[ Total Views: 2857 | Total Replies: 35 | Thread Id: 100688 ]
Author: Subject:  When do you need a wing ?
Member55slug
Threads: 22
Theme: UltimaBB Psyche Red
posted on February 2nd, 2013 at 11:14 AM
Im in Auckland mate. Prostock car I mentioned licensing passes next weekend... Prostock
Membermodulus
A.k.a.: Peter Hill
Mood: modular
posted on February 2nd, 2013 at 04:15 PM
Back to the topic...
You may not ever need a (rear) wing. As a drag car, you probably don't need extra down-force (and drag) at the top end as you're not likely to be short of traction at higher speeds. However, a reduction of the lift caused by the beetle body design at high speeds is desirable, as the beetle's wing-like profile, coupled with a rather steep drop angle of the rear body, will create unwanted lift. This may be best resolved by a spoiler (rather than a wing) as Doug Sweetman and others have pointed out.
I can't find any *quantitative* information for the beetle, but *qualitatively*, I found these wind-tuft tests quite convincing in terms of separation of the laminar airstream (at least at 100 kph):
http://www.gerrelt.nl/section-aerodynamics/aerodynamics-wool-tuft-test.html
It would be great to reduce lift without the additional weight, bulk, drag and access complexity of a spoiler and relatively easy to perform back-to-back tests for efficacy.
hth
Peter Hill
1975 Type 2 Double Cab
modulus.com.au
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on February 2nd, 2013 at 05:33 PM
Were else do you put your tools and spark plugs ( holes) , chips & drink when woking on car . Wings are cool .
It isn't all about down force , but the sides all so helps to keep your car stable and straight at top end .
Membermodulus
A.k.a.: Peter Hill
Mood: modular
posted on February 2nd, 2013 at 06:51 PM
Instead of a drink tray, for longitudinal stability you can do this:
Peter Hill
modulus.com.au
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on February 3rd, 2013 at 04:14 PM
Don't forget the muffins and for westi somewhere to put his cancer sticks and lighter lol
Memberdangerous
Mood: 591
posted on February 6th, 2013 at 07:09 AM
Can you tell us more about this Adrian?
Originally posted by westi
That's mad Alan.
[ Queries: 40 ] [ PHP: 11.1% - SQL: 88.9% ]
