[ Total Views: 329228 | Total Replies: 1582 | Thread Id: 58055 ]
 Pages:  1  ..  13  14  15  16  17  ..  53
Author: Subject:  What has Dave Been Up To? 29th AUG 2015: 10.66@126.09mph!!
Memberdangerous
Mood: 591
posted on April 7th, 2008 at 05:48 PM
OK, that settles it.
It ws my first choice,
or the front quarter, or the door.
Done deal...now back to going fast.
Originally posted by westi
That's mad Alan.
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on April 11th, 2008 at 05:57 PM
Have we been to dyno yet Dangerous??
Memberdangerous
Mood: 591
posted on April 12th, 2008 at 06:38 AM
not yet!
That's mad Alan.
Member13BVW
Threads: 6
Mood: always chilled
posted on April 13th, 2008 at 01:06 PM
Dave just worked out how to get video from the camera to the internets.
:DHeres a couple from Mini Jam
http://www.youtube.com/watch?v=3fMl9-LhAW4
13BVW 11.80@114mph
Memberdangerous
Mood: 591
posted on April 15th, 2008 at 05:49 PM
Wow, thanks Andrew!
That's mad Alan.
Memberdangerous
Mood: 591
posted on April 15th, 2008 at 06:57 PM
Got it running today in prep for dyno on Thursday.
Man there is a lot of fuel comes out at idle.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_3740.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_3739.jpg
If you look closely you can see the fuel pouring in:
Here is a better view at idle.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_3737.jpg
That's mad Alan.
posted on April 15th, 2008 at 07:06 PM
Man, your hosing in that methanol Dave!
posted on April 16th, 2008 at 09:58 AM
Bout the same job a holley 4 barrell does ?? Jam tin with 4 holes cut in it and 1/2 fuel ine LOL
Looks good mate. Can't wait for the results. Who is doing the dyno for you?
posted on April 16th, 2008 at 09:27 PM
Big day tomorrow hey Dave. All ready?
MemberBoostn
Threads: 28
posted on April 17th, 2008 at 01:07 PM
Looking good Dave,
Have you gone for one per port or two staged, primary down low and secondary up top would be ideal.
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
MemberStanley
Threads: 270
posted on April 17th, 2008 at 03:43 PM
How'd the dyno go?
Membermactaylor
Mood: even my dog is german
posted on April 17th, 2008 at 06:14 PM
yeah hurry up wana know all the details as long as its not hurt!!!!
EVERLAST CONCRETE TANKS
1800 552 123
Memberdangerous
Mood: 591
posted on April 17th, 2008 at 07:14 PM
OK, I am home.
All is OK, and details soon.
No Huge gains but some very interesting info.
started with about 220 and finished with 225......@8000!!
That's mad Alan.
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on April 17th, 2008 at 07:28 PM
Peak?!???
FUCH your early!
http://www.noh2o.org/
posted on April 17th, 2008 at 08:01 PM
AT 8000 !!!!!
That means you are going to rev it harder ???
Membercolin
Threads: 82
posted on April 17th, 2008 at 08:11 PM
Well done Dave 225hp is a great result. I bet hearing 8000rpm from a vw motor was just awesome.
Cheers Col
Memberdangerous
Mood: 591
posted on April 17th, 2008 at 08:14 PM
OK, just spent an hour typing all the explanation and lost it all when my computer froze.
here is the chart:
http://i113.photobucket.com/albums/n216/dangerous_05/DynoSessionChart17thApril08.jpg
That's mad Alan.
Memberhainesy
Threads: 3
posted on April 17th, 2008 at 08:33 PM
Well done dave very nice figures there.
posted on April 17th, 2008 at 08:34 PM
here is the chart:
Nice one Dangerous. Holds the power above 215ish hp from about 6500-8500k which is very handy.Inlet temp also relatively nice and cool too and almost the same as ambient temp.
Memberdangerous
Mood: 591
posted on April 17th, 2008 at 08:37 PM
Every pull we did we went to the 8400 rev limit,
and did two at each session to confirm consistency....15 tests in all.
The first interesting thing was the 13hp gain when the oil was nice and warm.
The first pull (not on the sheet) was 206,
and then 220.8 peaking about 7400, but still just under 220 past 8000.(purple on the graph).
