| [ Total Views: 166380 | Total Replies: 62 | Thread Id: 13811 ] |
| Pages: 1 2 |
T25Turbo
Threads: 17
Mood: Rollin' LO and Slow
| posted on October 12th, 2003 at 03:05 PM |
Problem.... Solution
If you guys are serious about track work, scientific tests on piston sizes and horsepower figures, I would think the benchmark would have to lie with
Electronic Fuel Injection + Electronic Ignition Control. (Haltech, MoTec)
I know everyone doesn't have the dollars associated with these mods, but surely you are grasping at straws comparing 1950's technology with
what can be had on todays roads.
You may quibble about 5-10hp here and there, but this won't mean crap when another turbo jap car goes sailing past you on the freeway with
airconditioning and cruise control.
I think its time to bring on the new wave.
Volkswagen should have persisted with the flat four thing, just look at Subaru.
I think the smartest thing anyone can do is cut their losses and implant a subaru motor with/without turbo and laugh all the way to the finish line
(and the bank).
Bizarre
| posted on October 12th, 2003 at 03:31 PM |
You are missing the point
Yep if we were after cheap power we would have gone Wes' route and put a jap donk in.
We are interested in VW power. That is why we drive them (fast and hard). Basically keeping them stock - not some hybrid. If we were after just power
a Jap grey import is the go.
We are interested in what you can do with a naturally asperated (read induction noise) flat for.
To each their own but the point of this is air cooled flat four
[Edited on 12-10-2003 by blue74l]
jakriz
Threads: 46
Mood: 2 headed
| posted on October 12th, 2003 at 06:02 PM |
T25turbo (don't know your name) I think that u are in the wrong section of the forum, I believe that we have a conversion section now, u may want
to go comment there. It still amazes me that people still make comments on posts when the comment is irellavant & insignificant
By the way, I've seen 4 wrx conversions in a vw & although they may be quick in a straight line, they still can't handle like a standard
engined beetle
Jak
Congratulations to Ben Durie for breaking the hillclimb record at Ringwood in his stroker beetle!
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on October 12th, 2003 at 06:15 PM |
| Quote: | Originally
posted by Ben Durie
Wes,
you are sprouting untruths again, 94's are thinner at the stud holes and the bottom, nothing like the std cylinder, and they do run hotter, Jaks
test shows little gain in power, not enough to justify the crankcase mutilation needed to fit em.
what the..?
last time i checked bbq plates were made of low grade mild steel. and they warp because they're usually heated unevenly, and have no support.
apples/bananas here dude. my 94's have been blasting their way around the country for more than five years. they're also about to be
transplanted onto a new motor. I'll try and get some photos for the faithless. I also wouldn't like my case to be butchered to fit
94's, get a machinist to do it. criminy.
If you have a cast B'B Q plate that is too thin it warps right ?
We drive with BB Q plate material cylinders, not ideal but cheap, if you want long life the thicker the better.
You don't need to be an engineer to know that if a metal structure is thinner it has to be weaker, more prone to heat distortion etc .
Of course its all been covered before.
regards
Ben
let sleeping dubs lie
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on October 12th, 2003 at 06:22 PM |
for some reason my reply was left off the quote.
in short, and without the swearing and smacking of my forehead:
bbq plates warp because they're unreinforced unsupported mild steel, heated unevenly and cooled unevenly.
my 94's are being re-used in another motor in a few weeks, i'll take some photos of what they look like after five years of abuse. the motor
they're in is perfectly fine, i just decided to jam some more power in the back of my dub. means new heads, and carbs and counterweighted crank,
same barrels.
this debate is so much fun.
*sigh*
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on October 12th, 2003 at 06:24 PM |
ahh.. now the reply has turned up in the middle of the quote..
freaky.
:alien
FirstName V LastName W
Threads: 0
| posted on October 12th, 2003 at 07:28 PM |
Hey Ben, man when are you going to wake up and smell the coffee, it is practically under your nose and you still dont get it.
