| [ Total Views: 623120 | Total Replies: 964 | Thread Id: 66140 ] |
| Pages: 1 .. 16 17 18 19 20 .. 33 |
2443TT
A.k.a.: Ian
Threads: 69
| posted on April 30th, 2009 at 07:28 PM |
| Quote: | The heads comes with
alu bronze valve seats cut with four angle on intake and two angle plus radius on the exhaust.
Manley severe duty valves, ti retainers, OTEVA 75 dual valve springs and bronze guides.
The port is also blended into the valve seat, I will also point out that those heads are extremely good out of the box so be careful with
modifications, they are not like the american heads wich you have to modify almost everything.The Pauters will fit right on.
Does that make anyone else aroused?
66deluxe
Threads: 139
| posted on April 30th, 2009 at 07:36 PM |
Yes it does Ian.
66 Deluxe Beetle 2270 type 4
10 Subaru WRX Impreza
dangerous
Mood: 591
| posted on May 1st, 2009 at 06:32 AM |
I think something has moved "down there"!
I would still check spring travels
and have a look at the port with the valve removed. (for future "material" when you are alone and lonely).
You may want a bit more inlet spring tension.
I have seen plent of pics of those ports and yes,
nothing to do in there.
Definitely don't polish the inlet ports...as cast gives better turbulence and "tumble".
| Quote: | Originally
posted by westi
That's mad Alan.
Marko
Threads: 0
Mood: More power
| posted on May 2nd, 2009 at 12:36 AM |
Quote another board:
I have JPM heads in my 84 x 101.6 street engine with FK91/89 cam, 1 7/8 header and 50mm throttle bodies. Compression is only 10.5:1. The engine made
241hp @ 6950rpm and 278nm
JPM heads out of the box. Nothing modify. Valves is 48/40.
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on May 3rd, 2009 at 07:28 PM |
Marko bring this car of yours to the dyno day!! Would love to hear it on the dyno as would everyone else.
Flintstones
Threads: 69
| posted on May 3rd, 2009 at 10:47 PM |
| Quote: | Originally
posted by LIFE IN THE LOW LANE
put it on youtube for the rest of us to enjoy.
would love to here this motor scream
Marko
Threads: 0
Mood: More power
| posted on May 4th, 2009 at 03:11 AM |
| Quote: | Originally
Hahah, too far a way, it's my friends car and located in Finland. My own maybe ready next year and of course i come dyno.
2443TT
A.k.a.: Ian
Threads: 69
| posted on May 5th, 2009 at 06:01 PM |
Ok guys, finally an update. I'd been working on radiator mounts for a few weeks but between running out of materials and getting interrupted it was
hard to make any good progress. But the long weekend sure helped.
Ive made recessed mounts for the radiators and thermo fans into the floor as you can see. The fans are setup to pull air up, and there will be an
alloy sheet metal scoop fitted that goes over both radiators and forward a bit so that the radiator doesnt re-circulate hot air when the car is
running when stationary. They were originally going to be used for the watercooling of the heads, but now they are for the water-air intercooler(s)
the engine will be using.
Where the wires are hanging out is where the water hoses connect to the radiator, and also the air flows out. The exhaust slot is about 3" x 10".
The outer plate edge of the chassis had to be strengthened to support the roll cage so thats heavy 6mm plate, but is only about 400mm long. The inner
plate material and mounting points are all 3mm and everything else is 1.6mm sheet.
If only I'd known I was going to make these before assembling the car, putting the body on the pan etc... It would have been a lot easier to make. I
dont like welding and painting next to the car with the paint finished like it is.
Next on the list is a windscreen and the engine. I received an email from JP Motorsport again today and will be ordering a pair of heads tomorrow
from the looks of it.
Ian
Flintstones
Threads: 69
| posted on May 5th, 2009 at 09:37 PM |
Definitely one exotic machine Ian
D
2443TT
A.k.a.: Ian
Threads: 69
| posted on May 8th, 2009 at 12:14 PM |
Out of the blue yesterday I received a phone call from Johannes at JP Motorsport in Sweeden. How about that for good customer service and being
proactive. DRD should take a lesson from this.
So the last of the details are now ironed out, and I paid for my heads today. They should be here in Australia in 3 weeks!
reub
VWRX is gone...
| posted on May 8th, 2009 at 12:33 PM |
WHOO HOO.... can wait to see these dude
Reub
66deluxe
Threads: 139
| posted on May 8th, 2009 at 04:25 PM |
Thats great news and service from Johannes, were all looking forward to seeing these heads Ian.
mountainbug
Threads: 34
Mood: allways wanting
| posted on May 8th, 2009 at 08:38 PM |
absolutely no budget involved as it was from the start, Fanfuckingtastic effort. WOW. When do you stop to think.
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 1st, 2009 at 10:17 PM |
Hi Guys,
I received an email today from Johannes at JP Motorsport with a picture of my heads as removed from the milling machine.
From the looks of them they just need porting, seats, and guides. He is working on them now, and they will ship before the end of the day (sweedish
time) aparently. So with any luck i'll be completing the assembly of my engine inside 2 weeks! Woo Hoo!
| Error |
reub
VWRX is gone...
| posted on June 1st, 2009 at 10:38 PM |
They look great mate.
Reub
matberry
| posted on June 1st, 2009 at 10:40 PM |
| Quote: | Originally
posted by reub-revhead
x 10
Euro_67
Threads: 75
| posted on June 2nd, 2009 at 11:02 AM |
| Quote: | Originally
posted by 2443TT
From the looks of them they just need porting !
