| [ Total Views: 32725 | Total Replies: 563 | Thread Id: 101171 ] |
| Pages: 1 .. 8 9 10 11 12 .. 19 |
Stanley
Threads: 270
| posted on July 28th, 2013 at 07:12 PM |
Officially retired the 1641 Turbo by pulling it off ready for the new owner.
| Error |
Ampdub
Threads: 44
| posted on July 28th, 2013 at 11:23 PM |
Had a fuel smell in front so out came the tank and fitted new electric fuel pump and brake hoses to master cylinder while tank was out. Last owner
used lead wipe to fix hole in bottom of tank so flushed (lots) and blew out for 5 mins then cleaned and welded up that sucker, no leaks now.
nils
Threads: 65
| posted on August 11th, 2013 at 06:56 PM |
Turned a box of pipe into somethimg useful
Quit calling rust patina
Klaus
Threads: 100
Mood: Heavily modified
| posted on August 11th, 2013 at 07:14 PM |
Welded a complete roof on a split bus ..now to grind back 500+ plug welds
FROSTY
Threads: 65
| posted on August 11th, 2013 at 08:02 PM |
Dropped my gearbox off to Dave Butler for an alloy spool!!!! The old diff is now holding the gate closed.
1303Steve
| posted on August 11th, 2013 at 08:33 PM |
Putting my bug back together again after some issues with the paint job
vwo60
Threads: 71
Mood: good
| posted on August 11th, 2013 at 08:40 PM |
Fitted a gauge panel in my type 34
| Error |
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
| posted on August 12th, 2013 at 10:08 PM |
I also played with dash boards...
http://forums.aussieveedubbers.com/viewtopic.php?tid=73866
Trendy
Threads: 25
Mood: 😎
| posted on August 18th, 2013 at 04:04 PM |
Got my 30 year old tyres pulled off...Stripped the paint from my rims.... only to find a pair is from 1967 and the other a 1960 hence the slight blue
colour difference. Then I decided to paint remove from my rear blinds. Put some stickers on the rear of engine and then..... the baby woke up. Then
dreamed of doing more.
1960 Beetle sedan (Bubbles)
nils
Threads: 65
| posted on August 18th, 2013 at 06:38 PM |
Pulled the engine and gearbox out for about the 20th time in the last month
AndrewB
Threads: 19
Mood: arghhbjfhbejrhfebf
| posted on August 18th, 2013 at 10:17 PM |
Dropped a widened steel front fender on the rear fender of my 58 that was in the final stages of paint prep
benny_acko
Threads: 32
| posted on August 18th, 2013 at 10:54 PM |
Checked gaps on spark plugs. Then pushed,pulled and sweated to get the car turned around ready for a tow to the mechanics in 2 weeks to get running
and brakes serviced..
1967 VW Beetle Deluxe
Sides
A.k.a.: Dave Sidery
| posted on August 19th, 2013 at 08:43 AM |
So long as yesterday counts... I fanged hell out of it around Leyburn, smashing my previous PB by 1.3 seconds.
My toys
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on August 19th, 2013 at 02:01 PM |
Nice Sides!
tar76
Threads: 95
| posted on August 19th, 2013 at 02:51 PM |
Gave them a start and check over. Been on hols for a week so needed to blow the cob webs off
"Obey your Dreams"!
62 Std beetle.
65 11 wnd Split "The Cross".
6? coming very soon!!!!
ancientbugger
Threads: 191
| posted on August 21st, 2013 at 09:36 AM |
I found a new way of stopping a VW from going Been playing with the
buggy and noticed that the accelerator wasn't moving much (buggy hasn't really been used a great deal recently) . Took off the cable and moved the
pedal - fine, pulled on the cable and it was fighting all the way out of the tube so I decided to do a pull through using a piece of stainless steel
wire with an oil soaked rag (only a little rag!) connected to the end. Well this rag is now solidly fixed at about the middle of the tube I do amaze myself that now after 40 years of playing with them I can still come
up with something new.
vlad01
Mood: Side ways
| posted on August 21st, 2013 at 11:00 AM |
| Quote: | Originally
posted by ancientbugger
LOL good luck to you. I would hate to be in that situation.
try a longsolid but still flexible rod and try ramming it out.
71 notchback,
ancientbugger
Threads: 191
| posted on August 21st, 2013 at 12:49 PM |
Tried it And I'm going to continue to try it. Possibly my posts for
the next few days will be the same..... Poking flexible rod into accelerator tube!
hellbugged
A.k.a.: Daimo Pell
| posted on August 21st, 2013 at 01:17 PM |
Curtain wire and a drill?
vlad01
Mood: Side ways
| posted on August 21st, 2013 at 03:16 PM |
hydrochloric acid?
is it cotton?
71 notchback,
matberry
| posted on August 21st, 2013 at 03:20 PM |
I use an old clutch cable and a drill
sander288
"Bolt-on Master"
Threads: 183
| posted on August 21st, 2013 at 04:29 PM |
moved it into the garage instead of backyard! Just assumed it wouldn't go up the driveway because my mates land cruiser scrapes.... nope just a
little touch and up!
simohagz
Threads: 6
| posted on August 21st, 2013 at 05:37 PM |
Oil and gasket change....black sludge for GTX...good trade!
bug68m
Threads: 15
| posted on August 21st, 2013 at 07:09 PM |
try blowing it out with some compressed air should work
ancientbugger
Threads: 191
| posted on August 21st, 2013 at 07:39 PM |
I tried a multi-strand cable and a drill and found a new way to make myself bleed from several places I don't think I'm game enough to try acid with my sort of luck, I've got some different thicknesses of
wire now and I'm going to just persevere. Maybe if and when I'm feeling a bit more brave I'll even attach a drill.
ancientbugger
Threads: 191
| posted on August 21st, 2013 at 07:40 PM |
Compressed air might be fun
Ampdub
Threads: 44
| posted on August 21st, 2013 at 10:30 PM |
| Quote: | Originally
Ahhh, still laughing from this, only cause i know the pain
Ampdub
Threads: 44
| posted on August 21st, 2013 at 10:32 PM |
stripped the inside roof and sanded half for rust convert. checked the back seat and middle i have will fit.
DubbyDo
A.k.a.: Dave
Threads: 45
Mood: need more compreshunn!
| posted on August 21st, 2013 at 10:43 PM |
Plumbed in and wired up lectric fuel pump and refitted fuel tank, now it's just the arse end to get back together then it's croooooze time
beetle_nut
Threads: 55
Mood: rollin low n rollin slow.65 notch back and 59 beetle
| posted on August 23rd, 2013 at 07:00 PM |
Started to put my motor back in after a rebuild.
And makeing some lower brackets for my type 1 beam conversion beam.
