[ Total Views: 2499 | Total Replies: 53 | Thread Id: 16892 ]
Author: Subject: Oval progress
posted on December 27th, 2003 at 07:09 PM
Yeah OK that will work i was think the other way for some reason.... but no harm measuring forward
Make sure it dont look too odd by being either back or forward out of position...
I saw a mustang once that the guy put a roof in and he had it way to forward..
if you can sit your seats in the car as well maybe that might give another idea.
Keep up the good work
Membernbturbo
Threads: 89
Theme: UltimaBB Powder
posted on December 27th, 2003 at 08:47 PM
It's got to go in exactly the right position for the curve in the roof to line up.Will probably get some distortion when they make a new lip around the opening,but they are good at their job so should be able to get it right
Membernbturbo
Threads: 89
posted on January 12th, 2004 at 09:29 PM
Update
Trailered it to Adelaide last Monday for it's swim and had to take the NB down today for it's first service,so called in to check on my baby-it's now bare metal and not one piece of rust to be found and only one small bit of bog on LHR 1/4 panel covering a small dent-about 50mm by 80mm.Bloke reckons he's done dozens of Beetles and this is the cleanest one he has ever seen.Turned out to be a good buy.Forgot to take a camera.
MemberFlintstones
Threads: 69
posted on January 13th, 2004 at 05:49 PM
Hi NB,
You've come along way with you oval now, it's really starting to take shape.
Lucky man you are with that sunroof. I've been looking for years...extremely difficult to get a hold of.
Membernbturbo
Threads: 89
posted on January 13th, 2004 at 08:40 PM
G'day Dino
You are right-but a long way to go yet.Have just finished for the night-machined up some injector pockets from 19mm round bar and have trial fitted one into a modified Type4 fuel injected manifold.Have cut of the original pipes off flush with the cast end that bolts to the head and drilled into the side of it to mount the injector boss-looks like it will work ok.Can weld some pipes back into the cast end to still end up with a centre throttle body.This looks like no cutting of the engine bay.Will take pics
MemberFlintstones
Threads: 69
posted on January 15th, 2004 at 09:42 PM
NB, if you have the fuel injected manifold, don't these have the injector bosses already incorporated into it, unless there is something I'm missing??? or are you using a different type of injector......
Membernbturbo
Threads: 89
posted on January 15th, 2004 at 10:30 PM
You are correct-but those holes are too small and in the wrong spot-injectors hit hard on the body.I can plug them and fit the bosses higher up so everything clears the body The fuel rails I made were the biggest headache,but I can now use fuel hose onto the injectors,so allows flexibility with the rails.I have found a real small pressure reg.from a Toyota with the right value-also much better for room issues.Have to machine up a small boss and weld it directly into the end of my rail.
Membertyp-fre
Threads: 87
posted on January 16th, 2004 at 10:38 AM
its looking goood
dom
Gehts notch?
|.. ohhh shit!! wrong turn:P
MemberFlintstones
Threads: 69
posted on January 16th, 2004 at 07:54 PM
Ah..now I'm with ya, body clearance.
I was checking out the pics of your surge tank, where are you going to mount that?
Membernbturbo
Threads: 89
posted on January 16th, 2004 at 09:05 PM
Goes into the bottom of the original tank-will have about 50mm hanging from the bottom.Have drilled holes in it that will be 110 mm from the bottom of the tank and facing the front of the car-should keep fuel in it under acceleration when tank gets low.Can have 10mm supply pipe and will use 8mm for return.
Membernbturbo
Threads: 89
posted on January 29th, 2004 at 10:39 AM
Update
Brought my Baby home from Adelaide yesterday after the swim.It is now at the painters being undercoated.It was in black etch primer when I picked it up.Have had 1 mudguard painted in Double Yellow to check the look.I am putting the car in the Motor Show here in Feb. as an unfinished project.Mine is the only one entered so far-should do OK then
MemberCam
Threads: 187
Mood: addicted
posted on February 17th, 2004 at 03:59 PM
Must be satisfying to see the body bare know that most of it is downhill (in a good way, ofcourse) from here:)
Can't wait to see more pics. This car should be awesome!
Membernbturbo
Threads: 89
posted on February 18th, 2004 at 10:02 AM
Yes it is good to see some progress.Have put guards and bumpers and all lights back on for Motor Show this weekend.It is in grey 2pack primer now with one yellow guard.Booked in for mid March to get sunroof fitted and the full paint job.Have just had new laminated front screen cut and all side windows being made new with a bronze tint in the glass.Will get that stick on window tint put on the Oval.All 1/4 window frames and pivots being rechromed. Looking for completion by Xmas this year.
Membernbturbo
Threads: 89
posted on February 27th, 2004 at 08:00 PM
Show pics
This is how it went to the show
Membernbturbo
Threads: 89
posted on February 27th, 2004 at 08:02 PM
Our 5 cars entered as a Family Group
MemberFlintstones
Threads: 69
posted on February 27th, 2004 at 09:50 PM
You got a Val as well!! awesome man :thumb
My dad had one like that. Didn't have it for too long though. He did have a VC for ages, still like those :D
Membernbturbo
Threads: 89
posted on February 28th, 2004 at 06:58 AM
Yeh-had one of those years ago and a VG.
MemberCam
Threads: 187
Mood: addicted
posted on March 5th, 2004 at 08:31 PM
Man, that rear shot is hot as!
That exhaust is a mad idea too. Plus Porsche fans look the buis.
MemberFlintstones
Threads: 69
posted on March 5th, 2004 at 11:59 PM
Hi NB,
a few weeks ago I was checking out a VC with 20" wheels, mini tubbed, and twin turbo v8 with a perspex bonnet to show it all off!!!
really nice looking car :thumb:thumb
so is the oval at the beaters now?
Membernbturbo
Threads: 89
posted on March 6th, 2004 at 10:47 AM
The VC sounds like a real beast-is it a street car?The Oval goes in mid March.Two full resprays B4 mine.They are still trying to get their head around fitting the sunroof and how best to attack it.
MemberFlintstones
Threads: 69
posted on March 6th, 2004 at 07:04 PM
yep the VC is street rego'ed.
Engine I believe was built by Solo Hercules and the turbo setup was fabricated by Pac Performace.
Not long to go now!!!!
MemberAlex Holzl
A.k.a.: Big Al
2332cc of pure BALLZ!!
Threads: 85
biggrin.gif posted on March 7th, 2004 at 06:33 PM
ive got the same car with the same front areos but smothies on the back... Looks awsome man!!! :thumb:thumb
Membernbturbo
Threads: 89
posted on March 8th, 2004 at 07:48 PM
Picked up all my new glass today.Had all the 6 side windows made new in a bronze tint and toughened with the legal markings etched in the glass.Front screen is laminated with a slight tint and is also marked to show its legal.
Membernbturbo
Threads: 89
posted on April 28th, 2004 at 01:14 PM
Still on the go
Things have slowed up a bit-need all the spare cash for a deposit on an investment property and the painters are up to their xxts in work any how.Finally got my laser cut engine lid badge back and will now tidy it up and send it away with the Deluxe one to get coated in 24c gold like the others.
Membernbturbo
Threads: 89
posted on April 28th, 2004 at 01:15 PM
Another
Membernbturbo
Threads: 89
posted on April 28th, 2004 at 01:20 PM
Another
MemberXXX-1.8T
Threads: 454
Mood: Oil Drippin
posted on April 28th, 2004 at 01:30 PM
lookin sweet:beer
