| [ Total Views: 124877 | Total Replies: 1116 | Thread Id: 85894 ] |
| Pages: 1 .. 9 10 11 12 13 .. 38 |
ian.mezz
Threads: 280
| posted on November 29th, 2012 at 11:17 AM |
reub incar.?
http://www.youtube.com/watch?v=_1Tom86YA-g&feature=BFa&list=ULTHgskvI...
some noise in car from something ??????
1303Steve
| posted on November 29th, 2012 at 02:20 PM |
Ruebs noise developed over a period of time, it was quiet at first.
ricola
Threads: 9
| posted on November 30th, 2012 at 04:49 AM |
| Quote: | Originally
posted by 1303Steve
To get the gearbox out again, I had to remove the rear bumper, rear apron and partially remove the rear mudguards, not something I want to be doing
too often
I've had to do that way too often recently too!
Made a start on my crosspipe...
1303Steve
| posted on November 30th, 2012 at 07:18 AM |
Hi Rich
That looks good. I've been meaning to ask if you have experienced any gearbox noises form your G50?
debiasi4
Threads: 51
| posted on November 30th, 2012 at 08:36 AM |
Hi Steve. Your car looks great I'm building a suby powered early notch for my wife. These guys have some great air conditioning bits. May help with
your setup
Cheers Adam
ricola
Threads: 9
| posted on November 30th, 2012 at 08:38 AM |
I do get some bearing type noise at low revs when I'm driving off but it disappears with a few revs and higher gears. From what I found 'they all do
that' to a greater or lesser extent, my box was low mileage too.. It did get better with an oil change, with the LSD install it had new diff bearings
too.
psimitar
Threads: 148
| posted on November 30th, 2012 at 11:30 PM |
| Quote: | Originally
posted by 1303Steve
Thanks for that. Actually after driving the car more at night its only the high beam that bothers me, what size resistor would I need? Its a straight
12 volt feed from high beam.
I few goodies arrived last week.
A Griimspeed cross pipe, good for 5 HP and a AVO solid boost control actuator.
Surprised the LED ain't blown yet. normally LED is 30mA max forward current @ 3.6v so hang on whilst I just do the maths. Yup 300ohms and use a 1
Watt resistor for heat handling. Done that from memory and rough common variables for high output LEDs so should be OK.
madness is in the eye of the beholder
Joel
| posted on December 1st, 2012 at 08:43 AM |
The LED warning lights like that are designed to run at 12 volts so they can just plug and play with built in resistors, same as the ones you fit for
parkers, brake lights, indicators etc.
1303Steve
| posted on December 1st, 2012 at 05:34 PM |
Thanks for the input. Once I get the gearbox issue sorted I will look in to air con.
Adam I would love to see a build thread on the notch, Type 3s are just asking for a conversion
Hopefully my gearbox noise are not too expensive, if not I might treat the box to a Quaife, ZFs go for $3000+ down here, a Quaife is about $1800.
As Joel said its a LED module with the warning lights with built in resistors, I just want to turn down the high beam one, its way too bright and as
you usually only use high beam on dark roads it makes it worse.
ricola
Threads: 9
| posted on December 2nd, 2012 at 12:52 AM |
Hi Steve,
Do you have any oil in the intake? Thinking out my breather options atm...
Rich
1303Steve
| posted on December 2nd, 2012 at 06:16 AM |
Hi Rich
Its as clean as a whistle, the breather seems to be working OK.
psimitar
Threads: 148
| posted on December 2nd, 2012 at 10:32 PM |
| Quote: | Originally
posted by 1303Steve
Hmm, maybe run an extra 150ohm inline with the high beam dash light then or buy a small potentiometer so you can turn the thing down till you are
happy with the light level.
1303Steve
| posted on December 11th, 2012 at 03:32 PM |
Motor and gearbox are out.
Michael Newton warned me before he pulled the G50 apart that they are a noisy transmission from the factory and Porsche went to great lengths to drop
the noise levels, revised engine & trans mounts, dual mass flywheels etc.
He cant find anything wrong with it, he said that its in very good condition with none of the usual wear areas. So it appears that my noises are cause
by my mounting method. I have a stock G50 mount at the front of the transmission, two Kombi bellhousing mounts like a top mounted Berg style mount and
stock WRX mounts under the motor.
So I ordered a Quaife diff for it and he will replace a few bearings just to be sure and its better to setup a new diff with new side carrier
bearings.
