[ Total Views: 1678 | Total Replies: 40 | Thread Id: 37728 ]
Author: Subject: Chewy's 66 rebuild project (lots a pics!)
MemberChewy
Threads: 75
Mood: Buggered
posted on April 22nd, 2005 at 12:31 PM
On the pan?
I used some stuff called Barmastic, available through guys called Pro Tec Ltd.
Its a 2-pac epoxy mastic (rubberized) protective coating, Its industrial stuff, used on bridges and oil rigs and stuff.
Me and MickH (or M?) have both used it with good success.
Seems to be relatively tough, I didnt do the best job of painting it as it was my first attempt at this kind of thing but the paint is designed to be used on poor prep'd surfaces and to be applied by any means possible.
It came out pretty good I thought.
cost $80 for 4L (3L paint, 1L catalyst)
Also on the under side of the pan I used a bitumen rubber type paint for pretection against stone chips and as a sound deadener, you can get this stuff frome mitre ten/autobahn/supercheap etc for about $15 L.
I used an litre for the entire underside.
MemberBaldy67
Threads: 38
Mood: turbo charged
posted on April 22nd, 2005 at 02:09 PM
cheers mate
MemberChewy
Threads: 75
Mood: Buggered
posted on April 23rd, 2005 at 07:16 PM
rear apron is off, gonna make it removable for easy engine changes.
http://www.thesamba.com/vw/gallery/pix/202725.jpg
and the trannys in, used Empi urethane mounts which I am a bit suss on.
http://www.thesamba.com/vw/gallery/pix/202726.jpg
it feels so good to be able to change gears on it again.
:cool::cool:
MemberBaldy67
Threads: 38
Mood: turbo charged
posted on April 26th, 2005 at 03:19 PM
looks like it is getting there slowly.....keep the pics coming
MemberChewy
Threads: 75
Mood: Buggered
posted on May 3rd, 2005 at 04:19 PM
Yes slowly is the key word
Waiting on a bunch of parts to arrive, I think they landed today.
Tie rods have been beefed up with 3mm galv gas pipe plug welded to original rods.
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on May 10th, 2005 at 11:40 PM
why are you suss on the urethane bushes? Do I spy a urethane steering coupler as well?
MemberChewy
Threads: 75
Mood: Buggered
posted on June 17th, 2005 at 06:44 PM
Hey tofu, sorry I missed your post.
With the mounts, the front one gets distorted when it is torqued up, also they seem like they may be a bit brittle, but this may or might not be the case, plus they are EMPI :duh
How are the heater boxes going??
MemberChewy
Threads: 75
Mood: Buggered
posted on June 17th, 2005 at 06:52 PM
And yea that is a urethane coupler, really hope it doesnt crap out on me doin 100 down the highway...
Some more pics, its back on its four legs!!!!!!!!
I've pretty much rebuilt the entire brakeing system (MC, wheel cyl, lines, pads, etc.)
Tranny has new seals all over
Urethane spring plate bushes
rear re-indexed one inner up and 1 outer down
new shift rod bushing
tie rod ends regreased
new steering damper
rebuilt K+L assemblys
new shocks on the back (will balljoint bus shocks off the front fit???)
fronts were fine so I left them for the time being
Custom urethane bump stops rear
thats all I can think of atm
some more piccies
http://www.thesamba.com/vw/gallery/pix/212900.jpg
ground clearence with stock size tyres and no neg travel
http://www.thesamba.com/vw/gallery/pix/212901.jpg
new brake lines and that
http://www.thesamba.com/vw/gallery/pix/212902.jpg
http://www.thesamba.com/vw/gallery/pix/212905.jpg
Cheers!
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on June 17th, 2005 at 07:35 PM
Would a rolling chassis have a better drag co-efficient than a beetle body? :P
Yeh, the heater boxes fit like a glove - too bad my engine didn't though! stoopid small oval engine bays....
Lucky you - you could replace all your brake lines with the body off... i could only do the front ones... hope it doens't crap out on me at 100kph with a moose or kangaroo in front of me...
MemberChewy
Threads: 75
Mood: Buggered
posted on June 17th, 2005 at 08:01 PM
A moose? lol
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on June 17th, 2005 at 10:24 PM
Looking the goods Chewy
Would like to grab that jack asap u2u me your number and I will call
Would like to come out and crawl over your project
With beer in hand ;)
Cheers Doc
reVOLKS at Fyansford Geelong
[ Queries: 40 ] [ PHP: 13.1% - SQL: 86.9% ]