As Jack and Peter said there is NOTHING wrong with the 94mm Piston and Barrell kits we have here in Australia today.
Get your head out of the sand and do some homework. Likening a 94mm barrel to a BBQ plate is like comparing apples to oranges.
I have also used both the 90.5mm barrel and the 94mm barrel on the same engine with more importantly the same static compression and quess what heres
a news flash for you there was only10 degress difference in engine temp between the two. The engine is still in the car now daily driven and shows no
signs of leak down or blowby.
If any one out there is looking at running a set of 94mm Pistons and Barrels with a std crank or a strocker than I would say go for it, as long as you
stay realistic with the static comp and observe all the rules of properly fitting all the tinware for the late dog house style cooling you can't
go wrong in my books.
Ben you just ain't keeping up with the times.
[Edited on 12-10-2003 by FirstName V LastName W]
Each to their own just remember what goes around come around.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 12th, 2003 at 09:12 PM |
| Quote: | Originally
posted by Ben Durie
Wes,
We are often testing , in fact I have a 94 x76 engine in my street car at the moment.
I found a crankcase with the area behind the fly-wheel cast thicker (filled in ) so I machined it for 94's on our bridge port type Mill.
So far it seems to make similar power to the 90.5 x75.5 engine that was in the car till a recent problem keeping the fly-wheel on.
Oh yeh it does make more heat.
So what your saying is a larger capacity motor runs hotter than a smaller one. You need to compare apples with apples. Again I am not stirring you, I
just want to see some accurate scientific data.
| Quote: |
Wes admit you are wrong 94s are thinner than 90.5s all bar the top bit.
When did I say 94's are a thick as 90.5's all the way down? What I said was
| Quote: | Lee, 94's are
not thin walled. They are thick walled cylinders just like stockies.
Which was in response to what I thought was Lee confusing a 94 with a 92. I didn't mean to imply they are exactly the same thickness everywhere.
It was a very general comment. But you have agreed that the top part of the cylinder where all the heat goes through is the same thickness.
jakriz
Threads: 46
Mood: 2 headed
| posted on October 13th, 2003 at 06:03 AM |
| Quote: | Originally
posted by Ben Durie
hi Jak,
In my opinion 4hp is not worth the machining of a larger hole to fit the barrels, removal of precious crankcase material weakens the weak
spots.
Ben, I have the greatest respect for u , but I'm surprised at your comments, maybe u havn't had a real good look at the graphs on the front
page??
regards
Jak
PS do u have any dyno figures for your 94x76? Pauls got 93.7@ the wheels
Craig Torrens
A.k.a.: Craig Torrens
Threads: 347
| posted on October 13th, 2003 at 08:46 AM |
| Quote: | Originally
posted by Ben Durie
hi Jak,
spots.
Wes,
Turbo Guy,
I beat several WRX cars at King Edward Park on the weekend , and I don't have 4wd or a turbo .
the rest don't require an answer.
regards
Ben
[Edited on 10-12-2002 by Ben Durie]
You don't believe in 94's, yet you built a motor with them just to try !!!!!!!!!!!!
Is this because you're only just doing the reseach ??
Maybe if you start 8 dowelling your flywheels they won't come loose.......oops you don't believe it that do you
CONGRATS to Colin, for yet again another 94mm (1916) powered VW winning the state hillclimb series, now 8 years in a row a 1916 has won:thumb
56astro
Threads: 74
| posted on October 13th, 2003 at 09:50 AM |
Man, I gotta have one of those 1916 thingos with them 94's in there". They're the one all the fast cars have aren't they.
Come on Craig, "8 years in a row", that's just being absurd now!
35MPG on 101.3kPa
jakriz
Threads: 46
Mood: 2 headed
| posted on October 13th, 2003 at 06:55 PM |
Will do Ben, i've got brand new total Seal rings in there now & I'm having the barrels & pistons ceramic coated over Xmas to prolong
their life.
Jak
Stanley
Threads: 270
| posted on October 13th, 2003 at 08:06 PM |
| Quote: | Originally
posted by jakriz
PS just a little foot note, 90.4 hp with 90.5 pistons, & 93.6hp with 94mm pistons, those numbers are a little weird huh??
