| [ Total Views: 156713 | Total Replies: 204 | Thread Id: 75753 ] |
| Pages: 1 2 3 4 .. 7 |
byronmcmanus59
A.k.a.: Jono punton
Threads: 22
| posted on September 14th, 2009 at 10:07 AM |
love the oval mate, super clean.. screw the ball joint tool, try using two hammers
reub
VWRX is gone...
| posted on September 14th, 2009 at 12:08 PM |
Very envious of your oval!
I look forward to seeing the progression of the build.
Reub
Aussie
Threads: 43
| posted on October 11th, 2009 at 04:04 PM |
Trial fitted the beam up to make sure there were no issues. All went in easily and there is actually more clearance to the inner wings than on a stock
beam.
Dropped out the engine also so another step done before splitting the body.
Airkewld 2010
Threads: 0
| posted on October 24th, 2009 at 01:15 AM |
Car's coming along great Ian |
Aussie
Threads: 43
| posted on December 20th, 2009 at 05:54 PM |
Body off time. Made some lifting frames to help the process. Forks get bolted on to the bumper mounts.
Trolley jack goes under, lift to desired height and lock off with a bolt. Made some wheel trolleys too so that the chassis could be pulled out the
way.
Rolls around easily and ideal to work on the shell.
FROSTY
Threads: 65
| posted on December 20th, 2009 at 08:07 PM |
holy shit, that is the best lifting jig I have ever seen....Nice work
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on December 20th, 2009 at 09:03 PM |
Nice work Ian, nice setup mate!
Al
dangerous
Mood: 591
| posted on December 21st, 2009 at 05:21 AM |
Wow, cool jig and trolleys,
almost looks like some kind of engineer designed it!
| Quote: | Originally
posted by westi
That's mad Alan.
type_one
Threads: 166
| posted on December 21st, 2009 at 01:30 PM |
How stable is that Jig? Looks like the legs might fold in a bit. I'd be super keen on plans if available. Space saving when you aren't using them
for sure.
Blank
Aussie
Threads: 43
| posted on December 21st, 2009 at 06:50 PM |
| Quote: | Originally
posted by type_one
for sure.
Yeah pretty stable. I was a bit worried about this when I built them so I kept the upright outer sleeves long to help stop the legs from flexing. The
legs are quite thick gauge box tube and are a snug fit to the outer sleeves so no movement there.
Really happy with how they turned out - definitely makes this an easy one man job!
Aussie
Threads: 43
| posted on December 27th, 2009 at 06:27 PM |
Time to get dirty! Spent the last 2 days up to my neck in grease and oil getting the chassis cleaned up - easily the worst job so far. Still can't
complain - all this crud has kept the rust at bay for a long time. I am still amazed at the condition of this car after the last 2 tea strainers I
restored in the UK
Here is a pick of the front end after a grease down:
Check out the original chassis paint - not bad for 50+ years.
Aussie
Threads: 43
| posted on December 27th, 2009 at 06:38 PM |
Next the rear end got the same treatment. Dropped out the old split case + axles & tubes.
Cleaned up nice. The whole assembly will be stored and can be bolted back in if the car ever goes back to stock. Another handy use for one of the
wheel trolleys has been found.
Next job will be a trial fit of the new gearbox. The jury is still out on what front nose cone will be needed to get it fitted.
Aussie
Threads: 43
| posted on January 25th, 2010 at 04:11 PM |
Well, I managed to bugger my back over xmas while moving the floorpan around in the garage That will teach me for not bending the knees
Anyway, to help me out going forward (Doc says I have to take it easy) I decided to modify my lifting frames to work with the floorpan. Using a few
bits of scrap I made some additions to the original frames and now I can raise or lower the pan to whatever height and also spin it 360degrees. The
pan can be mounted with or without the gearbox in place to help me weld in mid mount tabs etc.
Next job........
dangerous
Mood: 591
| posted on January 26th, 2010 at 09:25 AM |
Looks awesome Ian.
Hope your back gets better soon,
I cant wait to see you driving this thing around again, even if it is only with a 36hp engine.
Alan drove his oval with 36er,(and now with 40hp) and a tall first gear,(3.33 with 3.88 diff) and it drove fine.
So your 3.444 with 4.125 will be no wuckers.
Still amazed how rust free this car is.
Your not planning to paint it at all? (hope not).
| Quote: | Originally
posted by westi
That's mad Alan.
Aussie
Threads: 43
| posted on January 28th, 2010 at 01:25 PM |
| Quote: | Originally
posted by dangerous
Looks awesome Ian.
Thanks Dave. Don't worry - not planning to paint anything that will be visible. Will paint the underside of the floorpan + framehead etc, inner
arches body colour, bottom of heater channels for protection and thats probably about it.
Euro_67
Threads: 75
| posted on January 30th, 2010 at 10:41 AM |
Dave,
What is the lowest rpm you would expect at 110km/h in a 'box setup with the tallest 4th gear possible, assuming 195/660/15 tires.
dangerous
Mood: 591
| posted on January 31st, 2010 at 05:25 AM |
195/60/15 tyre measures 24.21" in height according to google.
