[ Total Views: 285753 | Total Replies: 905 | Thread Id: 36521 ]
 Pages:  1  ..  16  17  18  19  20  ..  31
Author: Subject:  WPVW turbo oval progress - 443bhp (10.13@139.70mph)
posted on September 29th, 2006 at 06:25 PM
Originally posted by hypo-vw
only 14psi and 320hp!!! that's amazing! :duh
What sort of torque is it producing?
When the engine was dynoed last time it produced 900lbs of tractive effort and this time a massive 1260lbs .
1200 and freakin 60!!! that's monster! :spin:
No wonder people blow gearboxes to bits...:o
Memberhypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
cool.gif posted on October 4th, 2006 at 08:26 AM
DYNO SHEET
here is the dyno sheet for the turbo oval from last tuesday . As you can clearly see , the oval made an incredible amount of usable horsepower and was still making power when Kevin got off the throttle at 320.6bhp@5600rpm .
ran the oval for the first time on saturday at Warrick , and it bloody flys .
first run on the 1/8 mile was 7.1@102mph , with a very steady take off . The 60 foot time was 1.9secs , but the oval normally runs 1.7 secs . So 6's are very possible .
second run was 7.5@99mph and I missed 3rd gear . checked the tacho recall when I got back to the pits and it showed 8200rpm .
third run did a nice strong burnout , but broke the crownwheel & pinion from the start line .
CANT WAIT TO RUN IT ON THE QUARTER !!
[ Edited on 3-10-06 by hypo-vw ]
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
posted on October 4th, 2006 at 08:41 AM
awesome.
sorry wayne, seems I was a bit of a prophet there. what's happening to strengthen the gearbox now?
MemberHotRodMatt
If it's old or rare - cut it!
Threads: 361
posted on October 4th, 2006 at 03:34 PM
Sacrifice clutches instead of crown wheels.
Cranky has to play clutch even with a tuff box and I guess you will have to aswell.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on October 23rd, 2006 at 11:40 PM
G'day Wayne - how did the tranny repairs go after warwick? Is the oval back in action yet?
I was disappointed I didn't get to see it run more at warwick (I was sitting in the staging lanes and missed every run)...ah well, can't wait to see it run next time!
By the way, did you end up narrowing the ally beam 4 inches in the end - if so were you able to retain the shock towers in some way?
Alan
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 23rd, 2006 at 11:45 PM
Originally posted by pete wood[ what's happening to strengthen the gearbox now?
to strengthen the box now I have got my brother Rod to order for me a new 9310 chromemoly crownwheel & pinion set from US in 3.44 ratio .
I have also ordered a new 1st and 2nd gear combination of 3.3 / 2.08 to replace the 4.11 / 2.21
This will make 1st gear a lot more usable as with the present combination the oval tends to jump off the line , shift light flashes at 7100rpm and I have to grab 2nd gear in about 25 feet . When this happens I feel that the engine revs quickly but doesn't get boost up immediately .
I watched a lot of other cars on the drag day and they seem to be going a lot further than I am in 1st gear .
With the taller 1st gear I am sure that the engine will get on boost better as it will be under more load and this will bring my 60 foot times down .
Then with the taller diff ratio I have calculated that the oval will be doing 110mph in 3rd gear @ 7100rpm and then 138mph in 4th gear @ 6500rpm .
When the crownwheel & pinion arrives from Rod , I will strip the oval and post pics of the transmission carnage .
[ Edited on 23-10-06 by hypo-vw ]
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on October 23rd, 2006 at 11:53 PM
Originally posted by Dasdubber did you end up narrowing the ally beam 4 inches in the end
Alan
Hi Alan , I really didn't get time before I went to Warrick to narrow the front beam , so I removed the front disc brakes and put the brakes back to stock so that I could fit my BRM's on the front .
I was surprised at how well the oval stopped on 4-wheel drum brakes from 102mph . I think I may have to do a brake upgrade though before running on the quarter .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on November 11th, 2006 at 11:19 PM
preparation update .
Well I have had a slight setback . Brother Rods' order arrived from US on Friday and there were no ring and pinion sets packaged in the order .
I have made enquiries through several sources and I am waiting for a response .
The 3.3/2.08 1st/2nd gear set has arrived . Just waiting on the ring and pinion .
