| [ Total Views: 329220 | Total Replies: 1582 | Thread Id: 58055 ] |
| Pages: 1 .. 16 17 18 19 20 .. 53 |
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on August 9th, 2008 at 09:01 AM |
the black series 7 RX7 with the 20b PP apparantly run low 10 passes back to back recently so i was told by Captain. He also was the one who told me
about the other chook cookers making an appearance in all motor.
westi
what the
Threads: 28
Mood: not blue, pink
| posted on August 9th, 2008 at 09:29 AM |
they are never usually consistent that is there down fall.i still like the sound of a good burner 20b, nice and crisp.
down sharon.
| posted on August 9th, 2008 at 09:40 AM |
Muffin Man FTW??? LOL
grumpy rooster
Threads: 1
| posted on August 11th, 2008 at 09:58 PM |
The car that ran 10.1 is owned by Craig Wasson, original owner of MR12A, the fastest 12A in the country. He is a Mazsport customer. The car will run
into the 9's with a few more passes under its belt (probably at Jambo).
There is also the blue Honda S600 of Colin Beiber that has had the 13BPP replaced with a 20BPP. He is a Maztech customer and they are looking for low
9's. The car is way under weight for any record setting purposes (like 150kg).
Along with those 2 is Sam's black 20BPP RX7 and another 20BPP in a green RX2. So that makes 4 20B's.
On the Honda front the Online guys and Hi-Comp (us) will not be there. There are a couple of others that may sneak into the 11's.
Good luck to you guys against the rotars. (I will be supporting a rotary guy this time).
dangerous
Mood: 591
| posted on August 14th, 2008 at 10:52 PM |
| Quote: | Originally
posted by dangerous
Have a tranny and engine to do before the Test and Tune next Thursday.
Plan is to just get the rust off(driver) in prep for Jamboree on 23/24th of Aug.
Went up to the test and tune to get back into the swing of things.
It had been 5 1/2 months since my last confession,
oops I mean my last run.
Nothing great but at least I got the new clutch bedded in,
and the rust worn from the bores:
13.573@114.36... thats what happens when you try to use 3rd and 4th gear to take off!
11.329@118.02....clutch slipped off the line and over reved in 1st gear.
11.385@116.13...crooked launch but otherwise clean (I had richened it up to account for the -350ft air, but it went slower, good 60-fot at 1.539).
Lost the plot a bit with the tune, and it was getting a bit slick on the start line so came home.
But it was good to go out and cane the car.
118mph is still 8100rpm..sweet.
(116 is 7950rpm)
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on August 14th, 2008 at 11:03 PM |
13.57 was 2.173 sixty and 9.261@89.64mph on 1/8mile
11.32 was 1.600 sixty and 7.184@95.06mph on 1/8 mile.
11.38 was 1.539 sixty and 7.190@94.42mph on the 1/8 mile.
Surprising how even in the very dense air, 0.002" richer jet slowed down the mph so much.
| Quote: | Originally
posted by westi
That's mad Alan.
Stanley
Threads: 270
| posted on August 15th, 2008 at 06:46 AM |
"13.573@114.36... thats what happens when you try to use 3rd and 4th gear to take off!"
A lot of people would be happy with that using first. Maybe the time has come to develop an auto box Dave....
Can I just say how bloody cold it was out there as well
dangerous
Mood: 591
| posted on September 1st, 2008 at 07:12 AM |
Well the Jamboree two day event has been run and....WON!
As reported in another post, the clutch ring sheared off after the first burnout in qualiying,
so with help from Stanley, we welded it back on with his tig, and made it back to the track in time
to re-assemble everything and do a 'one-and-only' qualifyer at
11.31@117.59
In racing on an 11.29 dial in I ran:
11.30@116.85
11.30@118.14
11.59@ back off 90mph
11.73@back off 87mph to win the final.(0.411 reaction time)
Car weighed 1785 lbs after the last run.
(this is 811kg with me in the car).
