| [ Total Views: 872 | Total Replies: 5 | Thread Id: 99372 ] |
lakeb0
Threads: 1
| posted on October 24th, 2012 at 06:33 PM |
1970 disc brakes on a 1965 Type 3 fastback? Please help
Hey all, the front drum brakes on my 1965 fastback need repairing, however I have sourced some disc brakes off a 1970 squareback and was thinking of
using them instead. Does anyone know if this will be a relatively easy conversion? Or is the setup too different on the later models? Any information
will be greatly appreciated. |
scot70wagon
Threads: 84
Mood: happy
| posted on October 24th, 2012 at 06:56 PM |
easy changeover. you just get 4 stud instead of 5 with the 70 model brakes.
ALL GOOD THINGS HAPPEN IN NEWCASTLE. JUST ASK A NOVACASTRIAN :    !!
matberry
| posted on October 24th, 2012 at 07:24 PM |
You need the stub axle as well as disc's, calipers, bearings and wheels. Also master cylinder should be changed.
Calcool
Threads: 196
| posted on October 25th, 2012 at 02:01 PM |
The great thing about Type 3's is the interchangability between models on the mechanical parts.
You will need stub axle to grease cap on the 70 model to bolt onto the ealry control arms, just unbolt from the ball joints and bolt back on, you will
need the dual circuit master cylinder as well, the trickiest part is putting in a dual circuit brake fluid reservoir, but this is also interchangable
from the 70 modle.
Cheers,
David
lakeb0
Threads: 1
| posted on October 25th, 2012 at 03:36 PM |
Great, thanks a lot all. Should I grab the brake lines as well? |
Calcool
Threads: 196
| posted on October 25th, 2012 at 03:40 PM |
Yes,
I would suggest putting a kit thru the calipers unless they wer working when you pulle dthem off and for safety chnage the flexible brake lines too.
Get all the lines to go with the brake fluid reservoir. Just makes it a lot easier!
Cheers,
David
