| [ Total Views: 1962 | Total Replies: 41 | Thread Id: 41816 ] |
| Pages: 1 2 |
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on August 16th, 2005 at 12:47 PM |
| Quote: | Originally
posted by Baja Wes
Do you have something to stop sand getting into your flywheel area? Sand in the clutch plate could be another explanation. The sand would initially
get in between and stop it disengaging properly, but would then quickly wear the clutch out and make it slip?
So do I get a gold star?
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on August 16th, 2005 at 01:50 PM |
| Quote: | Originally
posted by Baja Wes
| Quote: | Originally
posted by Baja Wes
Looks like you only get a blue star Wes....you forgot to mention the Thrust Bearing so some points have been deducted.:P
tssnq.com.au
Midlife crisis
Mood: Wornout and Toxic
| posted on August 16th, 2005 at 02:00 PM |
Seeing that Wes got a blue star for picking the trouble How do you stop the sand from getting into that area is there something you can buy to do
that??
Marc
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on August 16th, 2005 at 02:44 PM |
it's pretty hard to get sand in there if you have a beetle motor.
It's easier to get it in there is you have a conversion that has left some kind of gaping hole open for sand to get in. I had to make up a steel
plate to cover from the bottom of my block to the bottom of the VW bellhousing.
I'm not sure why exactly Pete got so much sand in there.
pete wood
| posted on August 16th, 2005 at 06:38 PM |
mmm, I think I have the same gaping hole in the block as you had wes, only it was a subaru gaping hole not a mazda one. Wasn't just sand either.
There was definitely dust in there from the 2 motorkhanas I went in as well.
Basically the sand went up through the block, through the hole in the adaptor plate and then around the edge of the flywheel, which picked it up and
flung it round and it got into the clutch mechanisim. From there is was ground into a fine powder like I found it.
got some pics of it here,
http://www.geocities.com/peterwood738/buggyproject/buggyproject13.html
anyway, it'll get a cover on it now. Bit tired of learning the hard way...:onn[ Edited on 16-8-2005 by pete wood ]
pete wood
| posted on August 17th, 2005 at 05:53 PM |
Motor back and running...running once anyway.
Turned it over and it ran for a few minutes, horribly rich for the cat I spose. Turned it over again and there was a big bang, raw fuel?
Now she won't fire.
Any ideas? Just flooded?
helterskelter400
Threads: 62
| posted on August 17th, 2005 at 06:36 PM |
no ideas on the subaru but your web site was a good read. thanks.nn[ Edited on 17-8-2005 by helterskelter400 ]
:thumb
pete wood
| posted on August 20th, 2005 at 05:42 PM |
Ok, Now I have an issue. The motor is all back in, But i'm stuffed if I can get it to start. It has plenty of fuel and all the plugs are sparking,
but it won't fire or run. The ECU is not showing any codes either. A mate and myself spend 2 hours trying to diagnose it this afternoon and it has us
stumped.
Seems to be something to do with timing, but we can't figure out what.
Any ideas? Brad, Anyone?
pete wood
| posted on August 20th, 2005 at 05:43 PM |
stumped.
seagull
Threads: 752
| posted on August 20th, 2005 at 07:13 PM |
Pete , remove the power lead and leave it off for amount 60 seconds .
you put the earths back on ?
welcome to my DREAM !:alien
pete wood
| posted on August 20th, 2005 at 09:01 PM |
Nah dude, we've actually had mine run before. Prolly something stupid. last time it was the main ECU relay mucking up. But it was throwing masses of
codes then. Not sure this time.:duh
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on August 20th, 2005 at 10:52 PM |
Check all your sensore plug and stuff you had undone.
If it won't fire I and you think it is timing I reckon your ECU is getting a bad signal. Check all your earths as well.
If nothing then I would unplug an injector and see if it throws a fault code just to make sure the ECU is doing it's job.
I reckon it is a plug though if it is over fueled and was running before you pulled it one if them may not be done up correctly or a joing wire may
have pulled out.
| Pages: 1 2 |