Does that mean I can expect 87hp out of my 87 mm pistons ?.....:P
[Edited on 13-10-2003 by kafer69]
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on October 13th, 2003 at 09:27 PM |
i think he was kidding, ben...
lets call this the "apples and oranges banana post"
anyone care to explain how 'leakdown' tests are done?
amazer
kombi pilot
Threads: 308
Mood: Peachy!
| posted on October 14th, 2003 at 12:05 PM |
Leak down tests are easy. I filled my kombi up with 4.5 litres of oil, ran 100kms and had it all blown out the breather into the air cleaner. Still
motored along at the speed limits though. I love VW engineering.
hehehe when is a leakdown test successful, when you find you have plenty?
[Edited on 14-10-2003 by amazer]
56astro
Threads: 74
| posted on October 14th, 2003 at 07:14 PM |
Hehe
Bit like a brain scan, hey Amazer!
35MPG on 101.3kPa
70AutoStik
Threads: 18
| posted on October 15th, 2003 at 01:01 AM |
Ben, I must take issue with you: Please don't ever call Wes "scientific." He's an engineer, not a scientist, never could be -
his ego would never allow him to learn anything. One day I'd love to find out what kind of engineering he does, because it obviously has nothing
to to with engines.
At least you finally got him to admit that reducing the cooling surface area will not increase cooling efficiency - i.e. an increase in energy
throughput will result in higher temperatures. You'll never get him to understand that oil and head temperatures are not necessarily going to
reflect piston and cylinder temperatures accurately. I have seen tests done with a laser surface temp guage demonstrating the increase in surface
temprature, but the important issue here is the eveidence seen in the effects on the pistons and cylinders themselves.
I do not know of a highly experienced builder who does not say that the 94s run hotter and therefore should not be used on type 2s and 3s. As has
already been pointed out, Wes does not build, or even run, VW engines...
It seems there are a lot of situations where 94s can be run quite effectively and reliably, it's just a shame there are people jumping to
conclusions and telling everyone that they therefore don't have any issues.
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 15th, 2003 at 08:32 AM |
| Quote: | Originally
posted by 70AutoStik
Don't you fix photocopiers for a living?
| Quote: | One day I'd
love to find out what kind of engineering he does, because it obviously has nothing to to with engines.
A lot of my work involves finite element analysis. A bit of stress analysis and thermal analysis of large industrial equipment, furnaces, rotary
coolers. But hey I will never know as much as someone with your experience....
| Quote: | As has already been
I ran 1776, 1835, 1915's so I think I have some idea.
That's about all I have to say. The rest of the arguing on this thread is retarded. The 94's run hotter arguement is demented, since it is a
larger engine with more power. I mean an engine with dual carbs will run hotter than one with single carbs if they are both driven flat out, so does
that mean everyone should run single carbs? Get real. 94's have an extensive track performance with many reputable engine builders. If people
want to stick their heads in the sand and not use 94's, so be it. It's not my loss.
VWCOOL
Threads: 235
Mood: happy to help
| posted on October 15th, 2003 at 08:39 PM |
Jakriz, I can see why you wanted to retain your 'baseline' intake setup for test consistency - but your thinking is, unfortunately, flawed.
Let's face it, not changing your tune (either jetting or ECU) with an engine hardware alteration is something that - with respect - would get you
laughed off any LS1, WRX or Mustang forum.
As for 94s, I laugh and laugh and laugh at people who want to throw away high-quality VW componentry and big $$ to risk the unknowns of aftermarket
cranks and/or the evils of chopping out the reinforcing inside a VW case.
