[ Total Views: 147723 | Total Replies: 151 | Thread Id: 29235 ]
 Pages:  1  2  3  4  ..  6
Author: Subject:  48ida / 11sec bug ( Dragster Mag Pic ) 19/9/09
MemberLIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
posted on March 23rd, 2007 at 10:37 PM
Originally posted by RAZ34
I'm keen to take it to Summernats to run in the Dyno comp. This years winner recorded 86.15 rwhp. I mentioned this to Pete and almost had him until I said we should also enter it in Tuff Street.
Hopefully I can contine my Warwick winning streak at Mini Jam so Brennden, can you wear the same clothes you wore that week-end.
(Al , Pete will answer the technical question )
[ Edited on 21-3-2007 by RAZ34 ]
The trusty RBT shirt eh LOL. But you guys did chip in and buy me one to look the part so should I wear that one instead??? Or is it time for team shirts????(colours to hide stains from working on cars would be nice!!) should be a good weekend with a decent field in All motor from what Ray Box was telling me the other night.
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
Mood: faster ,faster ,Done
posted on July 23rd, 2007 at 11:32 PM
I keep Rods post about his beast(48ida) continue on .
New roll cage up date for safety reasons ,hopefully helps car to wheeeeeeelie !!!
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_3713.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_3716.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_3715.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_3718.jpg
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on August 22nd, 2007 at 12:49 PM
Any more updates/photos?? :bounce
posted on August 22nd, 2007 at 05:29 PM
I'd imagine after the weekend if all goes well there will be some more pics and time slips....
MemberRAZ34
Threads: 1
posted on August 22nd, 2007 at 08:32 PM
We took it for a run at Willowbank last Wednesday night. Car feels safe and sound with new cage and seat. I managed 3 two-step launches . 2 were OK. Pete might put some video up when he has time between building and maintaining all the cars. Thanks to Pete and Dave B for looking after me on the night.
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on August 22nd, 2007 at 10:52 PM
Rod had 5 runs ,best was 12.16sec at 108.88mph .Best mph on night was 109.65mph and best
60ft was 1.602 . All so half track was quick at 7.64sec 88.86 mph but top end was a little off (Air ,humidity ) We made a few carb changes but didn't ,show any gains .
Car times should be good 11.90's with the above mph and sixty foots .
Happy but no eleven sec pass gives me a headache!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MemberBoostn
Threads: 28
posted on August 23rd, 2007 at 09:24 PM
What a Hot "ROD"..........get it? hahaha
very impressive times dude, it would put some turbo cars to shame!
VOLLKOMMEN ART
nick@vollkommenart.com
Speed and Style
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on September 6th, 2007 at 02:42 PM
Any more pictures of various components of the car that have been customised to match the engines performance.....:smilegrin:
MemberAdsman
Threads: 21
posted on October 4th, 2007 at 10:43 PM
Very nice work. Keep us up to date with your progress.
What my garage isn't messy........Well chaos is a form of order isn't it?
Member063bug
A.k.a.: Alan
Threads: 0
Mood: just crusin'
posted on October 5th, 2007 at 01:07 PM
Sorry to bring it up but are there any updates on the events of the Warwick Weekend.
Memberdangerous
Mood: 591
posted on October 5th, 2007 at 03:37 PM
Looks like the Crown wheel and peanut is broken.
It was a Klingelnberg 4.125. Perhaps a stronger tooth form next?
Good excuse to change the ratios for more rpm!
Rod will most likely run his engine in the chop top car for the Jamboree Re-run.
Perhaps elevens in that car?
Originally posted by westi
That's mad Alan.
posted on October 5th, 2007 at 06:40 PM
Second that one dangerous. There was a lot of metal in the oil when we drained it and a few bigger bits as well. Troy also could feel some larger bits of teeth through the drain hole that wouldn't fit through it. So it should be good to see it when Pete pulls it apart. In the mean time Rods engine into the choptop for the Jamboree. Now that should be good!!!
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on October 10th, 2007 at 09:23 PM
Yep !! crown wheel let go but pinion teeth still intack .Broke teeth, deep down on crown wheel . Spool fine ,axles fine ,gear box case fine .
Yes , we are ! going to put Rods motor in choptop for Jambo rerun ,Nov 3
With motor and box out ,you can see rollcage bars down to forks
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/101_0027.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/101_0021.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/101_0024.jpg
posted on October 12th, 2007 at 06:34 AM
A couple of tubes of devcon should get it back together shouldn't it???LOL
Good work ROD!!!
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on January 30th, 2008 at 09:18 AM
Mini Jam is on the week-end after Portland so Rods car has to ready before hand . Dangerous has work wonders again repairing tranny .
