[ Total Views: 139945 | Total Replies: 1114 | Thread Id: 67327 ]
 Pages:  1  ..  16  17  18  19  20  ..  38
Author: Subject:  Humpty's finally got off his arse and begun a real drag car project!
Memberhellbugged
A.k.a.: Daimo Pell
48's and straight cuts
Mood: Couldn't care less
posted on February 17th, 2012 at 02:05 PM
I've been using the same one you have humpty on the notch
Was given it by a Subaru dude who had read comparison testing articles and it came out on top for bang for buck
1/4 turn gave a fair amount of pressure increase tho, from memory it was close to 2 pds for a full turn, take it slowly up!
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on February 17th, 2012 at 08:31 PM
That's good to know.... I have yet to run the car with this in place.... Fitting the new fuel cell currently.... Might see if I can get a little dyno time when I get back from Sydney.... I'd like to get it base set before I hit the track.
FUCH your early!
http://www.noh2o.org/
MemberStanley
Threads: 270
posted on February 17th, 2012 at 08:36 PM
Get off the forum and get out to the shed.......:crazy:
Memberhumpty
Threads: 139
posted on February 17th, 2012 at 10:21 PM
You lot seen these before?
http://d5otzd52uv6zz.cloudfront.net/5b70537b-fdd1-41a2-8fd8-1d05885ca80d-350.jpg
http://catalog.rpmware.com/catalog/group/65317
200 bux according to the rpmware website...
FUCH your early!
MemberStanley
Threads: 270
posted on February 18th, 2012 at 06:46 AM
I have but again wondered about mounting options.
I think being turbosmart product quality wouldn't be an issue.
Memberhellbugged
A.k.a.: Daimo Pell
posted on February 18th, 2012 at 07:10 AM
i rekon tuck em up and see how it goooooes!
then do some development :smilegrin:
Memberdangerous
Mood: 591
posted on February 18th, 2012 at 07:37 AM
This is the best decision you have made in your whole post Humpty!
Make sure you take along some methods of fuel and ignition adjustments.
1. Get it running,
2. Get it tuned on a dyno,
3. Drive it.
Always in that order.
Any other order is false economy,
especially on race cars.
See you in Sydney dude!
Originally posted by westi
That's mad Alan.
Memberhumpty
Threads: 139
posted on February 18th, 2012 at 12:18 PM
For me it would be a direct bolt on replacement for what's on my turbo... Easy as.
1. Get it running,
3. Drive it.
I've wanted to do it all along Dave, but the problem has been finding a dyno shop willing to help set the car up.... The wideband AFR gauge is an awesome bit of kit, which I know has helped me hugely to get this far, but a little professional help is still needed, for such a finicky intake.... But I can tell you this.... The Holley is way more consistent and stable than the Weber!!!!
FUCH your early!
Memberhumpty
Threads: 139
posted on February 28th, 2012 at 11:26 PM
Thanks to what I witnessed on the weekend, the POS development plan has been ramped up a little....
I know I've been in denile for sometime, but we all know the car has finally made the transition into a drag/street car, as apposed to a street/drag car... So I have finally made the decision to build up the 2276 that's sitting on the shelf..... This was always the plan, but it's gonna happen sooner rather than later...
But I have a few questions on spec before I get it on the engine stand.... Cam is a WEB 86C with 112ยบ lobe centres, AA 94's from Rodney.... The special Weisco copies in Mahle barrels, 5.4" CB H Beams, CB Crank and the other usual stuff.... So..
First up.... The heads..... Currently have some Wedge Ports..... Too big really.... Oval Ports a better option?.... Any other similarly priced options that use OEM intake/exhaust flanges?
Second question?.... Head studs.... Currently have 8mm CroMo studs I got off Rodney.... No idea on the brand, but he says they are good to go... Will they be enough for upwards of 15psi or should I step up to 10mm studs.... Options?
FUCH your early!
Membercnfabo
Threads: 140
posted on February 29th, 2012 at 10:02 AM
i thought the oval ports have a bigger cc volume of the intake ports..seen it in a current hotvw's mag.....
what about the superpro's
Memberessex
posted on February 29th, 2012 at 11:09 AM
I have 10mm Raceware studs, if thats any help,
Memberhypo-vw
A.k.a.: Wayne Penrose
Threads: 82
Mood: hypo cruis'n
yes.gif posted on February 29th, 2012 at 12:40 PM
Currently have 8mm CroMo studs .... No idea on the brand... Will they be enough for upwards of 15psi or should I step up to 10mm studs.... Options?
Hi Humpty, it was great meeting with you on the weekend at WSID ..... just confirm with Rodney that the AA pistons that he sold you are the true-forged ones and not the cheaper version as he imports both types . The true-forged ones are the only way to go .
ATM we are using bugpack 8mm headstuds in Chris Boltons' 2387ml turbo engine at 15psi boost with no ill effect at all . We are getting perfect head seal and making 238hp @ the wheels . If you plan to run a lot higher in boost pressure I would recommend using the 10mm racewear studs as I use in my turbo oval . I would once again confirm with Rodney that the studs he sold you are superior quality , and if not he may be able to help you with some .
Well done for making the trip across our great nation to be with us at WSID . Team WPVW
FASTEST SPEED @ WARWICK 2011
FASTEST ET & SPEED WSID 2012
Memberhumpty
Threads: 139
posted on February 29th, 2012 at 06:16 PM
Well Chris.... I've been thinking and looking at a few different head designs that would better suit a turbo engines needs.... And I reckon the Super Pro 044 heads from CB look to be a very good option for an 'off the shelf' head.... Slightly small intake cc which seems to improve velocity, but with nice un-shrouded valves to get the gasses moving better in the chamber.... Flow is similar to the Wedgie's but with greater velocity... That's looking like a step in the right direction....
