[ Total Views: 3306 | Total Replies: 40 | Thread Id: 32740 ]
Author: Subject: Finished...................
Memberfullnoise
Threads: 103
Mood: Middle of the road.
posted on December 22nd, 2004 at 07:42 AM
Flying Colours
Jak's car is passing everything (That's open to interpretation).
It passed it's engineering certificate.
It passed it's pink slip.
And yesterday it even passed the Central Coast Highway Patrol test.
With all the P platers going splat in modified cars the police are cracking down. The officer pulled over Jak and started giving him a hard time. True to form Jak escaped scott free with the guy showing a lot of genuine interest in the modifications. Apparently a few highway patrol officers in the area have kombis with subaru engines.
I thought it was a good story worth sharing.
CYA CT
esratrams
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on December 22nd, 2004 at 08:32 AM
CT,
You forgot the other things he has been passing.....
New v8 commodores.......13b turbo's......its never ending and this is only the beginning.
Matt
MemberCraig Paton
Threads: 68
Mood: Absolutely Gratefull..!
posted on December 22nd, 2004 at 06:19 PM
Jak
Bug looks great !
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on January 10th, 2005 at 07:05 AM
if you dont mind me asking jak. how far does a tank of fuel take you??
Anthony
MemberJak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on January 10th, 2005 at 08:01 AM
Last week I went to Newcastle twice for work, wound the speedo around to the bumpstop 3 times, took a client for a drive when I got up there, (he didn't beleive that a vw could be quicker than his boxter) & drove it daily here & there, used about 3/4 of a tank, bear in mind I havn't had the computer tuned properly on the road yet so the fuel economy will be even better.
regards
Jak
Member72RSbug
Threads: 49
posted on January 10th, 2005 at 06:21 PM
very nice work Jak.
Could you maybe give some info on your fine lines? Dµid you just use the stock line and 1 new one back to the fuel tank or did you put in a surge tank...? I'l be putting in my fuel system asap but need to make shure it'll be the correct type
MemberJak Rizzo
Threads: 67
posted on January 11th, 2005 at 04:53 AM
I installed 2 new steel lines through the tunnel of the car. I have a standard electric fuel pump & filter that feeds a 1.5 litre Alloy surge pot, which then feeds a VL Commodore Turbo fuel pump.
regards
Jak
Member72RSbug
Threads: 49
posted on January 11th, 2005 at 10:17 PM
ok, so no vapor line or fuel filters in your setup then?
MemberJak Rizzo
Threads: 67
posted on January 12th, 2005 at 04:56 AM
Yep , as I said, there is a fuel pump & Filter that feed a 1.
5 litre surge pot.
I have a return line back to the tank from the fuel pot.
regards
Jak
Memberhotdog008
Threads: 8
posted on January 12th, 2005 at 05:48 PM
well done
my ej20t manx is finally getting close and now looking at what you have done has made me pull my finger out
did you use a intercooler (i see you had original 4 sale)
congrats again hotdog
MemberJak Rizzo
Threads: 67
posted on January 13th, 2005 at 12:31 AM
I ended up getting a water to air intercooler from a liberty, I don't think that the air to air will be that effective in the back of a beetle, u are relying on the weather & correct air flow to combat inlet temps, with the water to air, I can control water flow, radiator position etc etc.
regards
Jak
[ Queries: 40 ] [ PHP: 11.0% - SQL: 89.0% ]
