[ Total Views: 1847 | Total Replies: 43 | Thread Id: 55806 ]
Author: Subject:  Type 3 Fastback resto
Memberfastyman66
Threads: 14
posted on August 29th, 2006 at 11:38 PM
underneath the tar like stuff the pan seemed to have been painted cream I think, thats where the yellowy sections on the pan are coming from.
Memberfastyman66
Threads: 14
posted on August 29th, 2006 at 11:44 PM
This is the section under the back seat on the opposite side of where the battery sits (its behind the front passenger). Water has in the past pooled in this spot and so I was more than a little nervous scraping off the tar in this section.
This is a shot before I had removed the tar/deadener/whatever except for a small section in the middle.
Memberfastyman66
Threads: 14
posted on August 29th, 2006 at 11:48 PM
This shot is after the tar has been removed. This section is literally pristine. I had to remove the heater channel connection section for better access.
Memberfastyman66
Threads: 14
posted on August 29th, 2006 at 11:52 PM
before painting with rust preventative paint, I am using a rust converter so that the job I do will last. The converter goes on white and apparently then drys darker.
Memberfastyman66
Threads: 14
posted on August 29th, 2006 at 11:54 PM
this is after the rust converter has been applied. I will leave it overnight before applying the rust preventative paint.
Membergreenman
Threads: 35
posted on August 30th, 2006 at 07:29 AM
How much fun is it working on a car in confined unsheltered space. Days and nights like these I wish I had a huge garage with concrete floors and a big long bench with shelves. I suppose it's character building and adds to the fun. Good luck with the job and don't get any wet and dry in the cats bowl.
MemberMidlife crisis
Mood: Wornout and Toxic
posted on August 30th, 2006 at 07:52 AM
Whats the name of the rust converter you are using??
Marc
Memberfastyman66
Threads: 14
posted on August 30th, 2006 at 08:20 AM
tell me about it cal68, I dream of a shed, with a work bench, space to open the doors of the car on both sides! and maybe a beer fridge (and a flat screen:P)
But I have what I have and I will make do.
Not sure of the rust converter brand will check this evening and let you know. Nothing special though, straight from Bunnings.
Memberfastyman66
Threads: 14
posted on August 30th, 2006 at 05:01 PM
Ok, so this is what the converter looks like the next day.
Memberfastyman66
Threads: 14
posted on August 30th, 2006 at 05:07 PM
I will paint that section with rust prohibitive paint later today.
Also did some more mundane work stripping the pan, using a flat head screwdriver believe it or not (boring).
The pan gets better and better as I go towrads the front of the car. There is actually no rust at all around this section, but given I started I may as well finish.
Memberbaybuscamperkid
Threads: 335
Mood: transported
posted on August 30th, 2006 at 05:43 PM
nice one, looks like you got a little ripper!
Memberstephenianjames
Threads: 68
posted on August 30th, 2006 at 10:43 PM
looking good mate..will be sweet when all done (for a fasty):thumb
Memberfastyman66
Threads: 14
posted on August 30th, 2006 at 10:54 PM
Thanks Steve, hows the notchy going?
Threads: 68
posted on August 31st, 2006 at 09:46 PM
nowhere fast at the moment (like you didn't know that already)
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
