| [ Total Views: 43960 | Total Replies: 578 | Thread Id: 89664 ] |
| Pages: 1 .. 8 9 10 11 12 .. 20 |
1916baja
Threads: 176
| posted on May 9th, 2012 at 08:37 PM |
I already have a bugpack one but i doubt it will be sufficiant....
| Error |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on May 9th, 2012 at 08:38 PM |
Being dry sump I didnt get oil from the rockers covers, more so from the breather on the oil tank and crank case. The new engine want have breathers
on any rocker covers just the case
ian.mezz
Threads: 280
| posted on May 9th, 2012 at 08:44 PM |
thats what we use.
humpty
Threads: 139
Mood: Totally boosted!
| posted on May 9th, 2012 at 09:25 PM |
| Quote: | Originally
posted by typethreeking
Always wanted to have a close look at a dry-sump setup.... A buddy has just gone that road with his sprint Dub....
Anyway.... I had one of those cast ali breathers.... Found it wasn't up to the task for my engine.... It never over flowed or anything, it just never
sealed properly around the cover..... And there was no blow-by issues with my engine, but there seemed to be a good amount of crankcase breathing and
huffing going on, so kinda think it's more down to higher rpm that my engine produces.... Only a small engine (1776), but rev's like a mad thing....
7500rpm which is a lot for a turbo engine.... I'd run that one you have and see how it goes.... Easy to update if it's not up to the task.
Stanley
Threads: 270
| posted on May 9th, 2012 at 09:47 PM |
My last run sucked/blew the gaskets in due to lack of breathing. This is my priority for the Turbo now I have better rocker covers.
Latest craze I believe is big arse breather on the case. You'll find current one is inadequate but this also depends on boost. Go big early.
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 10th, 2012 at 05:51 PM |
Your right Stanley, that's why I put a 1 1/4 breather off the case, stopped oil leaks with bigger breathers
1916baja
Threads: 176
| posted on May 10th, 2012 at 05:54 PM |
I do remember the last motor i had in my baja leaked alot until i put a breather system on it... stopped everything.
matberry
| posted on May 10th, 2012 at 06:56 PM |
I had 4 x 1" breathers on Joint Effort , it saw 8500 rpm without any oil issues. N/A 2165cc
ian.mezz
Threads: 280
| posted on May 10th, 2012 at 07:55 PM |
use a total seal 2nd ring.
you use a turbo so you don't have to rev your motor as much
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on May 10th, 2012 at 08:06 PM |
I'm still hoping to see 8000rpm with my new turbo set up in the drag car, just depends on set up and what power your chasing
Stanley
Threads: 270
| posted on May 10th, 2012 at 08:12 PM |
Hey Mick I like the exhaust on your car now.....
modnrod
Threads: 50
Mood: Old School Volksies!
| posted on May 10th, 2012 at 08:15 PM |
http://www.et-performance.com/turbo.html
Maybe give serious thought to one of these set-ups. I used them on KTM big singles and high-rev Ducati's, both of which oil-mist up badly, a little
1/2" Krankvent fixed it straight away. They work well.
The Holley650 seems a bit big to me. You could tune it in OK for the track, but a 465 Vac/Sec with the secondaries boost referenced (vacuum diaphragm
reversed on the actuation arm) would give much snappier response, even a 600Vac/Sec. Each to their own, some prefer mech sec, but the vac/sec set-up
can provide natural progressive fuelling that is boost referenced.
Carter pumps are 5psi internally regulated, and are 5psi even at over 100GPH (the black elec ones are the go) through 3/8" lines, no return, no boost
reference (dead-head), the duck's guts for Holley streeters up to 300rwhp, no annual rebuilds needed (and no, they're not painted
blue..........).
Just a few more points to consider!
1916baja
Threads: 176
| posted on May 10th, 2012 at 08:46 PM |
| Quote: | Originally
posted by Stanley
I like the exhaust thats on my car now too.... Shame i cant stick a
turbo on it! If i end up going ahead with all this it will be for sale once the turbo system is all up and running.... gotta pay for it somehow! It
would fit your N/A 1915 combo nicely stanley!