If Ian was using such a short tyre his rpm would be 3636rpm at 110km/hr.(4.125 diff with 0.931 fourth).
With Ian's proposed 205/70/15 tyre this would be 3346rpm.
The tallest gears VW make are the 3.875 diff and a 0.821 from an early bus.
This would be 3012rpm with the same speed and 195/60/15 tyre.
Albins DO make a 0.696 fourth gear and this would be 2554rpm, but these are very impractical,
an the huge gap from 3rd to 4th would be bogus.
| Quote: | Originally
posted by westi
That's mad Alan.
Euro_67
Threads: 75
| posted on January 31st, 2010 at 09:40 AM |
Thanks for the info.
I imagine higher load and lower rpms may also have a negative effect on engine cooling with the fan also dropping rpm.
66brm
Threads: 4
| posted on February 1st, 2010 at 11:11 PM |
Cant wait to see more progress on this one
cam070
| posted on February 2nd, 2010 at 10:59 PM |
Nice progress on this project. Hope your back gets better soon so you can really get stuck in again. And very envious of those jigs, man they are the
sh*t.
Aussie
Threads: 43
| posted on February 15th, 2010 at 07:35 PM |
K & L time....... Stripped all the grease and crap off the K&L assembly ready to have new stuff fitted throughout.
Labelled it all up and packed it ready to have the new pins and bushings put in. So paranoid about mixing up all the bits......its like a chinese
puzzle!
Came back all shiny and nice and ready for a bit of paint. Didnt paint the carriers first as they would likely have got chipped during putting in the
King's. I had painted the CB spindles back over in the UK to protect them from rusting during the boat ride over.
I taped it all up ready for a splash of gloss black. How good are the WD40 lids for masking off the Link pin holes??
Scarab
Threads: 8
| posted on February 15th, 2010 at 09:02 PM |
nice work!! love your painting trolley!!
Scarab (aka: Paul)
Wannavee
| posted on February 15th, 2010 at 10:32 PM |
Ah shit,I just threw one of those 'painting trolleys' out! Coulda used that this week painting my wheels
Damn it
donn
Threads: 428
Mood: LAID BACK AND CONFUSED
| posted on February 16th, 2010 at 08:18 AM |
Never throw those painting trolleys away, I've got one withthe seat still intact but without the backrest, great for sitting on while tinkering under
the bonnet of the buggy.
Aussie
Threads: 43
| posted on February 28th, 2010 at 07:48 PM |
Had a few issues getting the new box to mount into the correct position and finally chased it back to the front mount. I have two brand new front
mounts and both of them are wider than a stock mount which does not allow the box to sit as far into the chassis as it needs to to retain the stock
geometry. Bloody repro crap
The front mount on the old split box was in pretty good shape so was decided to reuse. Only issue is the new ERCO nosecone has 10mm stud holes and the
old mount has 8mm studs.
To sort this I "machined" up some sleeve's and installed them as a snug fit into the mount holes.
Job done!!
Aussie
Threads: 43
| posted on March 8th, 2010 at 09:39 PM |
Really wanted some detailed fuch rims to go on this car so ordered some Flat 4 wheels in 4.5 and 5.5 inch widths. Went over to Das Resto Haus for some
detailing action over the weekend to get things moving along.
Al was good enough to let me do some of the labour to offset the cost and also see what the process was. Started out masking things up and then
working out where we wanted the paint to cover vs what remains polished.
Infill taped all the remaining areas we didnt want the paint. 400 grit wet and dry then keyed in the surface.
Masked up the rest of the wheels and then lined up ready in the spray booth.
Primer applied then 2 coats of direct gloss black (no clear coat needed).
Take off the masking and we're done!!! Look awesome and can't wait to get them fitted up. Will leave for a few weeks now though to fully cure and
harden up.
trickysimon
A.k.a.: Simon Azzopardi
Threads: 43
| posted on March 8th, 2010 at 09:53 PM |
Mmmmm fuchs
chippy
Threads: 14
Mood: Volksie!
| posted on March 9th, 2010 at 05:28 PM |
They are SEXY AS!!!! I dont know many beetles that wouldnt look good sitting on those!
Cheers Todd
Aussie
Threads: 43
| posted on April 3rd, 2010 at 06:16 PM |
Got back to the Gearbox again and lined things up for a final fit. Didnt like the fit of the rear cradle as when bolted up it did not sit fully under
the rear mounts. To fix this I welded a plate onto the back of the cradle which pushed it out to sit squarely under the bell housing.
Now bolted up it all seems to line up properly again. Probably not 100% necessary but I just like things to look right.
Aussie
Threads: 43
| posted on April 3rd, 2010 at 06:29 PM |
Next up was the mid mount which needed brackets welded onto the frame horns.
Here is the kit as supplied:
You need to replace the 4 stock length studs under the box with longer versions to allow for the thickness of the mount plate.
Next a trial fit to make sure there is good clearence to everything. Not sure how much these things flex under load but the design is good with plenty
of room for a bit of movement.
The only thing I didnt like about the kit was the profile of the mounting face where it is welded to the frame horn.
So I grabbed the grinder and file and shaped things a bit for a more snug fit. Should help to make the welds a bit neater at least!
