, 2003 at 07:16 PM |
Thanks guys, I believe I have stock rims and tyres. I might do a test run with another car to check the speedo at different speeds.
Might be easier to just mark a spot on the speedo lens at the correct speeds.
