| [ Total Views: 249891 | Total Replies: 672 | Thread Id: 68967 ] |
| Pages: 1 .. 9 10 11 12 13 .. 23 |
20bkombi
Threads: 26
| posted on February 2nd, 2011 at 08:15 PM |
Whats the latest Andrew?
Engine getting closer?
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
Stanley
Threads: 270
| posted on February 3rd, 2011 at 06:40 AM |
Actually it is Aaron.....I moved it from the floor back to the bench so it's physically closer to the car now...
On a serious note things are moving. Went to see DB last weekend and picked up the barrels and push rods which he shortened about 7mm.
As the Nissan pistons have an 11cc dish Dave also flycut the heads to compensate. Excellent work on all accounts.
Now everything else needs to be narrowed 7mm per side. Intake, exhaust, tinware and mod to the fan housing. Rather than shorten the intake and exhaust
i'm considering making a new intake and getting a header system made. Never been entirely happy with the way mine looks. It doesn't need to fit
under the deck lid of a streeter anymore so looking at something like A J Sims.
Also fitting a half cage.
| Error |
Stanley
Threads: 270
| posted on April 3rd, 2011 at 08:06 PM |
new pistons
As the pistons are 8mm shorter than a std volksy piston DB shortened the barrels 8mm along with the pushrods.
DB also flycut the heads to allow for the 11cc dish in the piston.
The intake, exhaust and tinware also had to be modified to allow for the shorter barrels
| Error |
| Error |
humpty
Threads: 139
Mood: Totally boosted!
| posted on April 4th, 2011 at 01:03 AM |
Slipper skirts Forgies..... Mmmmmm.... More boost in your future Andrew?.... Have you decided on your exhaust system yet?
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on May 24th, 2011 at 11:07 PM |
Hey Stanley , whats the latest news , have started rollcage yet . How about bringing your car along to dyno mania day (put on display ) ?
Stanley
Threads: 270
| posted on May 25th, 2011 at 07:33 PM |
Cage will be finished this weekend.
Had to make a new seat mount to get side intrusion to fit. Something i've wanted to do for a while.
Engine is together after a small unforseen problem with the Nissan pistons. While installing the last B&P noticed it wouldn't fit in the case.
Other 3 were ok.
After thinking the rod was bent investigation revealed that the gap in the piston for the small end, being smaller than a std volksy piston (thought
2mm clearance was ok), was enough to cause this. Long story short all rods out and down to DBs to be narrowed a bit. All good now.
Next job is to make a new turbo exhaust. Then some Jenny Craig treatment to make up for the extra weight.
I'll be coming along to dyno day but i'll leave Frankenstein at home. It's not that much to look at
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on May 25th, 2011 at 09:03 PM |
You or the car LOL
Sounds like you've been a busy boy mate. Look forward to catching up at Dyno Day
SuperOwen
Threads: 67
| posted on May 25th, 2011 at 10:34 PM |
Trying anything new with the exhaust or just narrower?
Stanley
Threads: 270
| posted on May 26th, 2011 at 06:43 AM |
Narrower and smaller diameter from 1 5/8" down to 1 1/2".
1 5/8" is a tad too big for my displacement.
I was talking the car Brendan, however might do a soup diet the week before Warwick....every little bit helps...
Stanley
Threads: 270
| posted on June 26th, 2011 at 05:53 PM |
Well considering Warwick isn't far away and is the talk of the town thought i'd show those interested what's been happening to Frankenstein.
The engine is together wirh the nissan pistons and i'm just waiting for some exhaust bits to start welding that together.
In the meantime i've fitted a n expertly bent cage from Westi and his boys which i've since welded in and as i've never been really comfortable
with the poly seat i've fitted a Kirkey seat.
There was also some die grinder and hole saw action to counter the extra weight of the cage. More on that to come.
| Error |
| Error |
| Error |
westi
what the
Threads: 28
Mood: not blue, pink
| posted on June 26th, 2011 at 06:50 PM |
Side intrusion is alittle high. For my liking.
But over all mate coming along nicely.
down sharon.
OZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
| posted on June 26th, 2011 at 07:01 PM |
Looking good Andrew , what are you doing with that old exhaust as i may be interested for my Rat Racer
Stanley
Threads: 270
| posted on June 26th, 2011 at 07:50 PM |
| Quote: | Originally
posted by westi
Yeh mate your're probably right but it was the only way I could get it to fit around the old seat. Tried to get it to intersect with the taxi bar
like you suggested but wouldn't go with the seat. The rest fitted like a glove though....top work mate
Stanley
Threads: 270
| posted on June 26th, 2011 at 08:00 PM |
| Quote: | Originally
posted by OZ Towdster
not sure yet, but I don't think i'll use it again
dejan
Threads: 2
| posted on July 5th, 2011 at 04:12 AM |
@Stanley will mount the Nissan pistons , failed to come to this prekt to propose to take from Mitsubishi Lancer Evolution 10 pistons these very liht
pistons and have pitting of 8mm in the very forefront.
I will go to such piston.
20bkombi
Threads: 26
| posted on July 5th, 2011 at 07:46 PM |
Hi stanley, is the cage molly or steel? looking good man!!
Nice speed holes
Ph 0402 233 027
Stanley
Threads: 270
| posted on July 6th, 2011 at 06:11 PM |
thanks Aaron....cage is moly
westi
what the
Threads: 28
| posted on July 7th, 2011 at 10:58 PM |
were's the new header's mate.no need for sleep.
down sharon.
Stanley
Threads: 270
| posted on July 9th, 2011 at 05:49 PM |
75% done.
Hopefully done tomorrow.
humpty
Threads: 139
| posted on July 9th, 2011 at 06:30 PM |
| Quote: | Originally
posted by Stanley
75% done.
Looking forward to seeing the finished result!
Stanley
Threads: 270
| posted on July 10th, 2011 at 06:43 PM |
Done. Just need to finish welding.
Tomorrows job
| Error |
| Error |
humpty
Threads: 139
| posted on July 10th, 2011 at 08:17 PM |
Good work there.... It looks like your gonna be cutting up your apron a little to make it all fit though..... But I like how you've allowed for the
visual access to TDC.... Sure wish I did that with the POS when I built my header....
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on July 10th, 2011 at 09:59 PM |
Nice work Andrew - hoping to get a run or two in before Warwick?
essex
| posted on July 11th, 2011 at 06:30 PM |
Looks really neat job, nice & centred,
What fuel do you plan on using?l
Stanley
Threads: 270
| posted on July 11th, 2011 at 07:23 PM |
As much as i'd like to I'll wait for Warwick. I'd hate to break it before Warwick plus I have data from last year so will know where I am for the
1/4. Mind you it's put on a bit of weight.
I like symmetry so centred is good good and is easy. What you do for one side you do for the other. Just add 40mm for the offset and the bonus is you
can see TDC.
I've been slack and haven't run it since last Warwick. I think it's proved for a 1641 it's quick but i'm over replacing pistons after a race
meet.
Aim is to make it reliable and get it down the 1/4 without imploding.
| posted on July 12th, 2011 at 11:32 AM |
Nice theory Stanley and I will have my fingers crossed franky behaves and I get to see more than 1 run in anger!!
Stanley
Threads: 270
| posted on July 28th, 2011 at 12:14 PM |
almost there.....engine in and have cranked it over and have oil pressure. Just need to hook up new MSD and light the fire.
| Error |
| Error |
| posted on July 28th, 2011 at 01:34 PM |
Starting to look real serious mate!! Good work!!
Stanley
Threads: 270
| posted on July 31st, 2011 at 06:25 PM |
Well after some dramas which was thought to be an MSD problem but turned out to be a dud timing light Frankenstein fired up first go.
Just need to tidy up a few little things like accelerator cable and reset one spring plate and all is go for Warwick.
Changes since last year
Fitted a half cage....thanks again Westi
New MSD....old one shit itself just before Warwick last year so ran with the trusty 009
new Kirkey seat
new 1 1/2 exhaust system. old one was a bit large for a 1641 plus needed to be narrowed to fit engine.
fitted forged Nissan 87mm SR20 pistons. This required shortening the barrels and push rods, narrowing small end of con rods, flycutting heads to
account for piston dish (thanks to DB for mall the machining), trimming the tinware by 8mm a side and notching out the fan housing to clear the intake
castings. Why the hell would you do that I here everyone asking....maybe i'll leave that for after Warwick.
| posted on August 1st, 2011 at 10:54 AM |
Lookin forward to see some results mate!! Kudos for sticking with the project too!! Many others would have given up by now!!
