[ Total Views: 716 | Total Replies: 5 | Thread Id: 98574 ]
Author: Subject:  thread reapir
Member71dub
Threads: 46
Mood: happy
posted on August 28th, 2012 at 06:59 PM
thread reapir
Hi any one of anybody in brisbane who can repair the threadsb in the steering wheel of a super bug where the srews fit to secure the horn ring .I have two that are stripped and dont want to get another steering wheel .
regards barrie
Membergreedy53
Threads: 468
Mood: strung out
posted on August 28th, 2012 at 09:34 PM
could you redrill using a bigger bolt or fill it with a resin or the 2 piece epoxy stick you mix the 2 bits together and away ya go can be drilled when set
good luck
posted on August 28th, 2012 at 10:14 PM
Just put in slightly larger screws, even self tapping screws will work there I believe
Memberpsimitar
Threads: 148
posted on August 30th, 2012 at 12:04 AM
I wonder how small helicoils go too?
Epoxy putty may hold the spring tension of the horn ring.
I think I'm right in saying the hub itself is alloy so welding is out.
Hmm, as the screws are 'special' then you could re-tap to M4 with a blind tap so the M4 screw bottoms out so the screw stays tight and cut the screw to length than that works or dill thro the hub to put a nut on the other side.
MemberOld Dubber
Threads: 25
Mood: great!
posted on August 30th, 2012 at 07:46 PM
Bring it over to me I will fix it for you
Grahame
Grahame
visit my club site at www.vwdcqinc.org.au
Member71dub
Threads: 46
Mood: happy
posted on August 30th, 2012 at 10:14 PM
hi grahame thanks for that have just bought helicoil kit from the uk to repair.
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
