| [ Total Views: 40073 | Total Replies: 495 | Thread Id: 73866 ] |
| Pages: 1 .. 14 15 16 17 |
whathaveidone
Threads: 98
Mood: Heading for 10.99
| posted on June 19th, 2013 at 08:07 PM |
Man those ports are HUGE!!!!!!!!!!!
DavoBuggy 1641
Threads: 12
Theme: UltimaBB Pro Orange
| posted on June 21st, 2013 at 06:03 PM |
Dyno Update, Had another interesting dyno session today, made good power topping at 250Hp @ 20 psi and around 5500 rpm. He backed off early because I
asked him not to exceed 20 psi as I was not 100% happy with the fit of the intake manifolds which ended up biting me in the arse. What happened was
when the plenums were bolted to the new heads they were 5/10mm further apart so when I attached the "basically solid" Y peice in between them it
pulled the plenums towards each other and even had trouble sealing when it was dead cold let alone all warmed and stretched up on 20 pound. 4th run in
the lh hand gasket blew out at 20 psi and sprayed methanol out which then caught fire. Matty saw this on his live camera behind my car and quickly
shut it down and the flames soon burnt themselves out. Could have been a major drama on the track so thats why dyno sessions can be invaluble when
sorting a car like this. Oh and to top it all off as I was undoing the nuts on the manifold I managed to put the spanner through the side of it so now
I've got to take it to Aaron's tonight and have it welded We
are modifying the intake system to take two flexible joints and will hit the dyno Wed next week and if all goes well willowbank wed night before the
big trip south...
Cheers Dave!
DavoBuggy 1641
Threads: 12
| posted on June 21st, 2013 at 06:32 PM |
Here's a vid of the fire....
http://www.youtube.com/watch?v=utfVOvqm490
typethreeking
A.k.a.: TROY ALDER
Threads: 9
Theme: UltimaBB Pro Red
| posted on June 21st, 2013 at 06:43 PM |
Glad I wasn't the only one having all theses dramas, except I didn't have a fire.. Very lucky!!
DavoBuggy 1641
Threads: 12
| posted on June 23rd, 2013 at 04:18 PM |
Dad whipped up a luggage rack yesterday to fit over the bonnet of the buggy to store the pit gazebo's and whatever....Might even put Matt on it while
we drive to Sydney so we don't have to listen to him
| Error |
| Error |
| Error |
DavoBuggy 1641
Threads: 12
| posted on June 23rd, 2013 at 04:31 PM |
Got a bit done today on the car as well, picked up my plenums from Aaron last night. He did a great job building up the thin sections inside and out.
So today I hand filed the surface where the nut seats to match the mating surface to the head and to allow just enough room for an 8mm nut with a 12mm
hex to go on. I tried to leave as much thickness as i could for some strength. I Also test fit the now seperated intake pipe with the silocone
'bump' hose. It all fits really well and should work a treat.
Cheers Dave!
| Error |
| Error |
| Error |
DavoBuggy 1641
Threads: 12
more
| Error |
| Error |
typethreeking
A.k.a.: TROY ALDER
Threads: 9
| posted on June 23rd, 2013 at 05:25 PM |
You need some small 11mm nuts for the manifolds, makes life easier..
RodPenrose
A.k.a.: Rodney Penrose
Threads: 330
Mood: GETTING FASTER
| posted on June 23rd, 2013 at 05:42 PM |
Dave , I sourced some new 10 mm flanged nuts in the US that will suit your needs . I will take some to Syd. next week if you can remind me to give you
some , ROD.
More boost + More fuel = More power
1968 Beetle fastest run 8.96 sec @ 161 mph 4th Nov. 2001
2010 New Beetle 8.12 sec on 8th march 2014
http://www.rodpenroseracing.com.au
20bkombi
Threads: 26
| posted on June 23rd, 2013 at 07:42 PM |
Glad I was able to help, was fun welding the cast manifolds reeking of sweet methanol... Haha
9's here we come !!!!