Over last week-end fitted all back together and finally fitted spring plate retainers ,found that the bushes pounded out quite bad on both side of car. Had to pop spring plate down off stop so to get bolts to line up (longer bolts ).All so found outer right side with rust pits ,that wound damage new brass retainer ,so change spring plate .
Decided to leave out inner urethane bush .They say that the brass bush free's the movement (travel) up ,which helps car taking off and stop toe in when everything pushes forward (worn bushes ).
Was looking for a test run at track tonight but weather looks crap here .!!!!
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_0513.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/100_0512.jpg
posted on January 30th, 2008 at 06:30 PM
There was a storm out that way just after lunch. My neighbour was out there on a drilling rig and it poured rain,thunder and lightening so doubtfull it TnT will go ahead as weather is mighty unstable.
Good to see the spring plate retainers finally in their new home Pete!!(and the right ones too)
MemberStanley
Threads: 270
posted on January 30th, 2008 at 07:02 PM
Yep been raining Amberley most of the day
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on March 21st, 2009 at 10:45 PM
Sorry about above pic's ( moved them to new folder and stuffed up link )fixed them !!
We have put the new 2387cc motor back in car after a few issue's ( oil pressure poor , too much comp , oil o-ring missing from flywheel ) Dangerous went through engine with a fine comb and all things fixed . Have drivin beast around alittle and all well so far . A couple little jobs ,then back up to willowbank soon .
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/106_0302.jpg
http://i143.photobucket.com/albums/r151/Dak-A-Tak/Rods%2048IDA/106_0304.jpg
Memberreub
VWRX is gone...
posted on March 21st, 2009 at 11:11 PM
Can't wait to hear more on how it goes down the strip Pete.
Video would be good too dude:tu:
Reub
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on March 21st, 2009 at 11:23 PM
Looking good Pete and Rod.
I am keen to see it run soon ... T&T ??
MemberSTOCK
Threads: 12
Mood: OK
posted on March 23rd, 2009 at 10:59 AM
HEY PETE & ROD
LOOKS GOOD GUYS
SHOULD BE HEAPS OF FUN TO DRIVE
HEY ROD "MAY BE THE BEST IN YOUR LIFE":lol::lol:
:punk:
STOCK
MemberRAZ34
Threads: 1
posted on March 23rd, 2009 at 01:22 PM
Dont start. I'm still dirty we didnt go there.
MemberRAZ34
Threads: 1
posted on March 23rd, 2009 at 01:24 PM
Also Pete has done another great job on the car . Looks good , sounds good and I suspect should scare me .
Membervassy66T1
A.k.a.: Marcus Vass
posted on March 23rd, 2009 at 05:41 PM
Don't you go out to the track unannounced!!
Dying to hear and see this . .
Memberoldskl60
Threads: 28
posted on March 24th, 2009 at 08:49 AM
Looks very sweet indeed! Nice job Pete and Rod
Looking forward to seeing some wheels up action!!
http://4.bp.blogspot.com/_0YtLR7Gj2Tw/SlsMWR7pLcI/AAAAAAAAAAM/CDqzMEYH70E/S1600-R/oldskl60-footer1a.jpg
MemberBoostn
Threads: 28
posted on March 24th, 2009 at 01:01 PM
Looking good guys!
VOLLKOMMEN ART
Speed and Style
Memberdavidoconnor
Threads: 7
posted on March 24th, 2009 at 09:09 PM
Fantastic stuff!! You guys must be itching to run this thing.
What's the go with the fuel line, has it been redirected to avoid the bellhousing? What's the theory with the heat shield?
Can't wait for the updates.
posted on March 24th, 2009 at 09:34 PM
Not a lot of cooling system on this engine and with the fuel line running where it is vapour lock could be an issue?
MemberDak-A-Tak
A.k.a.: Peter Page
Volksie Pete
Threads: 216
posted on March 25th, 2009 at 08:26 PM
Thanks vw friends , getting real close . Dave , fuel line comes in behide left carb and thats where reg is mounted .Plus I wanted real simple setup that I didn't have to crawl under car to adjust fuel pressure and this car keeps changing motors on me ( Rod can't help him self) . Yes Brennden is correct too ,Lots of heat from stanless exhaust , all so running pully and front tin to help keep heat out .
Maybe next week out to track if all stars line up .:yes:
MemberSTOCK
Threads: 12
Mood: OK
posted on March 26th, 2009 at 11:32 AM
SOUNDS GOOD PETE , GOOD LUCK
BUT FOR ALL US POOR SAPS DOWN IN SYDNEY
WE NEED VIDEO FOOTAGE """PLEASE""":tu::tu:
:punk:
STOCK
 Pages:  1  2  3  4  ..  6
[ Queries: 40 ] [ PHP: 15.7% - SQL: 84.3% ]
