| [ Total Views: 329221 | Total Replies: 1582 | Thread Id: 58055 ] |
| Pages: 1 .. 15 16 17 18 19 .. 53 |
punchbuggyracer
A.k.a.: Rob Tratt
Threads: 22
Mood: Above average!
| posted on June 30th, 2008 at 10:34 AM |
So can you do type IV heads?
Dave you make my job look so boring and useless compared to what you get to do.
dangerous
Mood: 591
| posted on June 30th, 2008 at 12:18 PM |
| Quote: | Originally
posted by punchbuggyracer
No.
I only do fast stuff.
| Quote: | Originally
posted by westi
That's mad Alan.
Stanley
Threads: 270
| posted on June 30th, 2008 at 12:33 PM |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on June 30th, 2008 at 03:55 PM |
OK thats not funny at all.....
just for that i should give you a set of Type 4 heads to do lol
dangerous
Mood: 591
| posted on June 30th, 2008 at 04:58 PM |
Never seen a fast one with out boost.
Thats damn funny.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on June 30th, 2008 at 04:59 PM |
As funny as haemeroids when someone else has got them.
| Quote: | Originally
posted by westi
That's mad Alan.
Stanley
Threads: 270
| posted on June 30th, 2008 at 05:43 PM |
not that there is anything wrong with a bit of boost
dangerous
Mood: 591
| posted on June 30th, 2008 at 06:40 PM |
After a weekend of fun making cutters,
I rolled the week end into Monday and made a MEGA two tip cutter
to unshroud the inlet valve in the chamber.
Both have radius tips.
The first tip goes right down to the top of the seat at a diameter that just clears the spark plug.
The second tip is set at a larger diameter to unshroud out to the bore edge,
but to a shallower depth that stops above the spark plug.
Here you can see the two different steps that the tool forms.
Then a quick blend with a rotary burr to show the approximate shape.
Much work to do yet,
but must rest for now and get the car ready for the dyno day.
| Quote: | Originally
posted by westi
That's mad Alan.
| posted on June 30th, 2008 at 06:56 PM |
They are looking good mate!!! As for having roids on your date it is funny whne you don't have em but it's hilarious when someone else has them and
can't sit down ahahahahha
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on June 30th, 2008 at 07:00 PM |
| Quote: | Originally
posted by dangerous
This time guesstimate does not include the many hours
of looking at the heads and planning ideas
as I sit with them on the couch, in bed, and on the toilet,
rolling them over and dreaming about a plan of attack.
You can probably double the hours if you include that.
now that sounds familiar!!
awsome work as usual Dave, enjoying this one!!
i especially like the cutter that does the radius down to the top of the seat...........that bit is very hard with just the rotary burr.
60 hours at shop rates, think about that guys!
punchbuggyracer
A.k.a.: Rob Tratt
Threads: 22
| posted on July 1st, 2008 at 12:11 PM |
Any one want to swap a T4 78mm hemaroid crank for a 84mm T1 go fast???
dangerous
Mood: 591
| posted on July 11th, 2008 at 09:56 PM |
I should be doing other things,
but since I had the face-plate mounted in the lathe,
I thought I would see how it would go flycutting my heads.
Normally this would be done in a milling mahine.
But this works very well.
This is just roughed down 0.100" and then a .050" step at the piston diameter.
Set up time is a little longer(like amout 1 minute),
but the tooling is much more rigid than a mill, so much larger cuts can be taken,
and with no chatter.
I am sure a case could be done this way without much problem.
| Quote: | Originally
posted by westi
That's mad Alan.
mactaylor
Mood: even my dog is german
| posted on July 12th, 2008 at 12:29 AM |
what other work dave? nothings more important than hipo vw bits.
EVERLAST CONCRETE TANKS
1800 552 123
dangerous
Mood: 591
| posted on July 12th, 2008 at 06:56 AM |
| Quote: | Originally
posted by mactaylor
That is correct.
I should be getting my car ready for Dyno Day.
Should be a good day!
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on July 12th, 2008 at 10:20 PM |
nah tinkering is much more fun.i love it,as i am sure you love to too.
i will get straight into it dave,with the carby testing that you did .was it carby alone.because i have bee doing some testing.
i took the valve out and blocked the guide hole just to see what the best of the best would be,it was 175cfm.
with the valve in and at 630lift it is between 161cfm to 170cfm.the tests have been done over the last couple of weeks ,and i keep coming up with
different numbers,is this normal.the machine is driving me nuts.
any how my question is ,do you think i have maxed out with vavle size or is it worth looking at the venturi side of things.
oh,i almost forgot .do you still have room next week for some boys from down south.
down sharon.
westi
what the
Threads: 28
| posted on July 12th, 2008 at 10:22 PM |
p.s
you proberly get sick of hearing it,but.
the heads look unreal.
when will they be going on,soon i hope.
keep the pic's coming
down sharon.
dangerous
Mood: 591
| posted on July 13th, 2008 at 07:32 AM |
Those tests from the sheet I posted
were carb only.
The numbers should be very consistent for each combination
unless the temperature is rising.
Temp change can make huge differences,
hence the reason for correction factors for each temp rise.
I recall putting a 48 ida on my heads and went from 170cfm down to 140.
I dont remember the ventruri I used,...37 to 42?
but the precentage loss gives you an idea how much an inadeqate carb or body can kill a good set of heads.