The use of 94s with a stock stroke has several benfits imo: Firstly, it doesn't upset what ios a reasonably successful stroke/rod length ratio
(ie: doesn't put extra side load on the piston skirts/rods); The bigger bore allows the potential unshrouding of valves for better breathing, and
they create higher peak airflow through the ports earlier in the rev range (good for throttle response and torque with carbs). The 'heat'
myth is, to my mind, Berg propaganda from the 1960s. And thin walls around the base of the barrel? Der, so what? No heat load down there - it's
below BDC. If you know what you're doing, you shouldn't be dropping the barrels on concrete anyway. The old 'making teh holes too
big' argument, too, is halloween. The static and dynamic loads of the piston/barrel combo are in fact spread over a larger base... 'too much
metal being removed'; is like claiming a larger poached egg ring is weaker than a small one...
Apart from routine care with over-boring of cast-iron V8s to prevent dropping into water jackets etc, no other engine, to my knowledge, has any
discussion/argument such as this, based purely on arbitrary numbers relating to size of bore...:P
[Edited on 15-10-2003 by VWCOOL]
Pay your debts, CxxT
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 15th, 2003 at 09:26 PM |
| Quote: | Originally
posted by VWCOOL
And thin walls around the base of the barrel? Der, so what? No heat load down there - it's below BDC.
To prove your point for you, I have some interesting images for you. Unlike some people who come here to mouth off, I didn't read these in a book
or copy them from elsewhere. I actually cut up some barrels to see the difference in wall thicknesses. How many people can say they've done
that.
Here is a 92mm at TDC.
| Error |
VWCOOL
Threads: 235
Mood: happy to help
| posted on October 15th, 2003 at 09:29 PM |
Lol... thanks... That looks spooky!!
Bizarre
| posted on October 15th, 2003 at 09:30 PM |
Hey Wes
You must go to the same shrink as me!
He showed that picture to me as well!!!
I thought it was 3 nakid ladies and a jar of honey!!
56astro
Threads: 74
| posted on October 15th, 2003 at 09:33 PM |
If you stare at that image long enough you will see a naked lady sitting on a chair infront of an open window!
:P
35MPG on 101.3kPa
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
And here's a shot of a 92mm cyl at BDC. You can see that the lower fins will not see much of the engines heat load.
I was investigating the effects of the combustion heat flux on the cylinder wall and fin temperature distribution. Alot of people will not realise
that a cylinder wall can be too thin, but it can also be too thick. Thick barrels don't cool as well (before people mouth off at me, the chief
engineer of Tatra agrees with me). And thin barrels are subject to distortion, not from being thin and weak, but because they are more subceptable to
even cylinder temperatures around the barrel circumference.
I agree 92's are too thin, but I do not think 94's are being too thin. But hey, everyone can listen to who-ever they want to listen to.
| Error |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 15th, 2003 at 09:35 PM |
| Quote: | Originally
posted by VWCOOL
Bet you can't guess how I made that image.
speedster356
A.k.a.: Peter Mcleod
Plastic not Classic Racing
Threads: 256
| posted on October 15th, 2003 at 10:21 PM |
I too have been cuttin up p/c's on the trusty band saw at work. These are my 94's after only a few 1/4 runs! Yikes.
| Error |
HotRodMatt
If it's old or rare - cut it!
Threads: 361
| posted on October 16th, 2003 at 07:01 AM |
Explain Ben?
Pretty simple - it's not the 94's it's the builder fucking up!
Many many 94'd engines have been stripped without these conditions.
Many stock 1600 have been pulled out shot too!
(BTW - I have 90.5's so i am not biased).
jakriz
Threads: 46
Mood: 2 headed
| posted on October 16th, 2003 at 07:11 AM |
VWCool ( I wish people would put their f%$#king names), we are not on any other make Forum, so lets stop making that comparison, & besides, how
many WRX's do u know that have changed their bore size?
Right from the start I've never made claim to knowing anything more than I've stated or then I have actually done. This 2027cc is only the
7th engine that I've done, so I'm no expert & I'm learning more & more everytime.