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on June 2nd, 2009 at 11:30 AM |
he he.. !
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 2nd, 2009 at 01:47 PM |
| Quote: | Originally
posted by Euro_67
| Quote: | Originally
posted by 2443TT
I only meant to blend in the valve seats so there isnt a step from the port to the seat. I suppose the need for that would be determiend by how
accurate their initial machining is. If they are built like a Koenigsegg they wont need it, and will do just fine.
| posted on June 2nd, 2009 at 10:25 PM |
Well Ian those pics signify good news for you after all the stuffing around you have copped and certainly do look nice!!
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 4th, 2009 at 07:48 AM |
| Quote: | Originally
Well it gets better!
On the 25/04/2009 DRD promised to give me a refund of my deposit minus a 25% re-stocking fee. I reluctantly agreed to this, but over a month later
still no refund arrived. Fortunatly I had made the deposit with a credit card, so I raised a dispute with my bank for failure to deliver goods and
then failure to return a refund.
Just checked my bank account this morning and the bank has ruled in my favour and refunded me the whole amount of my initial deposit!
I also just got an email from Johannes as well. My heads are finished and will be shipped this morning. How great a start to the day is this!
Ian
| Error |
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on June 4th, 2009 at 08:29 AM |
Great stuff Ian, glad to see things go your way and things are now back on track!
al
dangerous
Mood: 591
| posted on June 4th, 2009 at 08:32 AM |
That is awesome news Ian.
That lack of of response, even with a simple money refund, shows he was always a dishonest character.
That sort of thing really gets my gander up.
Even if it was just that restocking fee,
I would still want to find the plane fare and be taking it out of his hide within the 24 hours.
Wouldn't the world be great if it was as simple as:
-ring the guy
-pay the money(lots or little)
-Parts arrive in fair time
-being kept informed of any delays
-or told from the start"sorry I am too busy have all your money back",
But looks like your cool head has payed off and it has all worked out even better.
I think you will find most guys dont mind paying top dollar for quality ,
but when you have to pay for BS and lies that is just not on.
That is one of the reasons I very rarely have anyone do anything for me, even if I have to learn myself.
I understand people get busy and problems arise,
but I think most times people have a problem with vendors, a quick call is all that is needed.
...and PAYING customers always come before race cars. (but not at the neglect of family and health).
Enought of me on m soap box!
Cant wait to see them Ian!
| Quote: | Originally
posted by westi
That's mad Alan.
| posted on June 4th, 2009 at 11:40 AM |
Great news Ian. I've seen waaaay too many people get ripped off by overseas businesses which does certainly make me reluctant to deal anyone I do not
personally know of.
polak
A.k.a.: Adam Pawlowski
Threads: 49
Mood: definitely
| posted on June 4th, 2009 at 11:47 AM |
iv always tried to work out that picture at the bottom of all your posts Ian, and i guess finding this thread has answered my question..... holly crap
thats mental!!! i love it, this is the sort of engineering i was talking about on the subaru invasion thread, this is what we need more of.... keep up
the good work and post more update pics if possible, cant wait to see this thing out on the track....
Boostn
Threads: 28
| posted on June 4th, 2009 at 03:08 PM |
Nice nice nice!!!
good to see it all worked out in the end.
you are WAY better off with the jpm heads, the drd heads would have been a massive disappointment, just like his service.
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 4th, 2009 at 07:18 PM |
| Quote: | Originally
posted by Boostn
Nice nice nice!!!
Yeah i totally agree. I can just imagine what would have happened had i waited for the DRD heads. They would have leaked, and required re-machining
as they would have no doubt been warped. So glad I dont have to experience that!
Here's another pic from Johannes. These are the valve springs, support shims and titanium retainers that are on the heads. Seat pressure is
160-170lbs with this setup as they are on the heads right now.
| Error |
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 6th, 2009 at 10:40 PM |
Update time at last...
The a weeknd or two ago I fitted up the last of the trim and interior parts (except the seats). Windscreen wipers, windows all in etc... I want to
put some soundproofing on the floor before I go bolting seats into the car though. I still havent decided on the mirrors too. I have a pair of ones
that are painted to match the car, but im thinking i might just switch to a single carbon fiber mirror. Plenty of time to decided on that...
Had a slow start to the day today but I now have a set of barrels rough cut to length too. Ive setup for a 0 deck height. The piston shown is a
custom order CP piston, 22mm pin, low compression height and 36cc dish. Its also had the skirts teflon coated and the crowns ceramic coated and
polished. Tomorrows plan is to finish barrel machining and probably piston ring filing to set the ring gaps.
Heads arrive next week so I want to be ready to bolt them on and get stuck into header and intake manifold fabrication.
ian
2443TT
A.k.a.: Ian
Threads: 69
| posted on June 7th, 2009 at 06:53 PM |
Hi all,
Had a moderatly productive day today. Finished machining the cylinders to length, gapped the rings and fitted the rings on the pistons. Im now ready
for the heads to arrive next week.
Check out the compression height of these. Because of the massive stroke and 5.7" rods in this engine I wanted to keep it as narrow as possible.
Then of course I cut the back end off the car so it doesnt really matter now...
Tomorrow i'll be finishing the dry sump pump mount and making a plug to block off the distributor hole. Then hopefully the heads will arrive next
week.
Ian
VWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
| posted on June 7th, 2009 at 09:52 PM |
Coming along nicely