Memberdangerous
Mood: 591
posted on November 12th, 2006 at 08:36 AM
Did you go for Albins 002 style or Berg 113 key style Wayne?
Originally posted by westi
That's mad Alan.
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
posted on November 12th, 2006 at 11:07 PM
I love this thread (its inspiration for my next oval project!)....do you anticipate any problems with the heads cracking between the inlet/exhaust valves since there is such little material there?
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on November 12th, 2006 at 11:14 PM
Hi Dave , I went for the albins 002 style as this is the same as I am currently using in this tranny . I find them much stronger with the splined gear to hub on 3rd and 4th gears .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on November 12th, 2006 at 11:22 PM
Originally posted by Dasdubberdo you anticipate any problems with the heads cracking between the inlet/exhaust valves since there is such little material there?
I dont antisipate any cracking between the valves as cracking is normally caused by excessive heat . By tuning the engine correctly and making sure the fuel mixtures are perfect ( and those of you who saw the oval run at Warrick can testify to the crispness of the throttle response ) , the engine should produce good horsepower reliably without cracking the heads .
The amount of material between the valves is no less now than with the old heads , as I have made the new ally-bronze seats much thinner for better flow .
[ Edited on 12-11-06 by hypo-vw ]
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on December 13th, 2006 at 10:24 PM
Well after brother Rods' order arrived from US without the parts that I had ordered and chasing all over for over a month , the new 3.44 ring and pinion has finally arrived .
I managed to locate a couple in US and have them shipped over quickly .
Sometime over the next couple of weeks , I will stip down the oval and fit the new ring & pinion and also the new 1st / 2nd gear set .
old ratios...............................new ratios
4.11........................................3.33
2.21....................................... 2.08
1.43........................................1.43
1.04........................................1.04
3.88 r&p..................................3.44 r&p
130mph@7500rpm...................140mph@6600rpm
[ Edited on 13-12-06 by hypo-vw ]
Memberdangerous
Mood: 591
posted on December 14th, 2006 at 06:54 AM
Hi Wayne,
can you tell us the tooth count on those gears?
eg on first : 30/9 etc
For all four gears.
Thanks, DB.
That's mad Alan.
MemberGraeme
Threads: 3
Mood: Tired
posted on December 20th, 2006 at 04:43 PM
Hi Wayne,
Sorry to crash your site, bloody awsome car by the way, but i was wondering if you (or anyone on this forum) knows where to locate some half decent type 4 heads for a motor i am building up.
so far it looks like: 103x82, h-beam chevy rods, web 86b/86c cam, cb throttle bodies, msd, haltec computer etc.. only the heads i was going to build up are not a very good base.. I was thinking around the 38x48 ported/polished route.. anyone know where i can lay my hands on anything?
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on December 20th, 2006 at 09:30 PM
Originally posted by Graeme I was thinking around the 38x48 ported/polished route.. anyone know where i can lay my hands on anything?
Hi Graeme , give me a call during business hours at my shop on 02-42725844 . I might have just what you need ....or even do a custom set for you . I have just finished a set of what you have described for a 77 bay window bus 2-litre and it friggen flys......
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on December 20th, 2006 at 10:29 PM
MORE BOOST...MORE BOOST...MORE BOOST...
Today the new larger 759cc injectors arrived and I feel more boost coming on......... The old injectors were 550cc .
I am now feeling like I am about to take a walk across egg-shells with cast-iron boots . There is a fine line between maximum horsepower and major blow-up !! I wonder just where that is ?
MemberBoostn
Threads: 28
posted on December 28th, 2006 at 12:02 AM
Hey Wayne,
how is it all going?
looking good for the 13th?
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
posted on December 30th, 2006 at 12:14 AM
Originally posted by Boostn
Hey Wayne,
Hi Nick , I will be ready for the 13th at Heathcote .
I have been busy the last couple of days fitting the air-conditioning components to the type-3 project and only got a start on the oval late this afternoon .
I managed to get the engine out of the oval and started on the trans removal .
Below is a pic of what came out of the transmission drain plug hole .......... looks pretty impressive eh !!