As for the erellavant comments on the rods & crank, my 73mm crank is actually a Sabaduzi crank that has been offset ground for the Cevy journals
that then makes the 73mm stroke. U do know offset grinding is don't u?? & my rods are actually 5.7 inches long, a standard rod is about 5.394
or sometihng like that, so my side loads on the barrells are better than standard ( u obviously didn't know my engine combo before making this
reply). I also didn't have to remove one iota of material to get the crank & rods in the case, & just as another example, my good friend
Paul who also races with me didn't have to remmove any material to get his 76mm crank in either................
Just as a general note, how many engines have u built, high hp ones that is.
I only made this post as I love talking big hp engines with other vw people & I was tired of being on the yank forums talking to people with a
1776 & kadrons that makes 300hp. I thought that me posting the dyno graphs would let people know that I wasn't just talking out of my asre
& show them some real dyno figures.
I just want to talk shop, not shiitt
regards
Jak
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on October 16th, 2003 at 08:33 AM |
Ben,
You and Autostik like to take everything I say as out of context as possible.
The main idea of what I have been saying is all the crap people dribble about the theoretical side of which cylinders is crap, and most of them
don't know enough to even justify what they are saying. I've looked into the theoretical side in great depth, but prefer not to bore the
forum people with the details.
As anyone that knows anything about engine develop knows, the theory is a great base for somewhere to start, but it is rigorous testing that proves if
something works or not. That's what we should listen to.
That's why I listen to what Jak has to say. He has unbias test data from his own car.
I also listen to what you (Ben) have to say, because you have built more engines than I ever will, and have a lot of experience. The problem I have is
I think you are a little biased at times, so I am sceptical of what you say. That's why I ask for facts not opinions.
Everyone here should look at the track record of various engine combo's and make their judgements from there. It doesn't take much to see
94's have an extensive track record with some very respectable engine builders.
Ben, stop getting so offended by everything. Why does it effect you whether people want to run 94's or not.
Cam
Threads: 187
Mood: addicted
| posted on October 16th, 2003 at 08:51 AM |
| Quote: | Originally
posted by jakriz
regards
Jak
*ROTFLMAO* Oh that's sooo painfully true!
All these drop a "scooby motor in" people amaze me. I don't see the fun in that. This way you're developing, building and testing
your own engine. Flow benches, dynos, etc... Are so much fun and really add to the racing experience (well I feel like a V8 supercar engineer when
around this gear anyway )
Wes is probably the biggest conversion head around and has he started preaching? NO!!!
Forget Rex motors unless you want a quick power fix and some quiet driving. Plus I personally think these engines are past their prime when it comes
to club use. I see heaps of them with big $$$ upgrades at club events here and they're not that special. So why would I drop a heavy water cooled
motor into the arse of a sprint beetle? Sure, it would give a bigger power increase in a lighter car. But comparing a WRX (complete vehicle) to
Jak's car and saying a WRX will "go flying past" it is BS. Lets look at a WRX simple 1/4 mile times. They're what? 15's high
14's on a good day. Jak could do that (IMHO) with his eyes shut.
God! when will people realise sprouting numbers is a pissing contest. People take some figures from motor magazine (which have been quoted by the
manufacturer about their original concept development engine of an o/s model, prior to EM control crap, etc...) and figure thats what their VW is
going to pump out at the rear treads... Gimme a break! It all comes down to what happens at the track. I saw a 425KW (at the rear wheels) Soarer,
caged, on slicks, etc... at phillip island not too long ago. It was useless. Finished up tailing the cars it went out with by a large margin. The
thing had no power band, if he had of stepped on it the thing would have just turned around. And what's the point of that?!?!? The same thing
happens whenever any punk takes some hightech street/drag motor equipped track car out for a circuit day. It's pathetic really. You need as flat
powerband as you can get. Unless ofcourse you have mass amounts of downforce, big slicks and can afford to take track data from each track and set-up
6 close ratio gears and full suspension set-up accordingly each time you go out.
I would love to see a WRX equipped beetle at the next dyno day, see the power increase over something like Jak's. I guarantee there won't be
any pointing and laughing. I'm yet to be convinced about a/market conversions in anything other than something like a late model kombi for
something like off roading and/or towing.
just my rambling $0.2
Cam
| Pages: 1 2 |
