| [ Total Views: 3098 | Total Replies: 42 | Thread Id: 65808 ] |
| Pages: 1 2 |
1303Steve
| posted on November 17th, 2007 at 11:37 PM |
Hi Humpty
The good thing about a turbo is, if you want more boost you twiddle a knob or flick a switch. Supercharger, hang on a sec mate while I swap pulleys
for more boost.
fullnoise
Threads: 103
Mood: Middle of the road.
| posted on December 6th, 2007 at 10:18 PM |
Bloody Ebay!
If only I could find a cheap SC12 Supercharger in excellent condtion on ebay!
http://cgi.ebay.com.au/SUPERCHARGER-SC12_W0QQitemZ330194952985QQihZ014QQcategoryZ72478QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
esratrams
westi
what the
Threads: 28
Mood: not blue, pink
| posted on December 7th, 2007 at 07:57 AM |
how much is cheap
i told you already to pop down have a look,$200 merc /eaton/charger,and i have the next size up if needed.or a 1J take your pick.
down sharon.
fullnoise
Threads: 103
| posted on December 13th, 2007 at 09:25 AM |
Hi Westi,
I'll try and come past next week becasue I intend to drive the beetle to work all week. That way I can get a better idea of where it won't fit.
I've been contemplating a few things:
1. Could you use one of those tricky aftermarket vw off-the shelf serpentine belt conversions and then just get a longer belt that whips around the
supercharger pulley too. Hopefully they use the same belt (Wouldn't be that lucky?)
2. I could use some IDF manifolds with dellorto style aircleaner bases and my turbo tops bolted to them with a few gaskets for the intake plumbing.
3. There's an aftermarket fan housing that is at its maximum height off centre above the fan (Rather than the centre of the case). So it tapers away
towards the 3/4 head. This may allow enough some extra space if the super charger is too long and gets in the way of the fan housing if you start with
the pulley lined up with the standard pulley.
Just some thoughts for the boring drive too and from work in the boring old company Astra.
CYA CT
esratrams
2443TT
A.k.a.: Ian
Threads: 69
| posted on December 13th, 2007 at 10:55 AM |
I'd do away with the distributor and convert to a crank fire ignition system. With the distributor gone there is a lot more room for mounting a
supercharger on the left side of the engine. The oil filler is in the way on the other side.
Your probably going to end up making a custom pully anyway to drive the supercharger. Dont be afraid to do this. You can get a chromoly pully hub with
a keyway from the bugpack pully system, and get a pully machined up from alloy. Putting the crankfire trigger on the pully will require a little
creative thinking but its not that hard to do.
Turbo54
Mood: Boost'n
| posted on December 13th, 2007 at 12:11 PM |
I am running my timing off the flywheel. It's out of the way, accurate and easy to setup. I am then using the dissy hole as a breather. Just a
thought.
T54
C'mon kids gather round,
2443TT
A.k.a.: Ian
Threads: 69
| posted on December 13th, 2007 at 12:19 PM |
So the flywheel generates a sync signal... where is the reference signal picked up from?
Dero
Threads: 15
Mood: Ratty
| posted on December 14th, 2007 at 06:31 AM |
Courious to knoe if ya planning on and intercooler at all... I
guess it does add complexitity but a nicetity as well I guess....
sorry just rambling/ interested in seeing this setup!
fullnoise
Threads: 103
| posted on December 14th, 2007 at 08:15 AM |
No plans for an intercooler. I want to fit everything in a closed oval engine bay. That's the biggest challenge.
I'm rambling too!
CT
esratrams
ian.mezz
Threads: 280
| posted on January 7th, 2008 at 03:15 PM |
A little Holden Gemini
Holden Commodore V6 motor fits nice
OH YER THE SUPERCHARGERS THATS WHAT YOU SHOULD BE LOOKING @ VERY NICE
LIFE IN THE LOW LANE
A.k.a.: Brennden Alder
Theme: UltimaBB Pro Orange
| posted on January 7th, 2008 at 08:26 PM |
man that is a very good fit. If it isn't all show then that thing would get up and boogie!!
pete wood
| posted on January 11th, 2008 at 03:40 PM |
surely it would have been easier (and lighter) to use one large one? I mean it looks impressive all but really...
fullnoise
Threads: 103
| posted on January 11th, 2008 at 09:37 PM |
Lame.
My progress so far is L A M E. All I've done is flip my 54 around so the engine bay faces my work bench. That way I can put a stock 1600 in it and
mock up the position of the supercharger. That should be easy really. Moving the '54 was like solving a sudoko rubics cube. It had all my crap build
up around it and it hardly rolls. There is 3 cars sitting in a 2 car garage. I had to spin the thing 180 degrees using a trolley jack.
Westi, I'm still going to pop by your joint one day to look at your blower.
CYA CT
esratrams
| Pages: 1 2 |
