| [ Total Views: 495 | Total Replies: 3 | Thread Id: 99085 ] |
71dub
Threads: 46
Mood: happy
| posted on October 6th, 2012 at 11:13 AM |
steering column info
Hi guys can any advise where i can get info on replacing the top bearing on the steering column on a 1971 super bug .The shaft moves up and down an i
found bits broken plastic type stuff when steering wheel removed.I have a new top bearing to replace old one is there anything else i need.
regards barrie
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
Member Is Online
| posted on October 6th, 2012 at 11:16 AM |
i think the old man got the one to replace mine from tooleys.
most places carry them.
Joel
| posted on October 6th, 2012 at 01:11 PM |
You'll most likely find the bearing is ok, they don't normally go bad, its only the plastic bushing that centers the steering shaft in the bearing
disintergrates over 41 years and you get that play.
Before you go to all the effort of replacing the bearing try it with a new bushing.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-111-535D
71dub
Threads: 46
Mood: happy
| posted on October 6th, 2012 at 09:05 PM |
Thanks joel yes bush is shagged will need to get new one will try micks on monday
