[ Total Views: 119136 | Total Replies: 437 | Thread Id: 67418 ]
 Pages:  1  ..  9  10  11  12  13  ..  15
Author: Subject:  Simon's 1915cc Beetle
Membertrickysimon
A.k.a.: Simon Azzopardi
Threads: 43
posted on November 8th, 2009 at 06:44 PM
Thanks Ian.
I'll give that a go when I can bare to look at the engine again :rolleyes:
posted on November 8th, 2009 at 07:09 PM
Try swapping the idle jet with another cylinder and see if the problem moves.
I have seen new jets that didnt measure what was stamped
Membertrickysimon
Threads: 43
posted on November 9th, 2009 at 02:53 PM
Barry- Problem doesnt follow the idle jet. Stay with number 2.
Ian- Pulling off number 1 plug seems to make the only drop :crazy::grind::crazy::grind:
Who wants a free boat anchor? :grind:
Membercolonel mustard
Threads: 51
posted on November 9th, 2009 at 02:59 PM
you said free! stupid questions but are your tappets set right?
Membertrickysimon
Threads: 43
posted on November 9th, 2009 at 03:13 PM
They were set before I got the engine. As I said, engine has been run and broken in and all tht shizz.
Was planning on re-doing them after I had put 50kms or so on it. So prob in like 10 years :rolleyes:
posted on November 9th, 2009 at 06:36 PM
if your really feeling energetic try swapping carbs from side to side see if the problem stays with the carb
Membertrickysimon
Threads: 43
posted on November 9th, 2009 at 06:48 PM
Well using Aircooled "hose syncroniser trick", I got all cylinders pretty dam close.
Gunna put mixture screw problem in the "who cares" basket for now.
I've heard idle needs to come up a tad?
http://s260.photobucket.com/albums/ii19/trickysimon/?action=view&current=MOV007_xvid_001.flv
Member71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on November 9th, 2009 at 06:57 PM
I think the problem might be that its in your car not mine jjks, hope you get it sorted out.
Membertrickysimon
Threads: 43
posted on November 9th, 2009 at 07:09 PM
Haha well if you here a few hours earlier, I would have given you the car.
Was a bit fed up with it :lol:
AKA Josh
Threads: 108
posted on November 9th, 2009 at 07:12 PM
Yeah i get like that, storm into the house sit at the computer and read something to cheer me up while mum is going calm down itll be right. Get like that a fair bit, but not lately its been running well lately knock on wood,.
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on November 9th, 2009 at 07:26 PM
sell those carbs and stop wasting time and money on them....................buy some good Kadrons or 40 idf's
Membertrickysimon
Threads: 43
posted on November 9th, 2009 at 07:30 PM
Why? I'm pretty close arn't I?
Don't wanna have to start all over again... :crazy:
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 10:40 AM
How do you tell if your new fuel pump is leaking? :rolleyes:
Fuel levels in both carbys seem fine but my oil level is going up..
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 10:56 AM
Hmm just read on thesamba that new fuel pumps are usually high pressure causeing the engine to keep sucking fuel
after the engine has stopped. Could a fuel pressure regulator be on the cards?
Grease in fuel pump hasn't been washed away if that helps..
Membercesiumfrog
Threads: 7
posted on November 12th, 2009 at 11:03 AM
simon...don't get paranoid...you did put a couple gaskets under th pump? and correct rod length?
people have been using standard type pump with modded engines/carbies forever without the need for reg.
what else is happening?
phil
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 11:11 AM
Well the oil is pretty watery and clear....hard to see what the level is up to. Its definetly going up though.
Did put gaskets under fuel pum and checked rod length. Are you at work?
Membercesiumfrog
Threads: 7
posted on November 12th, 2009 at 11:32 AM
yeah at work.
does it feel like oil....smell like petrol? hot weather makes oil runnier.
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 11:33 AM
Hmm cant really comment on the smell..off sick with the flu...blocked nose :lol:
Threads: 51
posted on November 12th, 2009 at 11:37 AM
welll...... it could be fuel. Mine does that if i park it on a hill, the needle and seat just leaks heaps of fuel into the case. one night i did it and hydro locked the engine... not good.
If your checking it when its cold and its well above the line on the dipstick, you have issues! drop it and change the oil. its not worth blowing it apart for the $$'s of new oil. also, if you have too much oil, it will cause your engine to miss... a lot!!!!...
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 02:40 PM
Yeh dad reckons I'm just being paranoid as well. Its wierd, after I started it up and then let it sit for few hours the oil level is back to the right level so maybe I'm just going crazy :dork:
On a positive note: Finally got thottle cable hooked up and working so checklist for taking it for a drive anyone?!:cool:
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 07:04 PM
WOOOOO!!!
Pulls like a cut cat!
Ratios are awesome thanks Dave! :tu:
:D:D:D:spin:
AKA Josh
Threads: 108
posted on November 12th, 2009 at 07:32 PM
Does it spin?
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 07:44 PM
Of course not :cool:
http://s260.photobucket.com/albums/ii19/trickysimon/?action=view&current=MOV00A_xvid_002.flv
posted on November 12th, 2009 at 08:00 PM
well???
Why???
posted on November 12th, 2009 at 08:01 PM
WTF!!
There is more videos of someones foot than the car! :crazy:
AKA Josh
Threads: 108
posted on November 12th, 2009 at 08:20 PM
Its should, maybe youll have to get a system rigged up that squirts a bit of water in front of the tyres then spin it,
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 08:28 PM
Excuse the embarresing parents :lol:
They pay the rent...
http://s260.photobucket.com/albums/ii19/trickysimon/?action=view&current=MOV008_xvid_002.flv
http://s260.photobucket.com/albums/ii19/trickysimon/?action=view&current=MOV00C_xvid_002.flv
Memberian.mezz
Threads: 280
posted on November 12th, 2009 at 08:33 PM
Originally posted by trickysimon
WOOOOO!!!
:D:D:D:spin:
that sounds like it wouldn't pull the skin off of a rice pudding:crazy::lol::crazy::lol::crazy: just joking
its sounds a bit tappety or is that the exhaust???
yeah there goes his licence :lol::no::lol:
:lol::crazy::lol::crazy::lol:
Membertrickysimon
Threads: 43
posted on November 12th, 2009 at 08:36 PM
I'll prob check the tappets and drop the oil just for the hell of it now. On a bit of an adreneline high atm :lol:
Memberian.mezz
Threads: 280
posted on November 12th, 2009 at 08:39 PM
yeah don't let all that power go to your head.:lol:
[ Queries: 40 ] [ PHP: 8.7% - SQL: 91.3% ]