Sixty foot times were:
1.51
1.52
1.54
1.44
1.53
Best ever sixty foot in the car was the 1.44,
and best 1/8 mile time on the day was 7.01 and 96.53mph.
(best ever in the past was 6.98@97.7 so pretty close).
This win put me second for the series championship points.
Here is the cheque for that:
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 1st, 2008 at 07:20 AM |
The car was consistent but a bit slow considering the great track and weather conditions.
There was however, an annoying exhaust 'popping sound' that I could not get rid of,
until the engine was warm.
I had decided that this lack of power was due to the good air, making the engine just a bit to lean,
and with the next richer jet being 'too rich', I left it alone.
But when unloading the car on Monday morning the number two cylinder
had a considerable combustion leak between it and the head.
Once this warmed up, the 'popping' from the exhaust was reduced,
but certainly a cause for the lack of power.
Perhaps I should have not left it solong before a head re-tension.
92 runs.
Here is where it was leaking.
It took a 0.015 thou cut to clean up this surface.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 1st, 2008 at 07:37 AM |
Other than this minor problem everything else looks 'tip top',
so before making any cuts on the head,
I checked the piston to valve clearance and worked out I could take as much as .020thou ,
and still be safe.(if I needed to).
While the heads were off the springs were checked,(only one needed a shim),
and and a little more blending was done in the ports where the guides stick through.
As per 'tear drop theory' it is better to have a rounded face 'in the breeze' than a knife edge,
(makes sense), so I did these mods before washing everything for final assembly.
As run:
Now:
Exhaust as run:
and
Now:
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on September 1st, 2008 at 08:03 AM |
Should be running so strong for Warwick Dave.
Is this pretty much this combo at the top of its performance?
You certainly seem to have covered every angle meticulously.
westi
what the
Threads: 28
| posted on September 1st, 2008 at 09:21 AM |
just put the new heads on dave,you know you want too.it's eating you up so just do it.
down sharon.
hellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
| posted on September 1st, 2008 at 02:30 PM |
nice Dave, all the berg heads i've sussed have round edges too
dangerous
Mood: 591
| posted on September 5th, 2008 at 07:17 AM |
There are plenty of areas for improvement with this engine,
particularly in the tuning area,
but I have to try and "hasten slowly"
and keep consistency and reliability in mind,
to coincide with the race events that I plan to run.
ie
Warwick
Portland,
Jamboree 19.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 5th, 2008 at 07:19 AM |
| Quote: | Originally
posted by westi
That's mad Alan.
byronmcmanus59
A.k.a.: Jono punton
Threads: 22
| posted on September 5th, 2008 at 08:35 PM |
| Quote: | Originally
posted by dangerous
ie
Warwick
Portland,
Jamboree 19.
your running portland!! cant wait to see this.
good job
oldskl60
Threads: 28
| posted on September 6th, 2008 at 07:48 AM |
I found this footage on my camera that I had not got around to posting, it is of Dave's 11.00.
http://www.youtube.com/watch?v=w7aFkBphFDI
Dak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
| posted on September 6th, 2008 at 05:05 PM |
Thanks for the link to our web site , Tom . Very sweet run Dave .
dangerous
Mood: 591
| posted on September 6th, 2008 at 05:39 PM |
WOW!
Thanks Tom!!
| Quote: | Originally
posted by westi
That's mad Alan.
vassy66T1
A.k.a.: Marcus Vass
| posted on September 6th, 2008 at 07:23 PM |
Gr8 video!
Love your beetle Dave. It is a credit to your preparation the consistency. I was talking to Peter Beattie (no not the premier) the other day and he
was reliving old times when he leaned on your expertise in setting up his 4.0l cortina with the methanol injection. Unfortunately he never continued
with taking it to the track because he could see the $ running away.
tassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
| posted on September 6th, 2008 at 08:27 PM |
Damn!
I re-ran that vid over and over!
Thats such a sweet "leave"
Great stuff!
