[ Total Views: 10658 | Total Replies: 214 | Thread Id: 1263 ]
 Pages:  1  2  3  4  ..  8
Author: Subject:  Astro's Oval - **now with twin ignition**
Member56astro
Threads: 74
posted on June 26th, 2003 at 04:29 PM
Some seat belt anchor points ....
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on June 26th, 2003 at 04:31 PM
and ....
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on June 26th, 2003 at 04:38 PM
Taking photos to engineer tomorrow morning. Once he gives the OK to go ahead then the body should be home by late next week.
Some parts have already been sprayed (fuel tank, ashtray lid, gear lever, etc.)
Couldn't get "Gunyah Grey" cause dulux (PPG) don't make the paints any more that were in the original formula. Plus my spray painter uses Standox paints anyway. We ended up using Mausgrau (LH7N - mouse grey). It's as close as I could get without being too much of a nightmare for the spray painter!
35MPG on 101.3kPa
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on June 26th, 2003 at 09:58 PM
Looking good Astro, what about the pan, anything happening there ??
Member56astro
Threads: 74
posted on June 26th, 2003 at 10:41 PM
Ahh yes, the pan :D
I've just had new ball joints pressed in, new tie rod ends also. BTW about half of the BJs and TR ends were sh1t quality and had to be sent straight back to where they came from - too sloppy out-of-the-box.
New gear selector bush and coupler.
Early peddle assembly is in and adapted to a kombi master cylinder but the clutch tube doesn't line up with the hook on the peddle tube. So I guess the easiest way to fix it is to weld on a new hook on the peddle tube in line with the clutch tube.
New cv joints, new Konis, new steering damper, new window rubbers and associated bits.
I'll put down a full run down when it's all back together.
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 10:47 AM
new pics
Got her home a few weeks ago, but just got the digital cemera yesterday!
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 10:50 AM
Cardboard cut-out for the gauges at this stage - just to work out where everything will go.
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 10:51 AM
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 10:56 AM
The dash will be covered with vinyl, along with the door sills, A-pillars, and above the windscreen.
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 10:58 AM
Mmmm.
Where will the stereo/MP3 player go??
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:07 AM
New dual-tone horns.
No more "BEEP BEEP"!
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:11 AM
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:13 AM
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:17 AM
This will make some people freak-out.
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:20 AM
35MPG on 101.3kPa
Member56astro
Threads: 74
posted on September 18th, 2003 at 11:22 AM
35MPG on 101.3kPa
Memberpyr0
flame-on
Threads: 123
posted on September 18th, 2003 at 12:29 PM
great work she's coming up a beauty cant wait for the next set of pic's:thumb
Member56astro
Threads: 74
posted on September 27th, 2003 at 10:24 PM
Me and my brother got the body back on today.
The floor pan had the tranny and engine already in, so we were daring and just dropped the body straight on. You wouldn't believe how easy it was. Heaps easier than dropping the engine and putting it back in when the body is on.
We did hit a snag though. :cry
I need to get about 6-8 grade 8 bolts to replace a few we snapped.
Bloody front seems too high still. Even after I took about 4" out of the centre of one of the middle torsion leaves. I guess we'll just have to wait until the fuel tank, spare tyre etc is back in.
Rear guards are on, doors on and a few rubbers in place. Everything coming along smoothly (sort of!).
35MPG on 101.3kPa
Memberbugboymatt
A.k.a.: Matt
Threads: 75
posted on September 28th, 2003 at 06:27 AM
Looking good mate :thumb:D
MemberGrey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
posted on September 28th, 2003 at 08:42 AM
Looking good Steve. I really like that colour combo on an oval.
Is that a real convert engine lid or di you get the holes punched or something. Its a good idea for a larger motor.
Member56astro
Threads: 74
posted on September 28th, 2003 at 07:27 PM
Nah, it's my original engine lid with the vents off a later lid grafted in. My panel beater did a great job.
No more stand-offs, hopefully.
Getting closer :bounce
35MPG on 101.3kPa
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on October 1st, 2003 at 02:08 PM
Great job so far.I may have missed it somewhere but what are you going to use to power this gem?In one of the pics we can see your wiper motor-but it doesn't look like the original set up-what have you done there?
Member56astro
Threads: 74
posted on October 1st, 2003 at 07:45 PM
Thanks for the interest.
The engine was one of the first things I spent $ on when I acquired the car a few years ago. It is a Pobjoy Stage I 1916. A little head work to follow, maybe. :D
The wiper motor is from a later model 12V 2-speed unit. It has been grafted onto the "carry frame" of the Oval's. I had to have 2-speed wipers to satisfy the RTA cause it's now on a 1970 floor pan.
35MPG on 101.3kPa
MemberBoozer
Demented But Determined
Threads: 129
Mood: What the crap?
posted on October 2nd, 2003 at 08:19 PM
Nice Job!:D:thumb That's s##t hot! good work mate!
Member56astro
Threads: 74
posted on October 18th, 2003 at 04:31 PM
Some front suspension work today ...
By the time I shrink the pics they look sh1t, so follow the link;
http://www.midcoast.com.au/~astro/rebuild_diary.htm
35MPG on 101.3kPa
MemberRobo
Threads: 120
Mood: Oval madness
posted on October 19th, 2003 at 07:30 AM
Looks like it's comming together very nicely, did you weld a complete new turret to it after the roll over?
Rob.....
Boxer Power
Memberbyronbus
dsk
Threads: 119
Mood: dsk founder
posted on October 19th, 2003 at 09:11 AM
:D Sweet, keep the pics coming
Member56astro
Threads: 74
posted on October 19th, 2003 at 09:22 AM
Robo
Nah, Dad got another Oval body (through Pells at Nambucca I think). I think it had also been in a prang but not as bad.
35MPG on 101.3kPa
MemberRobo
Threads: 120
Mood: Oval madness
posted on October 19th, 2003 at 09:16 PM
OK that explains it! I thought ya must have been a Master with a hammer and dolly how did ya roll it?....:D
Rob.......
Boxer Power
Member56astro
Threads: 74
posted on October 19th, 2003 at 11:24 PM
young
in-experienced
swing axle
flatish rear left tyre
right hand corner
UP SIDE DOWN
:cry
35MPG on 101.3kPa
 Pages:  1  2  3  4  ..  8
[ Queries: 40 ] [ PHP: 15.1% - SQL: 84.9% ]