As for the studs and pistons I got off Rod... He did say when I purchased them, that they will be more than up to the task of 15psi+... The pistons do look very nice and the shop that did my balancing said they also looked and spec'ed up nicely... The race quality studs from Bugpack do look nice and price is very fair too... The Raceware ones that Dave Kawell suggested, which you run too Wayne, do look rather special, but I think might be going just a little too far for me.... I'm not searching for a 9 second car here.... 10's would be nice...:smilegrin: But realistically, budgets must be set at some point.... I still need to get a decent transaxle built... The current box is doing fine, but I think I'll be running out of gears when the stroker steps up.:spin:
FUCH your early!
Memberwhathaveidone
Threads: 98
Mood: Heading for 10.99
posted on February 29th, 2012 at 07:23 PM
does this mean the POS will be runniing at Warwick?????????????
Memberessex
posted on February 29th, 2012 at 07:37 PM
sounds like he's got something going on...
you got on the plane ok then Simon?
Memberhumpty
Threads: 139
posted on February 29th, 2012 at 10:27 PM
Oh if only.... If I could get sponsorship to cover the transport costs...... It's only a dream.... 2500 bux just to get to Sydney and back.... I doubt Warwick will ever see the POS run.... But I might make the flight over.... Just for a laugh. :smilegrin:
Sunday was bloody funny Barry.... The trains were down to Granville, so I had to bus it to there... Carrying a couple of tyres and a rucksack got some looks I can tell ya.... Then wondering around Central Station and Newtown was a laugh... But the biggest grins came at the airport check in and later in Perth on the luggage carousel... People were double taking the sight everywhere I was going.... All good but.... No extra charge to bring them back! :tu:
FUCH your early!
Memberhumpty
Threads: 139
posted on April 10th, 2012 at 01:59 PM
Originally posted by reub
:tu:
http://www.youtube.com/watch?v=NYtoGdHIOck
http://www.youtube.com/watch?v=sRNb1NZVXCQ
:love:
FUCH your early!
posted on April 10th, 2012 at 03:50 PM
wow...POS running...........:tu::tu: Cheers mate, but where's one WOT
Memberian.mezz
Threads: 280
posted on April 10th, 2012 at 04:07 PM
what have you done to the pos , it sounds like my old victa mower.
:lol::crazy::lol::crazy::lol:
Memberhumpty
Threads: 139
posted on April 10th, 2012 at 08:38 PM
In a fortnight.... Busy this weekend with a three day music festival.... Dyno next week I hope, then the track the week after.... All going to plan. :lol:
FUCH your early!
MemberStanley
Threads: 270
posted on April 10th, 2012 at 08:45 PM
You need to water your grass Simon.
Memberhumpty
Threads: 139
posted on April 10th, 2012 at 09:12 PM
That's what winter is for......:lol:
FUCH your early!
Memberessex
posted on April 12th, 2012 at 07:18 PM
hey Simon, have you checked out new Gonzo @ Volksworld show, seen on fb
Memberhumpty
Threads: 139
posted on April 17th, 2012 at 07:09 PM
Oh yes..... It's awesome!!!
FUCH your early!
MemberStanley
Threads: 270
posted on April 17th, 2012 at 07:14 PM
Hey Simon what do you teach?
Memberhumpty
Threads: 139
posted on April 17th, 2012 at 07:30 PM
Used to be a Design Lecturer at university, but moved over to high school teaching 6 years ago.... Started out as a Design and Technology Teacher, specializing in Home Workshop, Mechanical Engineering, Robotics, Fine Art Jewellery, Drafting and good old wood and metal work, but these days I'm a Visual Arts (formally painting, sculpture, print making) teacher, but specializing in Media Production (TV and Film) and Graphic/Industrial Design.... Both of which have been my profession (prior to teaching) for the over 20 years.
By the way.... Put hotter plugs in the POS today and took it for a blast around the hood.... Man what a difference that made!!!... Gonna book it in for some dyno time later this week I hope.
FUCH your early!
MemberStanley
Threads: 270
posted on April 17th, 2012 at 07:45 PM
Cool.......I thought you might be an English teacher which meant I had type any posts in word so I could use spell check......:lol:
Good to here pos is progressing well
Memberhumpty
Threads: 139
posted on April 22nd, 2012 at 03:45 AM
Just got word from VW Parts Unlimited..... My slicks are in transit!.... Yeah!
The car is done..... Been busy building a new engine and transaxle for the Bus last week, and have been driving it everywhere this week.... But finally had some time to work on the POS yesterday and today.... The last little jobs are finished.... The last time I was at the track the officials pointed out the crankcase breather was not legal..... Fuel tank is properly mount too..... It is now legal to race.....
Off to the dyno next week if I can book it in..... Stroker is this winters project..... And possibly a proper transaxle too..... Open to suggestions.
FUCH your early!
Memberessex
posted on April 22nd, 2012 at 06:39 AM
good stuff Simon, what didnt they like about the breather?
Memberhumpty
Threads: 139
posted on April 22nd, 2012 at 10:35 AM
I didn't actually have one.... Only the OEM oil filler/breather was in place.... The one that has a an outlet to the road and a outlet that goes to the air cleaner.... The don't like breathers venting/draining to the track and it's supposed to have a catch can devise built in.... So now I have both.
FUCH your early!
[ Queries: 40 ] [ PHP: 11.3% - SQL: 88.7% ]
