[ Total Views: 752 | Total Replies: 8 | Thread Id: 98566 ] |
BrisDubba
Threads: 190
posted on August 27th, 2012 at 07:47 PM |
seeping shaft - solex 34 - kombi carbs
After rekitting the solex 34's in my 75 bay - the right carb is seeping fuel through the shaft (well that what is seems to be anyhow)
I believe they are able to be rebushed/ rebuilt - anyone done this before - any suggestions.
Peter
VW Toys
64 Beetle - club car - Herbie
RSK 718 Porsche Spyder
76 Southern Cross Offroad racing buggy. "Manx Buggies"
77 Cobra Offroad racing buggy "RipOff"
68 Country Buggy KO200
64 Manx swb
70 Dual Cab kombi
74 Dual Cab kombi
74 Micro bus
silver
Dangerous when poked
Threads: 162
Mood: In 2 Minds
posted on August 27th, 2012 at 08:55 PM |
This tends to happen when the float levels are set wrong I would check them first
Keeping it real !
68AutoBug
posted on August 27th, 2012 at 11:57 PM |
Quote: | Originally
posted by BrisDubba
Peter
Hi Peter
to get them rebushed the hole is drilled larger then a bush is fitted.
Carburetor specialists would do this..
sounds like the fuel is running over the shaft/flap and out the shaft...
so, maybe the needle and seat aren't working when the bowl is full of fuel..
or too much fuel pressure from Your pump...
only need a couple of PSI.. [2psi]
Your pump may need shimming to lower the pump pressure..
if its an original vw pump
I have always oiled All moving parts on a carburetor
[just like VW mechanics did back in the 50s and 60s..]
this will help stop most wear...
vw54
posted on August 28th, 2012 at 07:11 AM |
give VVDS a call 02-9789-1777 as they have them rebushed and refurbished to make all new
there are a few different versions so you may have to remove and take some pics or remove and send down for corrrect supply of the throttle plates
they usually have several sets of the different versions in stock
BrisDubba
Threads: 190
posted on August 28th, 2012 at 01:18 PM |
Just when I thought the problem might be solved with Lee's suggestion about the fuel pressure. The dial was set to 3.5 so I wound it back to 2 and no
obvious weeping..
I ran it at idle for 10minutes or so without seepage and then as soon as I turned it off the motor the seepage began....
I will change the needle and seat over and see if that changes anything. I didnt change them over as the ones in the kit looked pretty poor quality
compared to the originals.
Peter
VW Toys
64 Manx swb
70 Dual Cab kombi
74 Dual Cab kombi
74 Micro bus
silver
Threads: 162
Mood: In 2 Minds
posted on August 28th, 2012 at 01:23 PM |
Quote: | Originally
posted by BrisDubba
obvious weeping..
Peter
try adjusting the height of the needle and seat with another fibre washer rather than replacing it. I had the same problem and it was this adjustment
that fixed it
Keeping it real !
BrisDubba
Threads: 190
posted on August 28th, 2012 at 02:35 PM |
Progress..
Cheers Silver, I did as you suggested and put another washer under there (either I misplaced the nylon ones or my kit had them as brass - either way I
didnt have any nylon ones)
I ran it like before and it isnt seeping upon shut down, so hopefully that will have solved it.
I rang about the rebushing and it is $65per carb for the throttle plate, which was fine but I would have had to send down to them and then they send
one up - so for the moment this has worked out okay, but will keep it in mind if the issue persists.
Thanks all (now onto my next item on the to-do list)
I have a week to get it on the road as I want to cruise along to action day (it is my daughters 3rd birthday so wont be able to stay long)
Peter
VW Toys
64 Manx swb
70 Dual Cab kombi
74 Dual Cab kombi
74 Micro bus
matberry
posted on August 28th, 2012 at 02:48 PM |
Definately float level related, rebush is for sealing air out, your fuel leaking is due to high float level or seeping needle/seat. When you turn off
the engine, the residual fuel pressure actually rises due to the stationary fuel at the pump and in the fuel lines heating up and therefore expanding
putting further load on the needle/seat. If it's not up to the task, it lets the fuel into the carb, which is also increasing in temp and the excess
fuel goes down the throat of the carb.
vw54
posted on August 28th, 2012 at 04:14 PM |
an easy way to find if the throttle bushes are worn and leaking is when the engine is running get a length of rubber tube
one end in your ear and use the othe end around the throttle shafts
if there buggared you will hear them sucking air very easy time to replace
