| [ Total Views: 124846 | Total Replies: 1116 | Thread Id: 85894 ] |
| Pages: 1 .. 14 15 16 17 18 .. 38 |
1303Steve
| posted on June 22nd, 2013 at 03:35 PM |
Some kilowatts were found today. My car was just below the DB limit on a DB meter, to be on safe side I stuffed some chicken wire up the exhaust, I
thought it had been removed, it was found to be still in place, I think some of my missing kilowatts are here.
| Error |
mactaylor
Mood: even my dog is german
| posted on June 22nd, 2013 at 03:47 PM |
prob some of your temp probs too!
EVERLAST CONCRETE TANKS
1800 552 123
Bizarre
| posted on June 22nd, 2013 at 04:15 PM |
Phew....... Though you were about to say you were doing a rust repair
1303Steve
| posted on June 22nd, 2013 at 05:42 PM |
I'm hoping that it fixes a few issues, another dyno is booked for Tuesday.
Its going in to have a few paint blemishes fixed after the drags.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on June 22nd, 2013 at 07:53 PM |
lou0060
Threads: 30
| posted on June 22nd, 2013 at 08:37 PM |
where did you get the fluid cooler from? looks like a good idea to get the overflow back to the tank at a lower temp.
And you'll need to find a few more kgs of chicken wire now that I have both turbos working......
oh, great photos too! car actually does look orange!
1971 karmann ghia Cabrio - Cruising
1963 beetle Sunroof - gathering dust
1968 race beetle - twin turbo Subaru - stress relief
1960 beetle - old school low & slow
1303Steve
| posted on June 23rd, 2013 at 07:51 PM |
So Lou do you want me to stick chicken wire up your exhaust so I can keep up with you?
I bought the cooler on Ebay there is one on there now http://www.ebay.com.au/itm/221121010783?ssPageName=STRK:MEWAX:IT&_trksid=...
lou0060
Threads: 30
| posted on June 24th, 2013 at 09:24 PM |
okay, that's the guys at Toombul. I get a few bits and pieces from them as well and they are not far from my place. got my window net, fuel
fittings, roll cage foam, race boots and socks, and a few other bits.....good guys there.
as for the chicken wire, nah, you probably still got the upper hand; your older (more experianced), you got struts -more cmaber, and heaps of
electronical wizardry in that beast of yours.....
1303Steve
| posted on June 25th, 2013 at 06:44 PM |
Just got back from the dyno shop, good news is that kilowatts were found as well lots of torque.
Shame its raining, I had to behave myself.
| Error |
| Error |
Bizarre
| posted on June 25th, 2013 at 06:52 PM |
Gotta be happy with that??
500 NM is a shit load
Is the blue line before??
lou0060
Threads: 30
| posted on June 25th, 2013 at 07:06 PM |
looks like a great run on the dyno Steve.
I gather you upped the boost from 15-16psi to around 20psi to get the final figures. Are you going to ran that as standard pressure or do you have a
boost controller so you can back it off for day-to-day running?
shouldn't have any trouble doing a burn-out at the weekend then.....
1303Steve
| posted on June 25th, 2013 at 09:42 PM |
MSEdyno 2 is high and low boost settings on the e Boost 2, blue is low, red is high. MSEDyno 1 is just two different runs.
The E boost 2 defaults to lower setting which is about 16 psi on start up, I need to select the higher setting if I want it.
Its a heavy car so I will see how it goes on the weekend.
hellbugged
A.k.a.: Daimo Pell
| posted on June 26th, 2013 at 06:30 AM |
That's more better !
sander288
"Bolt-on Master"
Threads: 183
| posted on June 26th, 2013 at 08:29 AM |
holy shit that thing is a torque monster!!!
A brand new Carrera S has 440Nm
1303Steve
| posted on June 26th, 2013 at 10:32 AM |
Thanks guys,
I'm not sure how to compare flywheel torque to torque at the wheels, this was the result that the tuner had predicted, I'm pretty pleased as this is
a stock low kilometre motor and will last a long time, so apart from changing cams or turbos or even stroking it out to 2.2 this is it.
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on June 26th, 2013 at 10:15 PM |
that should see you into the 11's this weekend.
1303Steve
| posted on June 27th, 2013 at 12:12 AM |
Its a heavy car, I will be happy to do low 13, maybe a 12.
Jak Rizzo
Threads: 67
Mood: Pastizzi eating
| posted on June 27th, 2013 at 08:09 AM |
If I can do a 13.0@103mph with only 8psi boost & 152kw @ the wheels, taking it easy off the line
u will do an easy 12 with 20psi boost & 204kw! U could do a 12 in reverse!....................then drive back to the staging lanes without a tow
car...................
reub
VWRX is gone...
| posted on June 27th, 2013 at 09:50 AM |
| Quote: | Originally
posted by Jak Rizzo
then drive back to the staging lanes without a tow car...................
Reub
Craig Torrens
Threads: 347
| posted on June 27th, 2013 at 10:20 AM |
| Quote: | Originally
posted by 1303Steve
My car is 1640kg (without driver) with 210-215kw atw.......12.5@109mph
My 4 yr old daughter could do 12's in your car Steve
1303Steve
| posted on June 27th, 2013 at 10:51 AM |
| Quote: | Originally
posted by Craig Torrens
| Quote: |
has she got a helmet
1303Steve
| posted on June 27th, 2013 at 04:19 PM |
Its been wet lately, so now its a little drier now so I went out a local free way to run up to the speed limit.
http://youtu.be/qDnLsxNzkvI
Camo
A.k.a.: Kev
Threads: 209
| posted on June 27th, 2013 at 06:38 PM |
Great stuff Steve, but I think you may need to take me for another spin in it now that the exhaust isn't choked up
Kev
vw54
| posted on June 27th, 2013 at 06:58 PM |
yr standing in it again
1303Steve
| posted on August 6th, 2013 at 05:38 PM |
After the failure of my front tyres after Wakefield and the tyre importers saying that cracks are normal and not to worry, I had some ADVAN Neova
AD08R fitted today. Cant wait to try them.
Thanks CT
| Error |
| Error |
Craig Torrens
Threads: 347
| posted on August 6th, 2013 at 06:08 PM |
1303Steve
| posted on August 11th, 2013 at 08:02 PM |
Does my bum look less fat like this?
| Error |
1303Steve
| posted on August 16th, 2013 at 02:29 PM |
Richard Holzl just got me in a set of 28 mm short bars. The're made in Japan and sold by Latest Rage in the US.
I'm running 26 mm short bars now which are much too soft, I hope that these will stop some of the squat I'm getting under power.
| Error |
Pickpocket
| posted on August 16th, 2013 at 04:58 PM |
I'm curious how those bars will work also. I installed a set of 944 bars in mine and it feels awful stiff, but I don't have the engine or anything
in it yet so hopefully that helps soften it up a bit. As is though, I can't even bounce on the rear of the car with my full weight (240lbs) and get
the rear end to move.
vlad01
Mood: Side ways
| posted on August 16th, 2013 at 07:46 PM |
I am curious how you work out the required bars without actually trial and error.
71 notchback,