L8tr
E
Im not a complete idiot, quite a few parts are missing....
dangerous
Mood: 591
| posted on September 16th, 2008 at 07:26 PM |
Prepare for Warwick '08
I decided to build a whole new gearbox this year for the Warwick 1/8th mile.
This way I can keep my 1/4mile box as a spare for events like Warwick and Portland.
There were some minor issues with the shift quality at the Jamboree.
Here you can('t) see the bush in the floor pan.
I know I had replaced it at some point in the past,
but I guess it needs another....1992 may be?
I had forgotten how much work it is to build a fresh one of these bus trannys for dragrace.
I am up to 40 hours so far, and still have not begun final assembly.
It will be based on a 2lt case, and replaced the bolts with studs.
Diff ratio is 5.42857,
and ratios will be:
1st : 3.3000
2nd :2.0588
3rd : 1.579
4th 1.2174
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 16th, 2008 at 07:35 PM |
Here is the ERCO spool,
with K38/7 crown wheel attached.
I made up these flanges by splicing the 2lt ones with ones from a Commadore.
(to match my CV's)
They will be retained by these stepped caps instead of factory circlips.
The spool is held into the case with screw in side covers,
to which I fitted new German seals.
I am going to try an ERCO chro-moly pinion nut this time.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 16th, 2008 at 07:58 PM |
The other end of the pinion will have this "Pablo" thrust shim arrangement.
It is fitted between 4th gear on the pinion half,
and is located in a recess that I machined in the intermediate housing.
(note oil return hole spooned around shims).
It is set at .003" clearance between the shims.
I should mention that the intermediate housing is a cast aluminium version from Morris Race Engines in the USA.
It is very similar to the original Bergs housing,
and every bit as good quality.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 16th, 2008 at 08:18 PM |
It is surprising how many extra little jobs needed doing.
Early nose cone is needed since the hockey stick that is supplied has been shortened.
This early nose cone needed re-bushing.
And facing off flat:
....to make room for this steel retaining plate:
I also had to take 1.5mm from the bell housing face and location.
This is to get better clutch geometry,
and also full starter motor gear engagement.
Lengthened the clutch arm:
Made a bronze bush,
and welded the clutch fork :
Shorten the 1800 input shaft to 1600 length:
Clearance inside the case to make room for the beetle style shift arrangement and forks.
Fit 1800/1600 style reverse idler shaft,
and modify the early reverse idler gear to suit.
Brass fork needed a bit more clearance too.
This input shaft coupling needed a counter bore to clear the splines on the FTC mainshaft.
| Quote: | Originally
posted by westi
That's mad Alan.
dangerous
Mood: 591
| posted on September 16th, 2008 at 08:31 PM |
Solid spacer is required between 3rd and 4th on the pinion.
It's length is a tight fit to assist and maintain the end clearance of the 'Pablo' shim system.
I made it from 4140 solid bar.
Here is the FTC mainshaft, and early metal caged bearing for third gear.
I bought this from Bergs as old stock when the dollar was good.
It will get a hardened key also.
The ERCO third:
This overall 3rd ratio is very close to the stock 1500 beetle second gear ratio.
I will have to be 'on the ball' with the shifting!
Hubs have oil holes added:
Straight cut 4th gear.
1.2174 ratio combined with 5.42857 diff ratio will equate to 8540rpm a 100 mph.
| Quote: | Originally
posted by westi
That's mad Alan.
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on September 16th, 2008 at 09:35 PM |
Mmmmm, gearbox porn.....its always a shame that these parts and work are hidden away for no-one to see.
Al
westi
what the
Threads: 28
| posted on September 16th, 2008 at 10:01 PM |
love your work,as always you are the man.
i love it.
keep the volks porn comin
down sharon.
| posted on September 16th, 2008 at 10:30 PM |
the "model" hands are looking a little cleaner mate!! with ratios like these you'll think you're riding a big bike!!
Stanley
Threads: 270
| posted on September 17th, 2008 at 07:13 AM |
see how easy it is people.....
so I guess you'll be changing the the clutch thrust ring...
