[ Total Views: 1642 | Total Replies: 36 | Thread Id: 75450 ]
Author: Subject:  who cut up their oval
Member13BVW
Threads: 6
Mood: always chilled
posted on March 23rd, 2009 at 10:07 PM
One I found tonight on the net
http://i41.tinypic.com/353cmmg.jpg
13BVW 11.80@114mph
MemberTurbo54
Mood: Boost'n
posted on March 24th, 2009 at 08:30 AM
Grogy, it is still stock. I was thinking about having it removable but I cant get registration if I do it.
The car will be 100% street driven so I need to keep it as standard to look at from the outside so I dont get picked on.
T54
C'mon kids gather round,
Membergrogy
Threads: 344
posted on March 24th, 2009 at 01:03 PM
hi vw54, ok.......... so they no rego if its cut off/ bolt on. where r u , im in nsw and mine not reg either, so i shouldnt cut the rear. r u guards fiberglass, hard to tell in the pics. r they standard width. thanks grogy
MemberTurbo54
Mood: Boost'n
posted on March 24th, 2009 at 04:18 PM
These guards are standard but I am going for a set of 2" wider. I am in SA and they are not kind to cutting, even a removable apron is a hassle. I am cutting large holes in the side at the back to get to sparkplugs. I am also thinking of making the little trays on each side of the engine bay removable.
Think you confused me with another forum member.
Turbo54
Membergrogy
Threads: 344
posted on March 24th, 2009 at 04:47 PM
u right i mixed up my vws, thanks turbo 54, i also have to say thanks to vw 54 for other advise he has given in the past as have a few members. regards grogy.
MemberCalcool
Threads: 196
posted on March 29th, 2009 at 05:48 AM
Removable Stock Rear Beaver Panel
Its pretty easy to make the rear panel removable.
Just make it bolt in thru the existing guard bolts on each side. Need to make the panel have holes instead of cut outs like standard but if you are doing a resto you always have to fix the rear beaver, suggest filling ing the tailpipe cutouts and putting in a solid steel rod inside the roll as it makes it a lot stiffer once all installed.
I did it with mu old 58 Beetle and it was undetectable.
Clearance for tappet cover retaining springs can be overcome with bolt on alloy rocker covers too!
David
MemberTurbo54
Mood: Boost'n
posted on March 29th, 2009 at 10:39 AM
Grogy, After re-installing my box and engine agin the other night and how long it takes to do up the intake bolts I have decieded to try to get my enigineer to sign off on a complete removable rear end like 2442TT in the drag section. It is never going back to standard and I dont think it will hurt value in the long run. Also it is my car and it is what I feel is the right thing for this particular car.
There will be update in a while in my members rides section. Bolt on alloy rocker covers always leak.
T54
