[ Total Views: 2225 | Total Replies: 32 | Thread Id: 67288 ]
Author: Subject:  turbo upgrade- what gains to expect
MemberJVLRacing
Threads: 30
posted on February 13th, 2008 at 07:26 AM
Originally posted by seagull
yes , due to the fact the lifters / rockers are shit mate
Yes I put JLV to give you further shits :) all is fun
There only shit when you start f*kin wacking bigger turbos on them and not copensating for anything else!(JLV cough*cough*)
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on February 16th, 2008 at 06:50 PM
The 98 model manifold which I have is a higher one for the intake to go under it...although the bolt pattern on manifold changed around 2000 and they are offset on the outer holes.
Jack Rizzo has a tdo5h although was only running 8psi on dyno and had a small exhaust. Paul has the tdo4.
The VF34 is better than a tdo5h although it is alot more ...aroung $1400 new. Bang for buck the tdo5h is the go.
You can get 200kw atw without bigger injectors and head work. I have a guy who is a wrx guru who is rebuilding my 2002 wrx engine for me...and he has comparisons on the dyno for heaps of turbo/exhaust/injector/cam/porting combos and heads and cams were one of the most expensive options with relatively the least gains.
matt
MemberJVLRacing
Threads: 30
posted on February 16th, 2008 at 08:48 PM
matt
Hello Matt!:cool:
[ Queries: 40 ] [ PHP: 10.7% - SQL: 89.3% ]
