| [ Total Views: 1438 | Total Replies: 36 | Thread Id: 23211 ] |
| Pages: 1 2 |
LOWBUG
Threads: 33
Mood: OUT OF CONTROL
| posted on June 8th, 2004 at 10:12 PM |
MY engine owes me about 25K and I'm pulling it down again for more up grades.
Good Luck and if you want more confusion than this join a VW club
56astro
Threads: 74
| posted on June 8th, 2004 at 10:43 PM |
Yeah, what Moose said.
Also go back over the results of drag results if that's what you're after (a drag car). Both here and the US.
Normally aspirated or turbo (NA = Craig Torrens, Craig Paton just to name 2).
Do your research and know why you make the choices you do.
Good luck
35MPG on 101.3kPa
boof2332
Threads: 120
Mood: Sympathetic
| posted on June 8th, 2004 at 10:56 PM |
Danny,
A few things with that spec sheet..
Carillo rods $$$$$$$$$$$
Fk10 cam ...I have one for sale brand new because i decided it too big for my 2332 street motor. Still driveable but at high revvs.
I also think it is a major over kill with the 1 7/8 exhaust...2110 with not real big valves.and the fk10. Would make heaps more torque with a 1 5/8
header.
From what the boys have said, if you do not want to stroke it, then call Stan.
If you do want the stroker option, then get the parts from overseas and get someone local to assemble it. I have recently bought all my stuff from US
and am still getting bits and pieces all the time. Drop me a u2u or call me and I will tell you where I got all my stuff...(Scat, berg, cb, action
imports, Kustom 1 etc...)
Be patient, and hunt around as there are lots of traps and unfortunately I fell in a few on this little excursion.
Matt
0416 115 993
jakjones
Threads: 3
Mood: Settled
| posted on June 8th, 2004 at 10:57 PM |
| Quote: | Originally
posted by LOWBUG
So what are the specs and who built it for you. ?
what are the upgrades.
AdrianH
Threads: 20
Mood: rebuilding again
| posted on June 9th, 2004 at 08:42 AM |
If you go to an 82mm stroke, go 94s - there is no replacement for displacement - Its easier to make big HP with more CCs and keep it (relatively)
reliable.
I wouldnt buy carrillo rods unless you are intending to make some serious HP. There are others that will work just as well for less than half the
I have a friend in Canada that has a 68 beetle, Berg 1800 (74 x 88), FK8, IDAs, 40 x 37.5 Berg heads, 4.125 R and P and short gears (1.21 4th I
think). He runs high 13s NA and mid 12s with a 70 shot of NOS. This engine was built in the 80s.
My 2110 has an 86B, 82 x 90.5, CNC 044s 42 x 37.5, 48 DRLAs, 3.88 R and P stock gears. I have only run in the rain 15.5, I guess in the dry it would
run high 13s with some seat time and tuning. With the gearing I only use 3 gears in the 1/4 - and it sits at 3000 rpm at 65 mph.
Just for the record - 12s are fairly rarified airs - its something to work towards, a car that runs 13 - 14 seconds is fast enough to get you into a
whole lotta trouble, there wont be much on the road that will keep up in the 0 - 60 mph range...
What about V force ?? They are local to you...
US - I would look at VW paradise, Mark Herbert, Geoff Hart, Heads Up, Marty Staggs - they know how to make Horsepower. Ive had dealings with Mark - he
is a very straight up guy, and he made 2oo hp with Kadrons !!!
[Edited on 8-6-2004 by AdrianH]
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on June 9th, 2004 at 08:57 AM |
as the saying goes:
if you're going to stroke it, stroke it!
Jon
boof2332
Threads: 120
Mood: Sympathetic
| posted on June 9th, 2004 at 10:01 AM |
Adrian,
How does the 86b go, thats what I replaced my fk10 with, motor not yet finished.
I got told by a friend of mine who is from cal-look.com
club in the states, that its one of the best "street" cams on the market. Thats whyI bought it off Craig Paton.
Matt
[Edited on 9-6-2004 by boof2332]
LOWBUG
Threads: 33
| posted on June 9th, 2004 at 02:54 PM |
I build my own engines, engine size is 2007 that comprises of 78MM berg crank 90.5mm pistons street eliminator heads k8 spec cam made here in
australia scat long rods big valves and lots of little tricks as well as spending money on things like proper balancing clearancing doing it right,
not cutting any corners.
The next upgrade which has also comenced is turbo.
For other details u2u me
AdrianH
Threads: 20
| posted on June 9th, 2004 at 08:56 PM |
86b is basically the same as a K8. Goes good, idles at 800 rpm, pulls well of idle and kicks arse from 3500 - 7000 rpm. Compression is at 9:1 at the
moment.
| Pages: 1 2 |