Testing my memory with a 'no valve test', but that seems like only a small gain with no valve,
which if correct means you have done your job well whan the valve is in there.
You guys are still welcome to stay here next frid night.
Sat night nfg.
I have a couple of spare beds and floor space, but bring your sleeping bag(not woman...sleeping bag).
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on July 13th, 2008 at 08:17 AM |
The heads will not be on until next year.
I still have to save up for the rockers and covers(DOOOHHH!).
That will take most of a year as will be the port and chamber stuff.
There are still a couple of tings I want to try on this engine,
and with my spare bullet before the heads upgrade.
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
| posted on July 13th, 2008 at 08:33 PM |
no prob's.
is there a drag meet or test and tune on as well as the dynoday on that weekend.
down sharon.
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on July 13th, 2008 at 11:09 PM |
YEP ! but with no pics of your car yet ! your not allowed to GO !! ( as a roller from side )
Rod , myself are going up ,maybe a couple more . Maybe fuffin man might come ? muffin man?
westi
what the
Threads: 28
| posted on July 14th, 2008 at 09:57 AM |
i will see what i can do.
but there were a few scratches on things that needed to be touched up,so basically what i am saying is that it is still apart.
you would much prefer a complete or as it is, pic or pic's ,yes.
down sharon.
dangerous
Mood: 591
| posted on July 21st, 2008 at 07:22 AM |
Well, they dyno day has come and gone for the year.
This year was a bit of a fizzer for me for my own car, but an awesome day for the Volksies!
The first and only test 'pull' was only 157.7 kW(= 212.48hp)
Unfortunately before they could get any heat in the engine, the clutch died.
Everyone has an excuse I suppose, but it would have been nice to get a better number,
being that the car is now faster than when it had 217hp last year.
Last run I had in the car in march had some clutch slip.
As did my dyno testing in April, until the clutch heated up.(225.5HP)
So 2 weeks ago I went to the trouble of replacing the disc,
and resurfacing the FW and pressure plate.
After the failure on Saturday I was a bit worried, being I had been tinkering in that area recently.
But as it turned out , it was merely a failure of the throwout bearing(old faithful).
My guess is that with the car sitting idle for the last few months,
a 17 year old throwout bearing,
and declutching a cold bearing at the 8400 rev limit on the only dyno pull,
the poor old bearing said, "enough!"
When I got home on Saturday night I was thinking if I did not find out what was wrong that night,
I would be worrying all day sunday while bushwalking.
So in a daze of dehydration,
I dived in at 7pm and sluiced the engine out to find the culprit, and the relief I was after.
The bearing has not totally seized, but is very stiff to turn.
It looks like a new bearing, and thorough inspection will be all it needs.
At least the new disc is now well 'bedded' in.
| Quote: | Originally
posted by westi
That's mad Alan.
Stanley
Threads: 270
| posted on July 21st, 2008 at 08:16 AM |
Better to find it know than at a T&T or even worse the Jamboree.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on July 21st, 2008 at 11:35 AM |
An economical fix .. that is about all you can really hope for.
Was a great day on Saturday.
westi
what the
Threads: 28
| posted on August 6th, 2008 at 01:41 PM |
what you up to dave.
hows those heads going,
down sharon.
dangerous
Mood: 591
| posted on August 7th, 2008 at 07:26 AM |
Hi Westi,
no more progress on the heads as yet.
Have a tranny and engine to do before the Test and Tune next Thursday.
Plan is to just get the rust off(driver) in prep for Jamboree on 23/24th of Aug.
| Quote: | Originally
posted by westi
That's mad Alan.
westi
what the
Threads: 28
| posted on August 7th, 2008 at 09:27 AM |
jambo time again,it sure goes quick hey.
keep us posted, is pagey and rod going too.
pic's and vid's are a must.
down sharon.
| posted on August 7th, 2008 at 11:18 AM |
Think Rod is running the chop top. Dunno if Pete is running as he was going to freshen up the engine in the yellow car.
Heard that there are some new guys who are going to campaign All motor from the rotary ranks. 20b powered RX3 and a few others all cars are apparantly
capable of sub 11.00 passes. Funny thing on the rotary forum is the angst between the honda guys and the rotary boys over who is better. Us Volksy
guys don't even rate a mention even though we keep winning rounds!!
I should be available to help out and Jambo if the need be.
westi
what the
Threads: 28
| posted on August 9th, 2008 at 12:45 AM |
the rx3 usually runs 12's,it is the green one,it will be the one that gets the 20pp. it should make some good pony's,it all depends on how nice he
is to me when we do the headers and exhaust,maybe i can choke it up alittle.lol
the red one about to go out(rx3)is his brothers, but he only has a 13b pp.both cars are heavy and run full street trim.
they are never as consistent as the volkys but they think there shit hot.
i know he use to hate racing the volky's because they always 60ft well.
i hope there will be vid's.and i wish the best of luck to all the volky's that attend.
down sharon.
dangerous
Mood: 591
| posted on August 9th, 2008 at 05:46 AM |
Thanks for the inside tips Westi.
I heard there was another PP20B that went 10.1 at the last test and tune up here.
Mazfix or Maztech customer I heard.
I can always try to be more consistent, and win that way I hope.
| Quote: | Originally
posted by westi
That's mad Alan.
