[ Total Views: 3365 | Total Replies: 31 | Thread Id: 46895 ]
Author: Subject:  Bay window and Diesel conversions
MemberMatt Ryan
A.k.a.: Matt Ryan
Mood: Fweemin
posted on January 24th, 2008 at 09:48 AM
Subaru are releasing their turbo boxer diesel this year. Probably be exy to buy a new one off the shelf but if you're patient you might get a second hand Jap one in a couple of years as they retire their engines at pretty low mileage.
I wonder if you could run the matching subie transaxle with it as well?
More info:
http://www.drive.com.au/Editorial/ArticleDetail.aspx?ArticleId=45405
Regards,
Matt
MemberGeorgeL
posted on January 28th, 2008 at 07:31 AM
The past problem with Subaru transaxles is that their cases were not symmetrical. You can't flip the ring gear around to reverse the drive direction of the axles, as you can in a VW transmission.
Seeing as how Subaru isn't likely to want to use reduction boxes or go to a rear engine setup, they probably won't change their design to accommodate VW gearheads.
[ Queries: 40 ] [ PHP: 9.9% - SQL: 90.1% ]