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 1st, 2007 at 05:50 PM
TRANSMISSION REMOVED AND STRIPPED
well I managed this afternoon to get to my workshop to remove the transmission from the oval and then strip it down to check the 'WARRICK CARNAGE' .
pic-1 the transmission is once again removed from the oval and fitted to the engine stand .
pic-2 the damage to the ring & pinion may be worse than first thought as quite a lot more debries falls out of the drain plug hole , including whole teeth .
pic-3 the axles and tubes have been removed , the LSD is removed from the transmission to find considerable damage to the ring .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 1st, 2007 at 05:57 PM
pic-4 a large quantity of teeth are broken or even missing from the ring .
pic-5 not a pretty sight inside the rhino housing . Massive amounts of teeth and debries . Fortunately no damage to main housing or side plates .
pic-6 the head on the pinion doesn't look any better than the condition of the ring . It also has whole teeth missing . I think I had better call the dentist for this tranny .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 1st, 2007 at 06:00 PM
pic-7 with the transmission completely stripped down , the ring & pinion are washed and dried , ready for the trophy cabinet . ( As they are useless for anything else )
Reassembly will start tomorrow with the new 3.44 ring & pinion and the taller 1st & 2nd gear sets .
No other damage was found in the transmission , other than a few minor markings on the ZF LSD housing .
[ Edited on 1-1-07 by hypo-vw ]
Memberdangerous
Mood: 591
posted on January 1st, 2007 at 06:09 PM
Hi Wayne,
Can you do a tooth count on your new (1 through 4) gear sets for me?
I am interested to get an idea on how course the teeth are.
Thanks DB.
That's mad Alan.
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 2nd, 2007 at 06:06 PM
Hi Wayne,
Thanks DB.
Hi Dave , here are the tooth counts for you .
1st gear 9/30 = 3.33
2nd gear 13/27 = 2.08
3rd gear 18/26 = 1.44
4th gear 25/26 = 1.04
R&P 9/31 = 3.44
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 2nd, 2007 at 06:22 PM
TRANSMISSION RE-ASSEMBLY
pic-9 the new ring is fitted to the ZF LSD hemisphere and the bolts are torqued down .
pic-10 the pinion is assembled with all of the gears and fitted to the rhino housing so that the ring and pinion can be set-up properly
pic-11 the ring assembly is fitted to the transmission to check the backlash . I had to adjust the shimming on the ring and pinion 8 times before I was happy with the results .
[ Edited on 2-1-07 by hypo-vw ]
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 2nd, 2007 at 06:31 PM
pics-12 & 13 show the new pinion fitted to the transmission . Note how large the pinion head diameter is to a stock 3.88
Bearing blue has been applied to the teeth of the ring and pinion to check the meshing of the teeth .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 2nd, 2007 at 06:33 PM
pics -14 & 15 show the complete gear carrier assembly assembled and the selectors have been adjusted , ready to fit back into the rhino housing .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 2nd, 2007 at 06:37 PM
Hey Nick , how is your bug going ? are you coming to Heathcote for the summer slam ?
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 3rd, 2007 at 11:08 PM
TRANS REPAIRED AND ENGINE RE-FITTED
pic-16 the transmission is completed and fitted back into the oval once again .
pic-17 after much consideration and advise from others in the know , I have decided to remove the 3-puk clutch disc from the oval and replace it with a 4-puk that I purchased from brother Rod . This should extend transmission life drematically .
I had 2 choices of discs . The cinter-iron disc or the 4-puk . I hope I have made the right choice , but the deciding factor for me was the disc weight .
The cinter-iron disc weighed 1.25kg and the Kennedy race 4-puk weighed 750gms . The lighter disc will not only allow the engine to rev quicker , but the choice for me was made due to the quicker gear changes that can be achieved with the lighter disc .
With the Kennedy stage-4 3000lb ductile pressure plate that I am using , I don't suspect any clutch slip .
Memberhypo-vw
Threads: 82
Mood: hypo cruis'n
cool.gif posted on January 3rd, 2007 at 11:15 PM
pic-18 check out the heat discolouration on the clutch and pressure plate that I removed from the oval . That 3-puk disc really doesn't like to slip , especially on that last 7000rpm launch that munched the ring & pinion .
pic-19 the engine was installed back into the oval late this afernoon . Tomorrow morning I will go to the shop early to connect all of the plumbing and fit the rear of the body back on , before all the crazy kids turn up at home for my daughters birthday party around lunch time .
[ Queries: 40 ] [ PHP: 11.9% - SQL: 88.1% ]
