| [ Total Views: 4183 | Total Replies: 40 | Thread Id: 39376 ] |
| Pages: 1 2 |
Alex Holzl
A.k.a.: Big Al
2332cc of pure BALLZ!!
Threads: 85
| posted on May 27th, 2005 at 12:00 AM |
should be quick!
boof2332
Threads: 120
Mood: Sympathetic
| posted on May 27th, 2005 at 12:16 AM |
Dont save...spend. As soon as you can afford the little things, then buy them and put them in the car. Project will tick along and before you know it
all you need to make it run is to put in an engine and box and thurn the key!
Do not forget cutting at rear(if any), frame to support forks,new fuel line and return, surge pot, 2x pumps, computer, exhaust, intercooler,
intercooler placement with mounts and ducting, intercooler thermos, radiator, radiator thermo fans, mounting and cutting/ducting, all associated
plumbing and piping for cooler, radiator and blow off valve, brakes and suspension, aluminium/sheetmetal work for boxing in parts of engine, air
filter, exhaust wrap, muffler,adaptor plate, flywheel, clutch and thrust race bearing, lots of wire and little coloured terminals, gearbox, hard mount
for box, engine! Thats roughly it....
Its easy to get started on the little things and is obviously quicker..because even if you get all of this at once.....I still think it would then
take 12 months. I do not know about Perth, although it would be best to keep the car registered the whole time it is off the road.
Matt
malcolm
Threads: 102
Mood: where did he go!!!!!!
| posted on May 27th, 2005 at 01:06 AM |
the renault gear box is longer than the porsche box there are more performance parts for the porsche box made in oz . early porsche 930,s had a 4spd
g50 box due to the turbo being able to stretch its legs .I was quoted $5000 to build a ssp vw box to handle 300hp . I can buy a 915 box in very good
condition for $3200 from centre of drive shaft to bell housing 8mm longer than vw and centre of driveshaft to end of box all up 150mm longer than
vw.if you want 300hp at the wheels your not going to drive it like a stocker .and the 4spd g50 is shorter than a 915box.
1303Steve
| posted on May 27th, 2005 at 11:03 AM |
My gearbox is still for sale, I beleive that its at high end of strengh that can be acheived with type 1 box, it would cost $6000.00 to build this box
now. Im reluctant to use this with my new Subaru powered car, Im going to build the chasssis around the gearbox so I dont want to base all work around
a stock transmission shape, then if it fails I would have to cutup the car again for my next transmision choice.
My gearbox for sale
bugat5speed
Threads: 2
| posted on May 27th, 2005 at 06:14 PM |
bellhousing for UN1-5
Hi,
the gearcase of the UN fits between the forks of the beetle. I´m preparing a bellhousing for this gearbox at the moment (casted). It will have
adaption to Subaru and to VW/Porsche. Axle flanges are made as well.
Unfortunatelly the UN is very long, but if you want to drive with hight torque engines there is hardly any better gearbox. It´s very often been used
for kitcars with V8-engines and torques of 400 Nm and more.
Martin Bott of Bug @ 5-speed http://www.bugat5speed.de
71superbug
The Itch Itcher
Threads: 72
Mood: Subified
| posted on May 28th, 2005 at 12:49 AM |
wuld u be making one that can adapt to mazda rotarys mate?
as thats what i will be putting in
13bt
Let me know.
Anthony
seagull
Threads: 752
| posted on May 28th, 2005 at 01:02 AM |
Come on , lets race !
| Error |
Jak Rizzo
Threads: 67
Mood: Pastizzi eating
| posted on May 28th, 2005 at 06:29 AM |
Hi Anthony,
THis is a little off topic but is the engine that u have out of a series IV rx7, the one with the factory intercooler on top of the engine similar to
the Pulsar GTI-r. If so, have u thought how u are going to get cold air to the intercooler? I've read several times that the factory intercooler is
quite inefficient, so putting it in the back of a beetle makes it worse? Have u thought about going water to air?
Jak
1303Steve
| posted on May 28th, 2005 at 10:30 AM |
Hi Martin
Thanks for that, I think reno boxs are getting a bit thin on the ground. Any word on a local distributor for your sumps etc.
71superbug
The Itch Itcher
Threads: 72
Mood: Subified
| posted on May 29th, 2005 at 07:26 PM |
yes jak i have considered going water to air intercooler. seems the most likely option.
i AM going the series IV 13bt as it is the one with the decompressed rotors.
however the turbo is shit on the series IV so probably going just a series 5 stocker for the time being..
Anthony
[Edited on 29/5/2005 by 71superbug]
boof2332
Threads: 120
Mood: Sympathetic
| posted on May 30th, 2005 at 08:27 AM |
Have you got your radiator in yet... I have a brand new Dewalt angle grinder that goes in one hand and after drawing a few guide lines with a magic
marker, I then pick up the other weapon of choice....an air compressor run hack saw. When it doubt, just cut it out! Even if you take out a bit too
much, it will just make you lighter!
Matt
| Pages: 1 2 |
