[ Total Views: 5668 | Total Replies: 45 | Thread Id: 68094 ]
Author: Subject:  "Valentino" and his MEGA! IRS Tranny
Memberdangerous
Mood: 591
posted on March 26th, 2008 at 07:13 PM
The side covers are a custom made part.
They were not new when I fitted them but had a history from back in the eighties(rally car) as far as I can tell.
The BAKAHAG is, I am guessing, the company who made the conversion to IRS.
Sounds like you have done a search Mac and come up empty?
If you wanted something similar it would be a custom order I would say.
You could try formula ford guys though.
Originally posted by westi
That's mad Alan.
Membermactaylor
Mood: even my dog is german
posted on March 27th, 2008 at 02:57 PM
yeah they just look soooo good and couldnt find them anywhere !!!
EVERLAST CONCRETE TANKS
1800 552 123
Memberchoppa
Threads: 42
Mood: Itchy
posted on March 29th, 2008 at 11:43 AM
Nice stuff Dave
Thanks for sharing.
I think I noticed your gonna run the standard coil spring between 3rd and 4th.
Makes for a nice whine, but do u get breakage with that?
I do but I havent so far.
Memberdangerous
Mood: 591
posted on March 29th, 2008 at 02:38 PM
Never had a problem with using the spring spacer.
I use a solid one now because, on my own tranny, I use 4th gear as a thrust face and it needs to be constant.
Pinions with a nut on the end get a solid spacer like stock.
At least with the spring it will not lose its pressure against 4th, and helps keep the circlip under thrust and therefore, in place.
Even my blown combo used the stock sprung spacer ,
and I DID break a 3rd gear once, but it was a stock VW third and had suffered oil starvation.
I was also using third gear for skids back then.
Nothing should whine.
I have heard whine when the crownwheel and pinion is set weird under coast conditions, to get a better load pattern.
I recal Bergs saying that with a bigger engine they had once the tranny began to whine under a coast situation,
but Gene's explanation never made sense to me.
Despite my respect for the Bergs,
there were(are) a lot of things they say and do that don't ring true with logic.
Suspension advice was one of a few.
.....but without proper analysis, taking their advice will, in general, be a satisfactory path to take.
That's mad Alan.
Memberchoppa
Threads: 42
Mood: Itchy
posted on April 1st, 2008 at 02:31 AM
Interesting. Yep all my boxes whine. I did have a go at blueing a crown and pinion once, but I got a bit bored, now I just use the OG shim that came out, maybe thats my problem.
I think your right, I remember reading that bit of Genes about cocking of 3rd and 4th , looked believable to me, maybe it wasnt the gospel.
Now ive got your info, ill blue the next one i do.
Memberdangerous
Mood: 591
posted on July 29th, 2009 at 06:33 AM
Actually Valentino recently sent this trans back to be for an upgrade of gear ratios and inspection.
The 1.333 fourth gear was not much fun with 4500rpm at 100km/hr,
and the previously "reconditioned" ZF was a little noisy, so these things were addressed this time.
After a recent taste of circuit racing, he thought he would change a few things.
I have some pictures and will post them up soon.
That's mad Alan.
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on July 29th, 2009 at 10:00 PM
Development is never ending.....
FUCH your early!
http://www.noh2o.org/
Memberdangerous
Mood: 591
posted on July 31st, 2009 at 07:43 AM
After some discussion about budget and available used ratios,
we settled on the following ratios.
3.875 crownwheel and pinion
Original FTC 3.778, and 2.357 mainshaft,
1.524 third gear
1.125 fourth
This will give him a 'bearable' 3600rpm.
That's mad Alan.
Memberdangerous
Mood: 591
posted on July 31st, 2009 at 07:52 AM
One of the reasons for changing the crownwheel and pinion was this:
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1815.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1818.jpg
If you saw Steveys driving style at Valla,(and probably Wakefield) you can under stand why the poor old R&P
That's mad Alan.
Memberdangerous
Mood: 591
posted on July 31st, 2009 at 07:58 AM
The other thing I found was that the sides of the trans were not flat.
I think this was from an over eager removal of excess powder coating.
I made up a big flycutter and this worked well.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1684.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1689.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1690.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1687.jpg
That's mad Alan.
Memberdangerous
Mood: 591
posted on July 31st, 2009 at 08:11 AM
The other area that needed addressing was with the ZF limited slip.
The break away torque was measured and found to be well avove the factory settings
of 108 to 144 ft.lbs.
Someone had added some shims in there from "who knows what"? ,
so these were removed,
and the casing machined to acquire the correct preload.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1802.jpg
That's mad Alan.
MemberStanley
Threads: 270
posted on July 31st, 2009 at 08:36 AM
Top stuff Dave....imagine what you'll be able to do with a mill
MemberFlintstones
Threads: 69
posted on July 31st, 2009 at 11:27 PM
Great work as always Dave.
D
Memberdangerous
Mood: 591
posted on August 2nd, 2009 at 02:07 PM
Here is the insides of the ZF limited slip diff.
Note the tiny spiders and fine 18 tooth side gears.
This is the reason I am not a fan of the ZF.
If clutch packs are kept tight within spec they tend to hold up pretty well.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1783.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1789.jpg
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1795.jpg
That's mad Alan.
Memberdangerous
Mood: 591
posted on August 2nd, 2009 at 02:14 PM
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1790.jpg
You will note that these side gears have 18 teeth.
Stock VW is 17 and later swing axle and IRS bugs had 15, making them even stronger.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1786.jpg
Here is the NEW Brazilian 3.875 crown wheel and pinion.
I set it up for factory pinon depth and the pattern is where it has been lapped at the VW factory.
I normally like the pattern to be closer to the nose,
but being a Klingelnberg tooth form in this case, the tooth is a little thicker toward the heel anyhow.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1808.jpg
Also the pinion pattern location is where I like it in both 'drive' and 'coast', so I was happy to comprimise a little.
http://i113.photobucket.com/albums/n216/dangerous_05/IMG_1810.jpg
That's mad Alan.
MemberSick68VW
Threads: 122
Mood: hearing 48s
thumbup.gif posted on August 2nd, 2009 at 09:30 PM
looks nice dave keep up the great work...
[ Queries: 40 ] [ PHP: 17.5% - SQL: 82.5% ]