Its in good company at the shop as its full of Porsche Cup cars.
| Error |
| Error |
| Error |
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on December 11th, 2012 at 04:12 PM |
Hope you have your Porsche wallet with you
psimitar
Threads: 148
| posted on December 11th, 2012 at 08:00 PM |
I hope they're going to give that gearbox case a clean before assembly? It's downright filthy
seagull
Threads: 752
| posted on December 12th, 2012 at 10:37 AM |
This is the set up for a 207 or 257 for the oil vent lines
reub
VWRX is gone...
| posted on December 13th, 2012 at 09:51 AM |
Hi Steve, is your G50 an LSD or open wheeler?
And do you mind me asking where you sourced your Quaife from?
Reub
1303Steve
| posted on December 13th, 2012 at 06:15 PM |
Hi Reub
I bought it from the Australian agent in New Zealand.
This is him and the 1800 number for him works from Australia.
PALMSIDE IMPORTS LTD
Preferred Australian Distributor
287 Hoon Hay Road
Christchurch, New Zealand 8002
Phone: 1800 760198
Fax: 00643 3389050
Email: mail@palmside.co.nz
My diff was open, my G50 is from a base model 88 Carrera.
I've read mixed reviews on Quaifes, they are not much good in a hill climb situation where one wheel is in the air, but for the price compared to a
ZF its cheep and is a much tougher centre.
A ZF is around $3000, the Quaife delivered is $1423
Sides
A.k.a.: Dave Sidery
| posted on December 14th, 2012 at 09:30 AM |
Yeah - I found Palmside were a great mob to deal with
I've had both Quaife and ZF in Jezzi and completely agree with what Steve's said... ZF for a track car while for a mainly street car I'd go the
Quaife every time.
Wait till you drive it first time in the wet with the Quaife Steve.... you'll be amazed at how predictable the handling is still.
My toys
reub
VWRX is gone...
| posted on December 14th, 2012 at 09:34 AM |
Thanks Steve
Reub
seagull
Threads: 752
| posted on December 14th, 2012 at 10:21 PM |
I can hook you up with Chris to fit the diff in Perth Reub
1303Steve
| posted on December 15th, 2012 at 07:15 AM |
I had a Quaife in my yellow 1302, they have no handling vices which cant be said for other LSDs.
Rudi ran one for years in his sports sedan and regularly two wheeled through corners and and says he didn't loose drive.
Oh and I'm adding to the budget surplus, $304.32, bugger
1303Steve
| posted on December 16th, 2012 at 10:09 AM |
| Quote: | Originally
posted by seagull
I ended up using a Grimmspeed oil seperator.
| Error |
1303Steve
| posted on December 18th, 2012 at 03:15 PM |
My Quaife arrived today, pretty quick delivery as I ordered it on the 8th December. I will take it out to Porsche gearbox guy and with bit of luck I
will have it running later in January, so on track to have a run at WSID.
| Error |
1303Steve
| posted on December 20th, 2012 at 01:44 PM |
My AVO solid boost control actuator had a manufacturing defect, when I pointed it out to them, they sent me an upgraded billet unit, great customer
relations.
| Error |
| Error |
SebastienPeek
Threads: 89
| posted on December 20th, 2012 at 02:00 PM |
Now that kind sir, is how some companies win at customer service!
Glad to hear at least someone is being looked after in this day and age, especially with everyone else complaining about customer service.
How long until the gearbox is already to be put back in?
Top work on this car by the way Steve, definitely one of my favourite 1303's.
I absolutely love that whale tail too, that's the one from Hölzl correct?
Craig Torrens
Threads: 347
| posted on December 20th, 2012 at 03:19 PM |
yep, Palmside is great to do business with.....my quaife will be here early Jan
1303Steve
| posted on December 21st, 2012 at 10:57 AM |
H
Thanks Senbastian, glad you like it.
I bought the AVO part through Tunehouse in Sydney, they were great to deal with as well.
I just took the Quaife out to Michel Newman, they are closed for 2 weeks so I should have the box back not long after that and I will get it running
real soon.
1303Steve
| posted on January 18th, 2013 at 09:07 AM |
Still waiting on the transmission to be finished, parts are all there just needs to be assembled.
I replaced my cracked 930 CV boots with some eBay ones, great quality.
Some time ago I read post on another forum by Ricola who is also on this forum about clocking CVs. After a bit of search I found the information on
doing this. You can read more about it here http://www.outfrontmotorsports.com/cv_assembly.htm
| Error |
| Error |
1303Steve
| posted on January 22nd, 2013 at 05:42 PM |
Still waiting for my transmission to be finished off.
I used a plastic windscreen washer bottle as my water to air intercooler reservoir.
It always looked a bit cheap so I bought a aluminium one from eBay and had Westi fit two 3/4 bungs and a two bosses so I could fit a level
indicator.
Excellent work as usual from Brad.
| Error |
| Error |
