| [ Total Views: 10810 | Total Replies: 400 | Thread Id: 18264 ] |
| Pages: 1 .. 8 9 10 11 12 .. 14 |
t2
stop taking life so serious
Threads: 206
Mood: tired
| posted on December 22nd, 2004 at 08:36 PM |
i think this is on a straight axle , check twoguns dc hes selling it on straight axle and 14" rims i think they are14"
| Error |
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
| posted on December 28th, 2004 at 07:45 PM |
my rims are 15x7 on the back and 15x6 on the front. no 14s htey are for pussies....
Simply Cruzin'...
twoguns
simply aircooled
Threads: 226
| posted on December 28th, 2004 at 07:48 PM |
oh and my bus is running 17x 7.5s
Simply Cruzin'...
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:36 PM |
Updated today. Finished the drivers side section of body, as in back to metal then etch.
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:44 PM |
Found a few hidden bad points, but nothing major. Under the proposed sill repair panel line is all bog.. And I mean heaps. I chipped off a huge
chuck.. there is next to nothing left there as far as metal. This thing is not going to have ANY bog in it if I can help it. Dents will be pulled, and
if filler is needed, and I am going to give lead wipes a go..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:46 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:51 PM |
People that have been reading this thread for a while will recall the jig I was making to get the bus mobile, when I didn't have a front or rear end
in it.
That was the second achievement for the day. Things were welded up and tested..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:55 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:57 PM |
The hardest part was getting the jig in and under..
Had sikdub and I scratching our heads.. he he
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 09:59 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:01 PM |
Sliding jack stands to be placed under the chassis rails..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:04 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:06 PM |
With the bus transferred onto the jig, we were ready to move it. Centralised.
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:08 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:10 PM |
Side on..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:11 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:12 PM |
180 degrees.. done.
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:14 PM |
The jig held up pretty well, but there is a few things.
The wheels will need to be upgraded, and once in the right spot I might tack weld the sliders on for security and strength.
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:17 PM |
Now to start on this side..
It is just like pulling it out of the bush on the first day.. It is like we hadn't done anything.. So raw and untouched! Was wierd!
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:20 PM |
The inspirational artistic pic..
Whack the 16" barny rims on, and some big emblem caps..
With the help of some bricks.. it looks the goods..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:22 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 29th, 2004 at 10:24 PM |
Last one. Looking forward to hooking into the nose tomorrow and just finding out EXACTLY what I am dealing with..
Peace out.
[Edited on 29-12-2004 by BenettonVW]
| Error |
sikdub
Mood: svweet
| posted on December 29th, 2004 at 10:40 PM |
david
Threads: 157
Mood: amicable
good work jim
like your dolly ,if you want some real good wheels i can get some real strong ones ,there are a stack of all steel ones down at the scrap yard near my
place cheap ,why did you not go a rotisserie
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 30th, 2004 at 07:38 AM |
Thanks David, might be an option. The rotisserie idea isn't really me, however I am considering making this one extendable, so you can roll it onto
its side, but not upside down. Therefore, depending on which way the bus is facing, you have better access to the roof or floor.
The initial idea wasn't big. I just wanted to be able to move it, and roll it around if I needed to. That bus is a bit heavier than I thought...
:blush
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 30th, 2004 at 08:43 PM |
I'm guessing by now you know the process, so conserve your time and our bandwidth, I will show you major changes instead of every little step.
Nose was today, as well as passenger door. We also took the windscreens out..
Kate, my fiancee, managed to capture the moment..
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 30th, 2004 at 08:46 PM |
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
[Edited on 30-12-2004 by BenettonVW]
| Error |
BenettonVW
AVD Forum Founder
Threads: 185
| posted on December 30th, 2004 at 08:51 PM |
Whilst it looks like I have hit it with a grinding disc, I can assure you it is a lot smoother than that. Not much warping either, however if it start
to get hot or buckle, move areas of course.
I could get used to this time-off thing..
| Error |
ClassicVW(pacific)
Banned
Threads: 141
| posted on December 30th, 2004 at 08:53 PM |