Stanley
Threads: 270
| posted on May 10th, 2012 at 08:55 PM |
You're a mind reader Mick....
| Quote: | Originally
posted by 1916baja
| Quote: | Originally
posted by Stanley
1916baja
Threads: 176
| posted on May 10th, 2012 at 08:59 PM |
Funny though, i'm rather partial to the exhaust on frankenstien... we should just swap! it even already has a turbo attatched!
Stanley
Threads: 270
| posted on May 10th, 2012 at 09:03 PM |
Doesn't the setup already have an exhaust?
1916baja
Threads: 176
| posted on May 10th, 2012 at 09:14 PM |
Yeah its got it.... Ill have a good look at the setup tomorrow, Im going out to daves place. I was joking regarding the swap.... Implying we swap your
complete turbo system for my merged headers....
Stanley
Threads: 270
| posted on May 11th, 2012 at 07:41 PM |
| Quote: | Originally
posted by 1916baja
Tell him he's dreaming....
1916baja
Threads: 176
| posted on May 11th, 2012 at 08:21 PM |
this is it... it seems more and more like a good idea the more i look into it!
| Error |
| Error |
Stanley
Threads: 270
| posted on May 11th, 2012 at 08:47 PM |
Do it Mick you won't be disapointed.
1916baja
Threads: 176
| posted on May 11th, 2012 at 08:53 PM |
Dave is taking the turbo down to Aarons tomorrow so he can check there is nothing wrong with it....
essex
| posted on May 11th, 2012 at 09:17 PM |
"this is it... it seems more and more like a good idea the more i look into it! "
your right, this is a good idea...
ian.mezz
Threads: 280
| posted on May 11th, 2012 at 09:29 PM |
yeah do it . rose just has a under boot street combo.
more power  you can feel it .
this is rose passin CT who did a 14.8
http://www.youtube.com/watch?v=Mfb4zeSL3XI&list=UUnJDKoUrWHlJAmbPeU_QHiw&...
http://www.youtube.com/watch?v=88GI27HMoAE&feature=autoplay&list=UUnJ...
ours is so nice to drive.
http://www.youtube.com/watch?v=iAJqbhKU6v8&feature=autoplay&list=UUnJ...
humpty
Threads: 139
| posted on May 11th, 2012 at 10:40 PM |
Took mine a for a spin the other night..... Damn its fun!..... Do it!!!!!
dangerous
Mood: 591
| posted on May 12th, 2012 at 05:18 AM |
Hey Mick, sounds like a great idea.
Even though I am a N/A fan, you cant beat the value of a boosted engine.
Hell, I ran boost for 11 years, so I know it can be fun!!
I would just de-compress your engine a little, and add some good dual springs.
Like anything, there are always more , or better ways to do things,
but for a budget build, your cam will work fine.
If you had some extra money burning a hole in your pocket,
I would consider a larger exhaust valve though.
| Quote: | Originally
posted by westi
That's mad Alan.
matberry
| posted on May 12th, 2012 at 07:41 AM |
Don't forget a scatter shield for your flywheel will need to be added to keeo the ANDRA officials happy.
1916baja
Threads: 176
| posted on May 12th, 2012 at 01:45 PM |
| Quote: | Originally
posted by dangerous
Thanks Dave, good to hear you think its a good idea! Dual springs were on the cards regardless... once we start setting it all up we'll be in contact
regarding compression and all. I think we'll set it up with the heads as they are for now and see how it goes, maybe down the track we might look
into bigger valves... i certainly dont have extra money burning holes in my pockets! Just out of curiosity though, what would it cost??
I also love N/A but for the money i couldn't in my lifetime afford to get real power from a N/A motor i dont think. I mean really... whats better
than the sound of a tough N/A motor ripping off a skid on the limiter???
essex
| posted on May 12th, 2012 at 03:20 PM |
anyone have any scatter shield pics?
ian.mezz
Threads: 280
| posted on May 12th, 2012 at 04:26 PM |
the best thing about a turbo is the little screw on the boost control. our goes from about 7 to 18 , not sure if we even going to try 18
humpty
Threads: 139
| posted on May 12th, 2012 at 04:44 PM |
| Quote: | Originally
posted by essex
http://www.cal-look.com/forum/vw-drag-racing/flywheel-scattershield/?PHPSESSI...
