[ Total Views: 755 | Total Replies: 6 | Thread Id: 99666 ] |
gayndahkombi
posted on November 14th, 2012 at 05:22 PM |
reduction box gearbox how to
I am in the process of trying to pull the gearbox out of our 64 DC splitty ute apart to fix 4th and reverse gear. We can not get one of the brake
drums off. Do I need to take the brake drums off or can i remove the axles some other way. The mechanic is having a hard time and well I need this box
done ASAP.
any help would be greatly appreciated
Klaus
Threads: 100
Mood: Heavily modified
posted on November 14th, 2012 at 06:02 PM |
is he using a drum puller ? or is the nut seized ? heat heat heat and lots of wd -40 or similar and leave over night or cut drum apart
tar76
Threads: 95
posted on November 14th, 2012 at 06:04 PM |
After it's had a good soak some good whacks with the hammer!
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
BiX
Threads: 154
posted on November 14th, 2012 at 06:38 PM |
make sure the pads are backed off........
then normall heat and a hammer......
Go hard or go home!!!!
vwo60
Threads: 71
Mood: good
posted on November 14th, 2012 at 07:02 PM |
Do not hit anything with a hammer, just ends up costing more money to fix the damage, back the shoes off, load the drum up with a puller and heat the
center of the drum with the oxy.
gayndahkombi
posted on November 14th, 2012 at 07:39 PM |
Yes brakes have been backed right of and he has heated but still no go. He will attempt it again tomorrow
Klaus
Threads: 100
posted on November 14th, 2012 at 09:36 PM |
vw's love hammers , dont be a girl haha , i use a leather hammer which doesnt do the damage a metal one does so settle down
