| [ Total Views: 8034 | Total Replies: 71 | Thread Id: 30740 ] |
| Pages: 1 2 3 |
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on March 25th, 2005 at 02:00 PM |
i think ill end up going along the same lines as das with the foil backed sound deadener in the back
boof2332
Threads: 120
Mood: Sympathetic
| posted on March 30th, 2005 at 12:28 AM |
Hi All,
I just built 7 sound proof teaching studios for my mates music shop..he got this new stuff called WAVEBAR.
It looks like lino and can be cut the same..comes in 8kg per m2 or 4 kg m2. It absorbs the sound, not reflects it. The rooms we built are awesome
thanks to one layer of this stuff inbetween each room. I have some for my car..you can cut it and use it in the floor or on the fire wall and it is
only about 5mm thick.
Matt
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on March 30th, 2005 at 09:25 AM |
How much weight would you guys add to your cars in the name of sound proofing?
Just wondering...
barls
Threads: 296
| posted on March 30th, 2005 at 03:36 PM |
weight is no an problem for me with the t4 2L
ruckus
Threads: 165
| posted on March 30th, 2005 at 04:00 PM |
boof how expensive is that stuff? |
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on March 31st, 2005 at 08:08 PM |
| Quote: | Originally
posted by barls
Yeh, I'm gonna be tootling along in my glorious 40HP! Every gram counts! I usually take a sh!t before I drive so the car goes faster!
boersch
Threads: 25
| posted on March 31st, 2005 at 08:12 PM |
| Quote: | I usually take a
hahaha, you could make a killing selling vw stickers with that line
barls
Threads: 296
thats ok mate its not for everyone to modify i salute you for keeping it stock
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on March 31st, 2005 at 08:38 PM |
lol
I only keep it stock coz my wallet and my front drums tell me to do so!
barls
Threads: 296
| posted on March 31st, 2005 at 08:47 PM |
yes mate ive been there but will never go back
68AutoBug
posted on April 1st, 2005 at 01:35 AM |
I have to have front disc brakes and a collapsable steering column...
I also like bumper bars....
& electric fuel pumps and electronic ignitions.....
& H4 Headlamps....
& two speed wipers.....
& Driving & Fog lamps....
& reversing lights....
| Error |
barls
Threads: 296
| posted on April 8th, 2005 at 05:19 PM |
it all comes down to how handy you are and how resourceful
Grock
Threads: 27
Mood: :booM
| posted on May 5th, 2005 at 04:02 PM |
http://www.soundguard.com.au/index.htm
Try this site, seems to have some altenative product choices when it comes to sound deadening!
Dan
hallph
A.k.a.: Phil Hall
Threads: 6
Mood: keen for snow!!
| posted on May 26th, 2005 at 11:03 AM |
That site looks great, i emailed them about some prices.
Also, which areas in a 75 Kombi would be the 'key' areas to sound deaden in order to reduce both road and engine noise? Front doors, floor, tire
wells - what about around the engine bay?
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on May 27th, 2005 at 10:05 AM |
The firewall and floor above the engine will benefit from some insulation, which will help prevent engine noise finding its way into the vehicle.
Even with the engine noise taken care of, any large flat panels will add noise if not dampened in some way. A lot of the noise found in kombis is not
engine noise anyway, just vibration caused by road surfaces, wind, etc. Try driving your kombi fully packed up for camping, and you will notice how
much 'other' noise is around; you just usually can't hear it above the engine noise. The roof, inside side panels and doors, and even the floor
would benefit from some sort of damping material. The bituminous stuff is reputed to be the best, but as others have said, it is heavy. Remember that
the panels do not necessarily need to be completely covered with dampening material; a section in the middle will still dampen a lot of the vibration.
(Have a look inside many factory-finished vehicles)
As RENNWAGEN already suggested, check this site out...
Heat, Rust, & Noise in VW's
Kruizin Kol
barls
Threads: 296
| posted on June 6th, 2005 at 06:37 PM |
i ended up going with the dyno mat extreme. bought the boot kit and still have enough left over to do the front kicks as well. this is what ive done
so far ill post more when ive done it
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on June 7th, 2005 at 10:39 AM |
nice one! How thick is that stuff?
How much did you get for how much $?
Did you you use a hairdryer to mold it or is it adhesive backed?
What's the mean rainfall in Kyrgyzstan for 1997?
barls
Threads: 296
| posted on June 8th, 2005 at 12:33 PM |
it cost me $230 for 5 sheets, which is the boot pack. its adhesive and you just peel and stick, roll for a better fit. each sheet is about 3-5mm
thick.
i think it was 24mm of rain that year.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on June 8th, 2005 at 11:14 PM |
smart arse!:kiss
so hows it sound? or, not sound for that matter?
[Edited on 8/6/2005 by oval TOFU]
barls
Threads: 296
| posted on June 9th, 2005 at 06:52 AM |
ill let you know when i get the engine back in mate as its still out awaiting a rebuild
penguin
A.k.a.: Chris
ackkkkkk thhhhhpt!
| posted on July 5th, 2005 at 08:35 PM |
Hey Barls
has the engine come back yet????
mnsKmobi
Threads: 27
| posted on July 6th, 2005 at 09:06 AM |
Be warned though that the kombi in that article is supposed to be a real rust bucket now. Make sure that you treat any rust b4 covering an area with
soundproofing. Also, don't use anything that can hold moisture - like insulation batts.
What I have been doing is coating areas with fish oil, rustproof primer then bitumenous paint. Takes a while but it shouldn't rust in a hurry! So far
only the front doors and the front passenger's wheel arch have been finished and it is noticeably quieter at 100 kmh.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on July 6th, 2005 at 10:39 AM |
| Quote: | Originally
posted by mnsKmobi
I was thinking that there wasn't that much prep done when he mentions filling all the door cavities with sound deadening foam and other stuff like
that...
barls
Threads: 296
| posted on July 6th, 2005 at 04:49 PM |
no penguin its only just made it to the upholsers to have a headtrim done
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on July 19th, 2005 at 10:44 AM |
any new news barls?
Was wondering if I should I tear out the old sound deadener if I'm replacing parts of it? nn[ Edited on 19-7-2005 by oval TOFU ]
barls
Threads: 296
| posted on July 19th, 2005 at 11:11 AM |
well its back from the trimmers for this time and now we are working on the engine so in a little while mate
barls
Threads: 296
| posted on July 31st, 2005 at 05:23 PM |
did the front kick panels yesterday ready to fit up, we just ran out of time. i started off by sound deadening the panels behind the kick panels
then fitting the kick panels in place to mark where the speakers would sit and covering the back in the dynomat
heres them sitting in place
hallph
A.k.a.: Phil Hall
Threads: 6
| posted on September 26th, 2005 at 08:53 PM |
Any more updates on this Barls?
I've just bought myself a pack of 24 Bostik sound deadening sheets - i'll put them in my van sometime but i doubt they are flexible enough to place
near the engine, possibly just in the doors etc on the flatter surfaces
barls
Threads: 296
| posted on September 28th, 2005 at 02:40 PM |
no mate unfortunately as im not even in the same country as my lovely chaos. but i will update it when i get back
azz
Threads: 56
Mood: whatever
| posted on September 29th, 2005 at 03:22 PM |
What product can I use in the engine bay of a kombi?
| Pages: 1 2 3 |
