[ Total Views: 678 | Total Replies: 2 | Thread Id: 99287 ]
Author: Subject:  Help with motor..
Membersurfdub
Threads: 41
Mood: Bright Eyed
question.gif posted on October 20th, 2012 at 06:17 AM
Help with motor..
allo all
i am just about to mount a 2l engine into my kombi though the gearbox is a 3 rib , will i need to change the flywheel so they meet?
if so does anyone have one =]
jordan
posted on October 20th, 2012 at 09:04 AM
You can change the bell housing on the trans (cheaper) or flywheel and clutch. Not really a good idea tho, unless you address the mismatch of gear ratios issue.
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on October 20th, 2012 at 11:32 AM
easiest is to get an 1800 flywheel n clutch 215mm, best option is the matching 2ltr box as mr berry said ratios in a 1600 box suck for freeway cruising
