[ Total Views: 604 | Total Replies: 6 | Thread Id: 983 ]
Author: Subject: standard compression?
MemberMad Manx
A.k.a.: Travin C.
KombiKroozin
posted on October 4th, 2002 at 11:56 AM
Can someone tell me what the standard compression ratio for a twin port 1600 type one engine is?
Member70AutoStik
Threads: 18
posted on October 5th, 2002 at 12:56 AM
If you mean the models sold in Australia, they were 7.5:1 The current beetles come with 6.5:1 for US and 6.6:1 for the rest of the world.
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on January 29th, 2004 at 08:18 PM
prior to April 68' 7.7:1
from April 68' 7.5:1
sorry for the delay in replying :D
posted on January 29th, 2004 at 09:02 PM
unless Gene built it
Then it is 3.2:1
:P
Member70AutoStik
Threads: 18
posted on January 29th, 2004 at 11:02 PM
Don't want to nit-pick Craig, but a pre-'68 1600?
(just raggin ya', don't take offence.)
Memberhelterskelter400
Threads: 62
posted on January 29th, 2004 at 11:06 PM
what should we be looking for in a compression test on a 1600????
Member70AutoStik
Threads: 18
posted on January 29th, 2004 at 11:30 PM
From memory, the book says 80. For a bit of performance 120 is nice, but 100+ with less than 20 between the lot shoud be a sign a rebuild is not quite required yet.
Memberlugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
posted on January 30th, 2004 at 01:48 AM
My book says 106-135psi new,92psi wear limit for a 1300sp.For a 1500sp 114-142psi new and 100 clapped.My balltearers got way over 150psi on all cylinders,AND YES IT DETONATES LIKE A B##T##D,im waiting for the big one to drop.:D
posted on January 30th, 2004 at 07:33 AM
The main object is to find if there ia any differance in the compression figures they need to be equal or with in a few Lb either way.
You dont want one cyclinder with a drastic different pressure
From memory the last time i did my 1500 engine the reading was around 150Lb
Threads: 62
posted on January 30th, 2004 at 09:15 AM
excellent.
my 1600tp has ~130 all round...
MemberCraig Torrens
Threads: 347
posted on January 30th, 2004 at 09:57 AM
Just reading from the book !!!
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
