[ Total Views: 2940 | Total Replies: 40 | Thread Id: 38727 ]
Author: Subject: For those that may need some encouragement........
Membersubaruboxer
Threads: 20
posted on May 12th, 2005 at 05:19 AM
Hi Jak,
nice torque curve! What an EJ 20 T do you have installed, all Wrx Impreza engines I know are over 200 HP strong ? Why is it third gear?
Jörg
Originally posted by Jak Rizzo
8 pounds of boost, small quiet 2.5 inch exhaust, pod filter, Microtech computer. The rest stock. My fellow Pastizzi eater Nathan Bajda played with the computer & it now comes on boost at 2650rpm & u can hear it chirping the tyres in 2nd gear in the dry on the flat when it comes on boost.
It's quite an exciting ride.
Nathan said with a 3 inch exhaust & 10 pounds boost it may crack 220hp plus at the wheels. But this is more than enough for me!! For now. Could also safely add more timing on boost as well, conservative has been my moto so far.
145.7kw @ the wheels.
regards
Jak
http://www.thesamba.com/vw/gallery/pix/205015.jpg
MemberJak Rizzo
Threads: 67
Mood: Pastizzi eating
posted on May 12th, 2005 at 07:13 AM
Originally posted by subaruboxer
Hi Jak,
Jörg
The 195hp is at the wheels, not the flywheel, it's done in third gear as thats just the way it is done in Australia on Dyno Dynamics dynos. Also I have found that Aussie dyno figures are a little more realistic than the rest of the world.
& sure there are more powerful wrx engines out there, but if u can safely handle more than 200hp at the wheels then u are a better driver then me, which wouldnt be hard!
regards
Jak
Memberrubyred
Threads: 4
Mood: turby
posted on May 12th, 2005 at 04:54 PM
doesnt that equate to about 225 at the flywheel?
Memberlugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
posted on May 12th, 2005 at 05:14 PM
http://dyno.scoobynet.co.uk/PEindex/uk.htm  ;)
Membersubaruboxer
Threads: 20
posted on May 13th, 2005 at 02:31 AM
Hi Jak,
sorry I forgot the difference is engine dyno and chassis dyno. You have around 260 HP at the flywheel, that is a lot for the old bug. I checked a book and it was said that there is difference of about 30 percent in the two figures. I asked because I am going to put my EJ 22 bug on the dyno in a few days. Any advice for a dyno first timer?
Thanks Jörg
[Edited on 12-5-2005 by subaruboxer]
MemberJak Rizzo
Threads: 67
posted on May 13th, 2005 at 06:11 AM
Just make sure your tuner knows what he is doing & think of the dyno as a tuning tool not for bragging rights, Ive heard some horror stories about dynoes.
regards
Jak
Memberexwrx
Threads: 2
posted on May 13th, 2005 at 11:23 AM
The 30% driveline loss is a rule of thumb. The wrx with its awd system is probably higher. I would imagine a beetle would be more efficient in this regard.
In relation to your dyno experience, make sure your tuner is familiar with subaru engines and listens for pinging. At the first sign of this or any other noises, they should shut it down immediately.
Hi Jak,
Thanks Jörg
[Edited on 13/5/2005 by exwrx]
MemberNigeType3
Threads: 32
Mood: Speedy
posted on May 13th, 2005 at 12:29 PM
Stoked for ya bud
Sounds like its the shiznit
MemberBaja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on May 13th, 2005 at 02:09 PM
30% is probably a bit high.
I think most modern cars are around the 17% loss, most dyno tuners use that as a rule of thumb.
Your right AWD's are worse.
MemberJak Rizzo
Threads: 67
posted on May 13th, 2005 at 04:16 PM
As an example, I've seen standard STI's off the showroom floor with around 140kw at the wheels. Thats less than what I have. The 4wd must soak an enormous amount of power.
Nathan my dyno tuner commented that it mine the power quite effortlessly, as though the gearbox wasn't holding it back at all.
regards
Jak
Member57kombi
Hannover Elder
Threads: 181
posted on May 13th, 2005 at 04:33 PM
Have you do a write up on this coversion.
Just thinking aloud(again).
What would it take to put one in a split.
Is the 1303 gearbox standard.
What cooling are you running, where is the rad??
I think I might be posting a bit on here in the future?????
Dave
[ Queries: 40 ] [ PHP: 10.4% - SQL: 89.6% ]
