[ Total Views: 1543 | Total Replies: 38 | Thread Id: 32207 ]
Author: Subject: Lowering Kombi's !!!(Pics)
Member57 Chook Shed
Mood: ? No thanks.
posted on December 6th, 2004 at 04:22 PM
Here`s the adjusters I made.
They are basically 5mm steel plate based on the swayaway idea. I cut a slot from the bottom grubscrew to the next dimple 90degrees around from the grubscrew hole.
If I had more resources I would make the centre piece out of solid ally like swayaways and fit longer grubscrews.
It works though and I`ve done about 15,000K`s on them with no problems.
Graham.
Memberwacked1
Threads: 302
Mood: naked
posted on December 6th, 2004 at 05:15 PM
57 that’s great for a home job, are you going to notch the spring plates?? or remove the rear bump stop?? do you have any probs with bump steer? I have found with mine , the ride is great but still looks a little high in the front see picture he rear sits fine for me see picture, I’m looking at dropped spindles with a bit of a tub job to get the front wheels just sitting under the front guard and i'm going with bigger diameter tiers ATM i have 50 series I want to run 60's on the front. i don't want the front to be on the ground but want the illusion of it being low with the tiers under the guard
wacked 1
this is how high it used to sit
http://img.photobucket.com/albums/v229/wacked1/v8kombinewfront.jpg
front as it sits now
http://img.photobucket.com/albums/v229/wacked1/finishedjob.jpg
rear height minus the motor
http://img.photobucket.com/albums/v229/wacked1/strip-down.jpg
[Edited on 8-12-2004 by wacked1]
YOU HAVE JUST BEEN DAKED
don't worry it's a VW thing
Member57 Chook Shed
Mood: ? No thanks.
posted on December 7th, 2004 at 09:10 AM
I think notching the spring plates might compromise thier strength so I`ll grind off the stops.
I did have the idea of cutting and turning the whole end of the torsion bar tubes to gain some clearance. Big job though and a bitch to get in there to weld it back on!
Plans for your bus sound cool, I want mine lower but then you get into the whole tubbing business, don`t really fancy sitting in the middle with the steering wheel and pedals over to my right!
Graham.
MemberVWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
posted on December 7th, 2004 at 10:41 AM
I can't get over how hight it looked before the drop, go lower. Shell look sweet as then.
Member57 Chook Shed
Mood: ? No thanks.
posted on December 7th, 2004 at 02:17 PM
You talking about mine or Wacked1`s Bus?? They both looked bloody rediculous anyway. Mine looked even worse in that first photo because I had just fitted the low profile tyres.
Graham.
Memberwacked1
Threads: 302
Mood: naked
posted on December 7th, 2004 at 03:22 PM
hey 57 i don't know much about metal strenght but i do know kimm at indian was selling notched spring plates and so did mike at cbb, so i guess they could work but grinding the bumpstops off is the easier of the two
wacked1
MemberVw nutter
Threads: 148
Mood: Chillin
posted on December 8th, 2004 at 07:07 PM
yeah my kombi is fairly low bugger paying 800 bucks!, i just let the air out of my tires! and put about 20 bags of cement in the back!
Member57 Chook Shed
Mood: ? No thanks.
posted on December 8th, 2004 at 10:24 PM
Hey wacked1, how many splines is yours dow at the back??
Dropped mine 2, would like to go to the magical 3!!
Memberwacked1
Threads: 302
Mood: naked
posted on December 9th, 2004 at 08:55 AM
from memory it's 2 splines but memory isn't all that good, but i have a v8 in the back of mine weighing it down a bit, i'm running 16 inch rims which give the illusion of it being lower in the rear.
