[ Total Views: 124878 | Total Replies: 1116 | Thread Id: 85894 ]
 Pages:  1  ..  10  11  12  13  14  ..  38
Author: Subject:  Steves 1303 buildup, found lots of kilowatts
Membervlad01
Mood: Side ways
posted on January 22nd, 2013 at 09:01 PM
very nice welding on that.
71 notchback,
posted on January 24th, 2013 at 08:38 PM
My gearbox is ready to be picked up, turned out to be not as expensive as first quoted.
A few photos, the intercooler tank in place.
I have big feet so I decided to make my own front speaker enclosures using ready made speaker bases.
posted on January 25th, 2013 at 06:16 AM
That was exactly the same as how I had my front speakers installed at one stage.
The pods still got in the way on the drivers side.
give it a try, see if you have the same problem.
posted on January 25th, 2013 at 07:22 PM
Hi Joel
I'm really pressed for speaker space so I will see how it goes, I wanted to keep the speaker base away from the accelerator pedal.
I fitted the gearbox today, motor tomorrow. I'm not sure if I want to drive it this weekend with double demerits.
Membervlad01
Mood: Side ways
posted on January 26th, 2013 at 11:04 AM
other solution is not to have any at all.
that's what I do with all my cars. either stock speakers or none, depends on what its options were from factory.
71 notchback,
posted on January 26th, 2013 at 11:11 AM
the only speaker space on a 1303 is a single speaker grille on the right hand lower edge of the dash.
I do like to listen to the radio and ipod and blue tooth will be handy.
posted on January 28th, 2013 at 07:28 PM
Gearbox and motor are back in, just doing a few odd jobs as the weather is too shity to drive the car in.
The Grimmspeed cross pipe has altered the rexy rumble, more toned it down.
posted on January 28th, 2013 at 07:36 PM
Cant put speakers in a rear parcel shelf??
Or the rear side panels??
posted on January 28th, 2013 at 07:58 PM
Hi Barry
I will put some in the back as well but I haven't made a parcel shelf yet, I want to do one of type that goes upto the bottom of the rear window.
Rear side panels might be easier, how affective are they in rear side panels.
I think this might be Joels car.
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on January 28th, 2013 at 08:12 PM
Not a good sound from the side panels Steve.... And makes getting the back seat up and out a pita!
posted on January 28th, 2013 at 08:18 PM
Hi Damo
Good point.
I mounted my header tank and inter cooler reservoir very high in the engine bay so I will need to make the parcel tray easily removable in case I need to fill either tank on the road.
Membervlad01
Mood: Side ways
posted on January 29th, 2013 at 01:29 PM
have you ever thought about mounting small speakers inside and under the dash corners pointing down to direct sound towards the foot well?
or 2 small speakers side by side in the stock grill so at least you have stereo sound instead of mono.
I would love to set mine up like this but I cringe at the fact there is no place for a radio in a type 3 that doesn't hang like dogs balls.
So I opt for no radio at all :tu:
even those retro sound radios don't look right at all.
71 notchback,
posted on February 2nd, 2013 at 05:11 PM
All my under dash area is taken up with relays and wires.
I had it running toady and drove it for about 15 minutes and then the weather turned bad.
Transmission still has noises but nowhere near as bad as before and it seems to be just one noise now, not a variety of noises. I've decided to keep the extra mountings that I've fitted even if they do transmit noise.
I fitted an extra brake light bulb in tail light housing, just in case and also I've made a move to a more permanent coolant overflow reservoir.
I'm using US style tail light lenses.
posted on February 7th, 2013 at 07:24 AM
Car is running again with the rebuilt transmission, still noisy but now I know I'm not doing any damage.
Booked in for a dyno on the 18th and will also have a knock module fitted to the Autronic SM4 at the same time.
I'm sorting out ride heights now and just having fun driving it. I'm also setting up the waste gate actuator.
posted on February 7th, 2013 at 10:21 AM
Just went out to my test track, the RMS were doing truck inspections there so I had to wait awhile.
I only wanted to setup my low boost pressure or gate pressure which will be my everyday drive around boost pressure, it made 13.9 psi in 2nd gear.
