[ Total Views: 498 | Total Replies: 3 | Thread Id: 99353 ]
Author: Subject:  oil pick up tube
Memberthomo
Threads: 8
posted on October 23rd, 2012 at 06:01 PM
oil pick up tube
i have been having trouble with my oil pick up tube
it doesn't seen to sit right is it possible to refit it with out
striping the motor
thanks
Memberbajachris88
A.k.a.: Chris Leete
Threads: 534
posted on October 23rd, 2012 at 07:28 PM
There is a nut that holds the oil pickup tube inside, from a stud around the oil sump plate hole. If you got good little fingers, this nut might just need tightening to bring the pick up tube 'home' as such. Id put a rag around you hand to prevent cuts on the case though. the edges are suprisingly sharp.
Otherwise, there is on some motors (like my 1600dp case) one of those giant flat head drive 'bungs' that screws into a hole where the other end of the pickup tube goes. Might able to tighten and fasten the pickup tube through there. But some cases like the early 1500 i have don't have this bung. The hole is filled in.
(ô_!_/ô) (ô_!_/ô)
Memberthomo
Threads: 8
posted on October 24th, 2012 at 02:15 PM
thanks for that i will give it a try in the next couple of day
Membervwo60
Threads: 71
Mood: good
posted on October 25th, 2012 at 07:22 PM
If the pickup tube is off centre, you might be able to get a piece of tube that fits neaty inside the pick up, you can gently bend it in place, i have done this before, you can really only check if the hold down nut is tight.
