[ Total Views: 2732 | Total Replies: 41 | Thread Id: 55678 ]
Author: Subject:  Gearbox oil
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on January 15th, 2007 at 02:04 PM
I've seen the Morleys and Lucas stuff in shops...
Never spoken to anyone who has used it...
I'm presuming its very expensive????
It's under $20 for about 500ml. So it's cheaper (by volume) than the Nulon stuff... but you have to use more of it.. so it evens out I think.
question.gif posted on January 15th, 2007 at 02:21 PM
LUCAS or MORLEYS additive...??
So, anyone on here using it in their gearbox???
the little gadgets they have to show you how it works
seems to make a big difference...
good thing about gearboxes, once You add this stuff You don't need to change it until something happens... or
at least the oil change would be in a few years time....
MemberACE_76
Threads:
posted on January 15th, 2007 at 11:12 PM
Have a look at how Moreys/Lucas works in gears here:
http://www.bobistheoilguy.com/images/lucas/lucas.htm
MemberBASHOdi
Threads: 94
posted on January 16th, 2007 at 05:16 PM
Has anyone used penrite 10/10ths 75-90 synthetic ?? or any synthetic for that matter ??
Membertoplessbug
Threads: 128
Mood: waiting for my lotto win
posted on January 16th, 2007 at 06:58 PM
there is a fair bit on synths in STF ,personally i will stick to dino's with my molybond, if you read the specs it will tell you that the average particle size is .5 micron ,which cannot possibly promote skidding etc as bearing tolerances are MUCH greater.
TECHNICAL DATA
The information enclosed in this Technical Bulletin is as up to date and correct as possible as at the time of issue. The data
provided in this Technical Bulletin should be used as a guide only, as the performance of the product will vary depending on differing
operating conditions and application methods.
The sale of any product described in this Technical Bulletin will be in accordance with ITW Polymers & Fluids Pty Ltd Conditions of
Sale, a copy of which is available on request. To the extent permitted by law, ITW Polymers & Fluids Pty Ltd excludes all other
warranties in relation to this product.
Date last modified April 2002 T0281
MOLYBOND Formula 2.5
Oil additive containing molybdenum disulphide
Description
Molybond Formula 2.5 is a mineral oil dispersion containing 20% by weight of colloidal molybdenum disulphide,
meeting the DEF2304 purity specification. The average particle size of the colloidal molybdenum disulphide is less
than half a micron. Formula 2.5 is intended for addition directly to oil systems which enables the benefits of wear
reduction to be achieved without changing oil.
Areas of application
• Gearboxes
• Crankcases
• Engines
• Differentials
Features
• Available in 40g tube
• Reduces friction and wear
• Accelerates the running-in process
• Reduces oil temperature
• Reduces noise in gearboxes
Directions for use
Molybond Formula 2.5 is designed for addition to most lubricating oil systems, with the amount required, varying with
the end use of the lubricating oil. A general guide is as follows:-
Hydraulic systems 2 tubes per 10 litres of oil
Automotive Engines 2 tubes per 5 litres of oil
Gear & Differentials 1 tube per litre of oil
WARNING:- Formula 2.5 can reduce friction of oil lubricated clutches.
Technical data
Appearance ..............................................Black Liquid
Molybdenum Disulphide content................20%
Type of oil base .........................................Mineral oil
Australia New Zealand
ITW Polymers & Fluids Pty Ltd ITW Polymers & Fluids
100 Hassall Street, Wetherill Park, NSW, 2164 18-26 Amelia Earhart Ave, Airport Oaks, Mangere
Phone: (02) 9757 8800 Phone: 09 256 2122
Fax: (02) 9757 3855 Fax: 09 256 2124
Health & safety information
The product is hazardous. A Material Safety Datasheet is available from the Rocol Customer Services
Department upon request.
standard abec tolerances are in the order of 8 microns in the raceway runout for bearings to 30mm O.D after that it gets much greater :beer:beer:beer
Don't argue with an idiot; people watching may not be able to tell the difference.
posted on January 16th, 2007 at 08:10 PM
Thanks for that....
thats what I'll use... the old Molybond....
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on January 16th, 2007 at 09:58 PM
Where does one obtain this Molybond?
posted on May 17th, 2007 at 09:33 PM
mmm what an essay, 85-90weight with nulon is looking like the easiest.
Memberoval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
posted on May 17th, 2007 at 09:38 PM
So everyone reckons the Nulon stuff is ACTUAL beneficial?
Memberkombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
posted on May 17th, 2007 at 10:35 PM
It made amazing difference to my sons MG Midget, before stiff and notchy, short time after quick & smooth, just like a VW box
posted on May 17th, 2007 at 10:50 PM
yep. same with my bros old bay.
nasty and noisy, hard to find gears before. even after a recent oil change a few months prior.
changed the oil and added some nulon and much happier. not brand new, but a noticable improvement.
I've been putting nulon in cars for years. Doesn't turn the motor brand new but it helps it a lot. Our old swift had done 250,000 plus kays on the original motor and is still going fine. the friend we gave it too only needed the water pump and clutch changed recently.
posted on May 17th, 2007 at 11:58 PM
Nulon has teflon in it and its supposed to coat parts with the teflon to stop wear....
I have been using it for many years in Mitsubishi cars and have never had any gearbox problems...
I have never really noticed anything though...
I really do prefer Molybond type products...
[ Queries: 40 ] [ PHP: 3.5% - SQL: 96.5% ]