This is as I ran it with my best time of 11.00@121.46.
Next, without any fuel system changes, the long ram tubes.
WOW! Radical curve!
Quite obvious in orange, is that the longer rams were best suited to a peak power around 6250.
But the engines' combination of parts tried to bring back the power again later.
In Blue, with the nozzles moved up high, it smoothed things out,
but still the power wanted to be lower at about 6700, and only 219.2.
The next step was to cut the tubes,
and I went about 15mm longer than the original short tubes.(took out about 150mm)
The extra 15mm was for two reasons.
One was the roughness of the emergency hacksaw cutting,
and the other was because I was not sure about where to measure the length from,
being how large the new radii is.
Nozzles still mounted high.
Anyhow, power of 220.8 returned, but its peak was 8200(pink graph).
The power at 6000 was good but it gained very little until it was nearly at the limiter.
Once the nozzles were moved back down to the lower position, the power jumped to 224,
at about 7800, and this is the same combo, as I last raced but the new ram tubes in short length.
(green Graph).
Last constructive test was to lean off mixture by 0.002" and this picked up almost everywhere
except a bit either side of 7000.
225.5 @8000 was the result, but it was still above 220 right up until it hit the 8400 limit.
I did try one step leaner but the pill was a different brand,
and it showed richer even though it was meant to lean it off.
So that last run was aborted.
Very constructive day and still looking over the chart and my notes.
Very interested how the longer ram tubes actually moved the POSITION of the power peak by so much.
But quite obviously the combination of cam and heads wanted it to be higher.
That's mad Alan.
Memberdangerous
Mood: 591
posted on April 17th, 2008 at 08:53 PM
Cheers Col
Thanks Colin and everyone else.
It sounded very nice at full revs.
I still have a stiffy.
That's mad Alan.
Memberwesti
what the
Threads: 28
Mood: not blue, pink
posted on April 17th, 2008 at 08:56 PM
cold spoon will fix that.
congrates dave.
down sharon.
posted on April 17th, 2008 at 08:57 PM
Fantastic flat graph on the money setup. Dave youmust be stoked.
Great to see how those tubes realy change things.
Memberhumpty
Threads: 139
posted on April 17th, 2008 at 09:07 PM
Simply brilliant effort Dave.... This sort of real world stuff is pure gold....
FUCH your early!
Membercolin
Threads: 82
posted on April 18th, 2008 at 09:11 PM
Dave i can back up what you discovered with yuor oil temp figuers.
When blue and i dynoed my car last we always got the car to 80degrees before mashing the throttle.After we finished i wanted to see if a lower oil temp made any difference. Because in hillclimbs especially your first run its hard to get temp into your oil, so we tried a run at 60 degrees, down 13rwhp, very enlightening
Again congrats great result
Cheers Col.
MemberStanley
Threads: 270
posted on April 19th, 2008 at 10:56 AM
Cheers Col
Especially with someone else in your car.....:no:
posted on April 19th, 2008 at 04:09 PM
you have to sit in the back of this thing like i did for the dyno day last year to appreciate the noise and power Dave's car makes.
Memberdangerous
Mood: 591
posted on June 10th, 2008 at 07:29 AM
Some upgrades planned for next year:
http://i113.photobucket.com/albums/n216/dangerous_05/CD1.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/CD3.jpg
I ordered just the bare castings.
I am hoping to use most of the parts from my old heads in these.
The plan is to increase the air speed compared with my Pauter heads.
http://i113.photobucket.com/albums/n216/dangerous_05/CD2.jpg
Looking at the 'as cast' ports, I have a lot to do.
Look how small the exhaust hole is in the chamber side!
http://i113.photobucket.com/albums/n216/dangerous_05/CD6.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/CD7.jpg
That's mad Alan.
Membermactaylor
posted on June 10th, 2008 at 05:35 PM
nice dave are you putting in berilyium seats? man they are a fat casting how thick are they around bolt holes and the like?I keep editing this post as i find more things do the come with the guides all ready roughed in?
1800 552 123
Memberdangerous
Mood: 591
posted on June 10th, 2008 at 07:48 PM
All the holes are there but I will have to make guides and seats.
Seats will be Aluminium bronze.
That's mad Alan.