AARON'S SPEED SHIFT AUTOS
Specialising in Vw automatic transmissions, differentials and torque converters
Stock or modified to suit your application (street, drag, off road)
Ph 0402 233 027
matberry
| posted on June 23rd, 2013 at 08:09 PM |
Yep, I've got the 11mm spanner or 10mm aero style flanged nuts here if you need any Dave
Stanley
Threads: 270
| posted on June 23rd, 2013 at 08:24 PM |
Well done Dave...looks good mate. Look forward to catching up in Sydney.
Sides
A.k.a.: Dave Sidery
| posted on June 24th, 2013 at 01:57 PM |
Bummer bout the blowout - great that caught it quickly like that, and even better that looks like have it sorted so already.
T&T Wed night tho instead of State of Origin... gotta be the definition of dedication right there !!!
My toys
andrewmurphy
Threads: 22
| posted on June 24th, 2013 at 04:42 PM |
Should be less people there = more runs
1916baja
Threads: 176
| posted on June 24th, 2013 at 04:48 PM |
Shame his tow car driver is going to the origin and I'm on baby sitting duties! he won't have anyone to boss around!
DavoBuggy 1641
Threads: 12
| posted on June 25th, 2013 at 06:23 PM |
Got the car going today after pressure testing the intake system and just had a couple of squirts up the driveway and she was turning the Tyres very
easily...
Dyno session tomorrow at 12.00 is a go. Going to turn down the boost a little as its making 20psi at only 5000rpm, prob lock it off at 18psi then
willowbank tomorrow night if that goes well!!
Cheers Dave
whathaveidone
Threads: 98
| posted on June 25th, 2013 at 08:29 PM |
Good luck man!!
20bkombi
Threads: 26
| posted on June 25th, 2013 at 10:06 PM |
Good work dude!!
Ph 0402 233 027
DavoBuggy 1641
Threads: 12
| posted on June 26th, 2013 at 07:27 PM |
F*#k it! Torched a head today on the Dyno, at Aaron's right now having it welded and Butler is waiting patiently to machine it tonight then going to
throw it all together and see if it runs. If it does I will make the trip to Sydney but that's a big IF!
andrewmurphy
Threads: 22
| posted on June 26th, 2013 at 07:34 PM |
Damn. Sorry dude
dangerous
Mood: 591
| posted on June 26th, 2013 at 07:43 PM |
| Quote: | Originally
posted by DavoBuggy 1641
"MR" Butler to you.
or DB.
| Quote: | Originally
posted by westi
That's mad Alan.
1916baja
Threads: 176
| posted on June 26th, 2013 at 07:46 PM |
Oh don't be sorry Andrew! This is how we do things... It's all about the thrill of getting the car ready!
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on June 26th, 2013 at 08:13 PM |
Bummer
I'd be sticking to "Sir Mr kind ole mate buddy pal DB Butler" at this stage
Good luck for the turn around
Stanley
Threads: 270
| posted on June 26th, 2013 at 09:10 PM |
Fingers crossed for you Davo. I'm sure Mr Butler will see you right
essex
| posted on June 26th, 2013 at 09:23 PM |
Good luck guys,
20bkombi
Threads: 26
| posted on June 26th, 2013 at 10:08 PM |
Finished welding up the head and now it's at DB's to be machined.
Also cleaned and flowed Daves ID 2000's injectors. # 1 inj is 15ml down on a 30sec cycle at 3 milliseconds @ 5000 rpm. Which is a lot!!
#2 inj was ok, that's the cylinder that got to hot???
Ph 0402 233 027
1916baja
Threads: 176
| posted on June 26th, 2013 at 10:23 PM |
Good work Aaron! Dave said you did a kick ass job welding the head!
20bkombi
Threads: 26
| posted on June 26th, 2013 at 10:35 PM |
Any time!!
feels good to work late nights before a big meet, even though I'm not racing.
Ph 0402 233 027
dangerous
Mood: 591
| posted on June 26th, 2013 at 10:36 PM |
Yeah #1 was the torched one.
Weld was supoib dude,
Dave is on his way home.
| Quote: | Originally
posted by westi
That's mad Alan.
20bkombi
Threads: 26
| posted on June 26th, 2013 at 10:45 PM |
Sweet, all makes sense.
Dave if you can get another injector I can flow them all again.
Ph 0402 233 027