When its on the dyno we will set up the Eboost to make 20 psi when needed.
posted on February 7th, 2013 at 10:55 AM
Good stuff Steve
14lb is nice.....20 better. :)
Memberreub
VWRX is gone...
posted on February 7th, 2013 at 02:52 PM
I still remember vividly experiencing 18lb boost...seemed like endless power, and in third gear equated to 175km/hr... ah the memories.
Really look forward to hearing how it all goes Steve. Might get me cracking on mine again too:tu:
Reub
posted on February 7th, 2013 at 07:19 PM
Its great on 14 psi, cant wait to try 20 psi. Looking forward to running the 1/4 but I'm really looking forward more to doing a few super sprints.
Memberlou0060
Threads: 30
posted on February 11th, 2013 at 08:05 PM
20 psi will be a weapon! can't wait to see it at Wakefield Steve.
1971 karmann ghia Cabrio - Cruising :yes:
1963 beetle Sunroof - gathering dust :fakesniff:
1968 race beetle - twin turbo Subaru - stress relief :smilegrin:
1960 beetle - old school low & slow :smirk:
posted on February 11th, 2013 at 08:49 PM
Hi Lou
Are you coming down for the 1/4 & supersprint?
posted on February 11th, 2013 at 08:56 PM
My son took a couple of cool photos with his phone today
Memberlou0060
Threads: 30
posted on February 11th, 2013 at 09:42 PM
Hi Lou
Hi Steve, not making the 1/4 as we are up to our necks with the shop atm. Definitely will be there for the Nats with what I hope will be a very quick car......
posted on February 12th, 2013 at 07:25 AM
Hi Lou
Have you had anymore seat time in the bug?
I want to go down to Wakefield and have a play around before the event to sort out swaybars etc.
Membervlad01
Mood: Side ways
posted on February 12th, 2013 at 02:05 PM
wicked! looks great.
what is that box ruining the view in the photo? :sniffle:
71 notchback,
MemberSebastienPeek
Threads: 89
posted on February 12th, 2013 at 02:12 PM
That fitment is perfect!
How much did you drop it at the rear? Preferably in minutes if you know.
Also the front?
Curious as to what the wheel specs are and tyres as well.
Looks damn good though Steve, I'd love to build a Subi powered bug one day.
The sold one, '73 VW 1303 - Zelda
The project, '74 VW 1303 - Gretl
posted on February 12th, 2013 at 02:30 PM
the box is my sons car which I spend too much time working on, but love driving.
I have 944 adjustable spring plates so I don't know degrees & minutes, I just make a mark on the spring plate with a marking pen and keep moving around the base point until I'm happy.
posted on February 12th, 2013 at 03:23 PM
I took the bug over to Westside today for a little bit of exhaust work.
The O2 sensor was in an awkward place, Brad told me he had 90 degree fittings for O2 sensors, so I fitted one.
Paul who works at Westside did a great job fitting an extra mount to the system and making the tailpipe go straight out rather than dumping on the ground.
And a random shot that I took outside Vintage Vee Dub the other day.
posted on February 12th, 2013 at 03:51 PM
I had an 1800 Golf that we cranked up to 23lb boost. It was a real weapon. Luke Pell drove it to Dubs gy the Pub back in the day and it got him addicted to power. When you wound it back, 12 psi felt like a stocker..... :)
Also had a mates baja at 15-17lb WRX. it was fun on the beach, thats for sure.
Get it cranking Steve, you won't look back, except maybe at the cops disapearing in the rear vision mirror. :lol::lol:
I think the biggest problem other than the law, will be the terminal velocity with that G50 box and 20lb of boost....it'll have legs that will just keep on running......Woo Hoo:crazy:
MemberFlintstones
Threads: 69
posted on February 12th, 2013 at 05:24 PM
That shot @ VVDS looks great Steve :tu:
D
posted on February 12th, 2013 at 05:41 PM
Thanks guys.
I'm not sure if I want to try to run it all the way in 5th gear, could get scary, imagine getting the Superbug wobble at 200 kph +.
[ Queries: 40 ] [ PHP: 12.6% - SQL: 87.4% ]
