[ Total Views: 1585 | Total Replies: 48 | Thread Id: 50681 ]
Author: Subject:  engine wont start..... (ok now it starts but wont run smooth)
MemberAnthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on April 10th, 2006 at 11:30 AM
ok now ive gotten it started.
starts fairly easy now.
blew the cobwebs out.
ok the exhaust for #3/4 gets very hot and the exhuast is hot as it exits the cannon.
the exhuast for #1/2 gets slightly warm and the exhuast gas is barely above room temp.
have to keep the engine at about 1800 revs to keep it running and if u pump the pedal it backfires or if u take foot off pedal suddenly it backfires
i pulled the 1 and 2 plugs and both were oily.
i have spark at these leads......why wont it run even? dissy cap perhaps?
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Memberpod
A.k.a.: paul mrvw061
Mood: could be better
posted on April 10th, 2006 at 12:57 PM
sounds like an air leak somewhere ,usually the cause of backfires:(
check wbsite for location
All Welcome
http://www.flatfour.org/
posted on April 10th, 2006 at 01:01 PM
Could also be blocked idle jet or circuit.
ie the have to rev above 1800 and the sudden back off.
Dont like the sound of the cool gas on 1 n 2
Sounds like they are not firing.
Member76camper
Threads: 89
Mood: happy :-)
posted on April 10th, 2006 at 02:30 PM
definantly worth doing a compression test. If youve got valve problems or just worn rings on one or more cylinder it wont run evenly or smooth without major compensations in power and economy. Do a compression test, sounds like your not getting enough compression on 1 and 2 to get a good combustion. Does the exahust sting your nose or smell rich (dont take too many whiffs or you will die from the carbon monoxide). Put ya hand infront of the 1 and 2 exhaust and pull it away after a few seconds and smell ya hand for petrol...
good luck
Memberkevo
A.k.a.: kevo Milner
Theme: UltimaBB Psyche Green
Mood: always happy
posted on April 10th, 2006 at 06:11 PM
if it was me...
id just rip off the head on the 1 and 2 side, check for cracks between inlet and exhaust valves, this is VERY common on TP 1600 engines
replace rings while the access is there, better yet, do all 4 piston and rings cos if its black and oily ya arnt burning the fuel... or the oil sliding up the sides of the barrel! if ya do all 4 cylinders then ya know ya got a reliable engine
but seriously, theres no other way around fixing your car if rings of valve wear is the problem
just rebuilt my sisters 71' 1600 tp n it wasnt hard at all, n i dont have a job in mechanics or nething, turned over 1st crank too
kevo
76 baywindow kombi - V8 & Weddle racing diff and gearbox
Daily driven beach cruiser
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 10th, 2006 at 10:21 PM
will try to do compression test 2moro. and double check the valves and try differnet plugs etc.
1974 Chevrolet Luv
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 10th, 2006 at 10:26 PM
oh and it stopped backfiring so it was prolly someting in idle circut which got blown out.
1974 Chevrolet Luv
posted on April 11th, 2006 at 12:01 PM
Does it idle ok now???
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 11th, 2006 at 10:02 PM
nope still wont idle.......but it appears to be running on 2 cylinders so i dont really blame it......it does however feel like it wants to idle but just cant keep it up with only the 2 cylinders.
ill pull the rocker covers off tomorrow and have a good look at the rocker action and see if i can pic something up.
1974 Chevrolet Luv
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 12th, 2006 at 10:46 PM
ok.
appears i have a cracked head.
made itself obvious today with raw fuel leaking out.
1776 is dropped and 1600 hopefully with be back in and running tomorrow.
hopefully....
1974 Chevrolet Luv
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 15th, 2006 at 09:18 PM
1600 is back in. as of about 2 hours ago.
damn it feels nice to drive my car again!!!!!
it would have been 2 weeks tomorrow.
already had someone tell me how cool it was and someone tell me it was "crazy" as in im insane having huge tires on the back lol and i only took it for a 10 minute drive with a couple of stops.
1974 Chevrolet Luv
Memberkarmen
Threads: 130
posted on April 15th, 2006 at 09:37 PM
anth
get a mate or the racq
if i was closer i would be there
read the book on how to make friends and influence ppl....
Karmen
56 oval resto 60 Cal KG
63 Baja 80 GLD parting
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 15th, 2006 at 09:52 PM
i dont understand bernie? what do i need a mate or racq for?
1974 Chevrolet Luv
Memberpod
posted on April 15th, 2006 at 10:06 PM
he means for the tow home the cheeky bugger:vader
All Welcome
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 15th, 2006 at 10:11 PM
ha ha i must be dumb.
a tow home from where?
car wasnt playing up i was the one who took the engine out and put the 1776 in and it didnt work out so the 1600 is now back in.........
wasnt stranded or anything
1974 Chevrolet Luv
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on April 15th, 2006 at 11:04 PM
check the head torque on the 1776, probably a loose head !!
Good to see the beast back on the road :thumb
Memberancientbugger
Threads: 191
posted on April 16th, 2006 at 09:03 AM
Nick if you can get the engine round to my place we'll pull it apart and have a go at it, as the wife can't understand how I can drive to Caloundra to play with a veedub engine but can't go to Maroochydore to go shopping with her:lol:
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
posted on April 16th, 2006 at 05:21 PM
ha ha.
should be down on wednesday to take some things down to dads place and get those wheels for you.
might leave the 1776 where it is at the moment its sitting in the corner punished:vader
1974 Chevrolet Luv
MemberAnthiron
A.k.a.: Nicko McKay
Threads: 310
oh and bring your tools back:P
1974 Chevrolet Luv
[ Queries: 40 ] [ PHP: 2.9% - SQL: 97.1% ]
